Samsung Syncmaster 245BW - Common symptoms - don't how to test
  • Sub780lime
    • Sep 2010
    • 5
    Alright, So I have seen a few threads floating on this but neither one seems to address the exact problem I am having and I need a little more direction on how to test and resolve it. The issue is one I have heard from others. The power led does light up on the monitor, but it will not display a picture. With no inputs connected and the monitor on it does not show the seeking signal screen. Now, if I have my computer on and connect the monitor and press the menu button I can get a quick glimpse of the desktop (it is shifted about 25% to the right) and then its off again. Its no more then a second. Also, when I press the arrow enter button I get some colored lines on the the right side of the monitor. This is not overlayed the desktop, just on its own.
    So, I am a complete noob when it comes to electronic boards. I understand electronics and computers on the service and to the component level, understanding the board level itself is knowledge I do not have. So, I have taken apart the monitor a decent amount of the way...first thing I always do when I have a problem with something, lol. I do not notice any obvious issues looking at the boards. I have heard many mention bulging capacitors, but I really can't seen anything that looks abnormal to me, at least, with my untrained eye. So, I took pictures of the main boards I came across and I am look at some guidance on if there is something that is obvious from the pics or what and how I can begin testing. I do have a multimeter. Let me know if you need other pictures. Thanks all! Reading on this forum, seems like there are a lot of knowledgeable members willing to help.
    Follow the link if you would like to see full size hi rez copies of the images
    http://www.flickr.com/photos/3247305...7625057224610/
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung Syncmaster 245BW - Common symptoms - don't how to test
    We are going to need better pictures in higher resolution and posted to this site. After that, we can suggest things to check with your multimeter.
    1) Post clear focused pictures AFTER reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    2) Please do not post pictures inline as they slow down the loading of pages.
    3) For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    4) Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • Sub780lime
      • Sep 2010
      • 5
      Will do. My initial concern with such hi rez photos was the size (mb) for the photos and the max acceptable for the board.
      • retiredcaps
        • Apr 2010
        • 9271
        When you use the manage attachment, it will specify the mb size. I use software to "resave" the jpg and can typically shrink the filesize by 4x and still have high quality focused pics.
        • Sub780lime
          • Sep 2010
          • 5
          I am not able to upload the images. The upload fails even though it is at or below the size and dimension requirements. When I try all 3 at once I get a security error. When I try 1 at a time it just tells me it failed.
          links to images discussed below
          So I think I have identified the problem and it is two fold. I was taking pictures of everything in better light, when I decided to check the actual backlight and LCD. Well, as you can see from the images two bulbs are cracked. Also, there is a dimple on one of the LCD ribbons. If you zoom in you can see it. It corresponds directly to the last photo, which I light with a lamp while using my laptop to provide the source. Everything works but that strip and it lines up perfectly with the ribbon with the dimple in it (like a finger nail). So my questions. The back light does not stay on at all. Would the two bad bulbs cause this? Or should the 3 good bulbs still light up fully? Second, is there a way to repair the ribbon issue? Will a shop have to do it?
          • retiredcaps
            • Apr 2010
            • 9271
            Yes, 2 bad bulbs will cause the backlight to go off. Most inverter IC chips are designed to shut off the backlight if one or more of the ccfls are bad. Think of it as "all or nothing".
            Don't know about your ribbon issue.
            • alexanna
              • Mar 2010
              • 1346
              as far as the ribbon problem thats part of the LCD and I know of no way to repair it.If you decide to spend the money on lamps,you could still have a display issue.
              Al.
              • Sub780lime
                • Sep 2010
                • 5
                What about replacement part for the LCD with Ribbon?
                • retiredcaps
                  • Apr 2010
                  • 9271
                  If this were my monitor, I would try the ccfl replacement and pray that the ribbon cable is fine. Since this a 24 inch monitor it is worth the effort.
                  If it were a 15 inch monitor, I would use the parts for future donor parts.
                  • Sub780lime
                    • Sep 2010
                    • 5
                    The problem is, I know the ribbon is not fine, because the distortion is there when you use another lamp as the backlight.
                    • chth96
                      How Can I test PWM DM0365R?
                      by chth96
                      Hello
                      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                      06-18-2025, 04:14 PM
                    • khelane
                      test active pfc power with lamp test
                      by khelane
                      Hello
                      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                      Is there a way...
                      06-03-2025, 01:00 AM
                    • chronic519
                      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                      by chronic519
                      Hello.
                      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                      Found issue with a RAM block
                      Replaced, green lines gone.
                      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                      Used a good card to test and same results low errors 32+.
                      I am just search for some form of command to do a full test on the GPU.
                      I just ran the mats command with my good GPU and passed after roughly 40 min.
                      The repaired one, ran...
                      05-20-2025, 07:56 PM
                    • Fredrik_Bostrom
                      LG 60PK250N ZA No picture
                      by Fredrik_Bostrom
                      To start with I think I have red every single topic on this forum about the No picture fault on this TV. Seems like a common fault but I just can´t find a match i other forum threads for my TVs fault.
                      Symptoms:
                      No picture, not even a little primer.
                      Unable to check if I have sound since I don´t have any picture to navigate the menu to be sure I´m on the correct input.
                      When connecting power cable it clicks just like it used to and the red standby light on the front comes on.
                      When pressing the power button on the front it clicks like it´s...
                      01-25-2024, 02:03 AM
                    • alltvrepairs
                      Lg TCon test pins for screen test
                      by alltvrepairs
                      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                      Appreciate your help....
                      06-13-2025, 06:33 AM
