Denon TCD-784 (ABEX) Test CD ISO
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I'm trying to find an ISO image of a test CD called: TCD-784 (ABEX)
    I'm guessing ABEX is the manufacturer,
    I'm try to repair a Denon UD-M30 which is a compact all in one CD/Amp/Tuner and the service manual calls for the above test CD.
    The track listing can be found here: https://www.almedio.co.jp/wp-content...pdf?2015060501
    The service manual is attached.
    https://www.badcaps.net/forum/attach...1&d=1645995712
  • petehall347
    • Jan 2015
    • 4428
    • United Kingdom
    Re: Test CD ISO
    check this out it may do same things . https://audiophilestyle.com/ca/ca-ac...download-r780/
    • R_J
      • 9567
      Re: Test CD ISO
      What is the problem with the cd? Do you have a scope?
      If the cd is working and you just want to do the alignment you can likely just use a good store bought cd, I would not use a cd image you burnt yourself.
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        Re: Denon TCD-784 (ABEX) Test CD ISO
        Thanks both.
        I've just opened the box and after the tray loads the CD it's doesn't spin up.
        I've cleaned the lens with ipa but it still won't spin up.
        Any thoughts?
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          The difficulty is that in order to get to the CD PCB (which lives on the underside of the drive) you have to disconnect it from the rest of the circuitry. So I'm not sure I can take measurements with the CD drive powered.
          • pecrie
            • Nov 2011
            • 182
            I`m not really sure , but is there not a switch that must be activated to let the player know , that the drawer is closed ??
            • R_J
              • 9567
              If you close the tray without a disc, can you see if the optics are moved to the inner part of the disc, Does the laser light? does the lens try and focus (move up & down)?
              When there is a disc in the tray, does it spin freely? or is the spindle motor sticky.
              If you can operate the mechanism manually (turn the sled motor gear) to move the optics to the center of the disc, then load a disc and see if the optics move to the inner part of the disc. This will check some of the operation.
              There should be a tray in position switch, but if it is not working the tray usually will just eject.
              • Nevillet
                • Sep 2019
                • 272
                • United Kingdom
                After taking the CD deck out I can confirm that the in & out limit switches work at the appropriate time.
                The motor that spins the disk does not turn on when the tray loads the CD.
                The motor itself works when powered with 5V.
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  After taking the CD deck out I can confirm that the open & close limit switches work at the appropriate time.
                  • R_J
                    • 9567
                    Do not hook 5 volts to the motor with it connected to the drive board, you can damage the driver ic.
                    Usually the optics will focus before it spins the disc, does this happen?
                    • Nevillet
                      • Sep 2019
                      • 272
                      • United Kingdom
                      Thanks for that.. I disconnected the motor/switch board before i powered the motor. The red/black wires were principally to measure V across the motor when in use.
                      • Nevillet
                        • Sep 2019
                        • 272
                        • United Kingdom
                        Q: does the laser briefly switch on to check for a disk before the motor spins?
                        Or does the laser power on after the disk spins?
                        • R_J
                          • 9567
                          Usually the sled drives the optics to the inner stop, the laser will light, the lens will focus and the disc should spin.
                          • chth96
                            How Can I test PWM DM0365R?
                            by chth96
                            Hello
                            I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                            So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                            I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                            I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                            06-18-2025, 04:14 PM
                          • khelane
                            test active pfc power with lamp test
                            by khelane
                            Hello
                            I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                            Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                            Is there a way...
                            06-03-2025, 01:00 AM
                          • chronic519
                            Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                            by chronic519
                            Hello.
                            GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                            Found issue with a RAM block
                            Replaced, green lines gone.
                            Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                            Used a good card to test and same results low errors 32+.
                            I am just search for some form of command to do a full test on the GPU.
                            I just ran the mats command with my good GPU and passed after roughly 40 min.
                            The repaired one, ran...
                            05-20-2025, 07:56 PM
                          • alltvrepairs
                            Lg TCon test pins for screen test
                            by alltvrepairs
                            i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                            Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                            Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                            Appreciate your help....
                            06-13-2025, 06:33 AM
                          • signal.quest
                            Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                            by signal.quest
                            I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                            I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                            09-30-2024, 11:21 PM
