2 sec to off, 22" LG Flatron, W2252QT
    Re: 2 sec to off, 22" LG Flatron, W2252QT
    No, but you can trace the circuit and identify which one goes to which voltage easily.
    Usually the higher voltage caps are feeding the invertor, and the smaller ones the logic board.
    You can be sure that you can find another caps afther the filtering caps on the rail to the logic board.
      Originally posted by 901THECAT View Post
      I finally figured it out
      the ones circled are the ones I need to replace
      Two of them are 1000uf 16 volt and the other 2 are 47OUF 35 VOLT
      Is there anyway to know which go where by the numbers on the board?
      No. But by following the traces on the back of the board it is easy!!
      PlainBill
        PlainBill
        i am not quite sure what you mean
        On the back of the board is the 8 holes for the 4 caps I removed
        I don't know what to look for
        Is there anyway to find a schematic of this lg w2252qt power supply board?
        Would there be any numbers on the original caps that show where they might have been positioned on the board
        I should have never took them off until I had the new ones to replace them or I should have took a picture
        This is my first time working with replacing caps
        I have a pic of the back of the board but I can't get that manage attachments screen to come up again
        It worked once
        I don't know anywhere else to post my questions but this thread because it deals with the same product I am trying to fix and everyone has been really helpful
          It worked once
          I understand; tracing paths is difficult if you don't know what to look for. That's not unusual.
          Do this: After you read this post, click on the 'Quote' button in the lower right corner. Enter some meaningful text if you wish. Now scroll down below the text entry area and click on 'Manage Attachments'.
          PlainBill
            PlainBill
            can I email you the pictures? I can't get the 'manage attachments' to come up
              You could, but I can't contact you via PM. Check your settings on this forum.
              PlainBill
                PlainBill
                I set up that vcard thing I think you can send me pm's mow if I did it right
                  Hi
                  Could anyone help with my Lg Flatron W2252TQT. Could anyone provide me a closed up picture of Front Panel board of the said model because i misplace this board also the top view of every board inside the Unit. Hoping someone will provide me one
                    Originally posted by Erick021972 View Post
                    Hi
                    You aren't going to get much help if you double post.
                    PlainBill
                      Ok sorry about that. I'm trying to look for picture of a control board and power "ON" board of a LG Flatron W2252TQT. Can anyone of you guys help me my control board and Power "ON" board are missing and I'm trying to find a way to buy or make a design by myself. All i need is a design how to make and wire it.
                      Erick
