Help diagnosing Pyle Receiver PTA66BT with burned resistors
  • SluggerB
    • Aug 2020
    • 747
    • US
    #101
    Re: Help diagnosing Pyle Receiver PTA66BT with burned resistors
    So this is odd. I confirmed chips F and G and the CD IC are disconnected and drawing no power
    So right now V- has chips A-E connected, and nothing else. It has 6.14v across the resistor
    V+ has chips A-E connected, and the power LED. It has 6.2v across the resistor
    Why is V+ resistor getting so much hotter than V- with such a minimal load difference? Do metal oxide resitors just run that much hotter than carbon film ones? Or is something else cause that V+ resistor to overheat? It can't be any missing connection or load or else we would see that in the voltage reading, correct?
      The replacement is Metal Oxide type and has the same dimension as the MOX for the -V, correct?
      Do you have infrared thermal meter?
      https://www.electronics-tutorials.ws...tor/res_7.html
      • Trumpetrousers
        • Aug 2020
        • 5
        #103
        Hi guys,
        I've just joined this site. I enjoyed reading this a lot. I was so eager to do the repair myself...
        I wanted to say the patience and effort given to help out the new chap was extraordinary. Medals should be awarded in some of these cases.
        Well done to both of you for persevering and getting to the bottom of it.
        Brilliant stuff.
        Regards Martin.
        • Trumpetrousers
          • Aug 2020
          • 5
          #104
          PS This last bit is impossible ha, ha, this is great to read.
          Is the DC voltage rock solid? Does it wiggle about at all? All I can think of is some ripple getting through or some AC component - Though it has multiple stages of filtering/regulation so don't see how.
          • SluggerB
            • Aug 2020
            • 747
            • US
            #105
            The replacement V+ is metal oxide (bluish color). The V- (and the original V+ that burned up) are carbon film (beige) color. It is the same size and tests same resistance
            I do not have an IR thermal meter, just a hand held temp probe
            • SluggerB
              • Aug 2020
              • 747
              • US
              #106
              The voltage drop across the resistor is solid. Probing other components with smaller contacts sometime I get wiggle in the numbers
              It's just odd that 2 voltages so similar would produce such drastic temp difference's in the resistors. The carbon film V- resitor never even gets warm, the V+ gets to around 98-100 degrees and hot to the touch with just a tad more voltage going through it
              The 2w resistor shows up tommorow so we'll see how that feels. I'm going to out it in first with just chips A-E and LED connected, get a voltage and temp, then add the 100ohm resistors and get a voltage and temp, and then the CD IC and get a voltage and temp
                It will help if you leave the resistor legs long so the body of the resistors will be above the board for better cooling.
                You can also try swapping over the 180 Ohms resistors.
                • R_J
                  • Jun 2012
                  • 9638
                  The V+ is likely used to supply more components in the circuit, the V- could be just for any of the opamps only.
                  • petehall347
                    • Jan 2015
                    • 4452
                    #109
                    is the board good for a 2w resistor in case of fault conditions ? like is there enough copper ?
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      #110
                      It does, but right now those extra components are disabled, I confirmed with my meter they are not drawing any voltage. At the moment the only difference in load between V+ and V- is the LED light.
                      I don't know if just the existence of a third transistor on that V+ power rail would cause that resistor to run hot.
                      I have no idea how to test that. Larger resistors do exist in the board in areas outside the power rails.
                      • petehall347
                        • Jan 2015
                        • 4452
                        #111
                        you are like doubling the size of a fuse . if downstream things can cope with this thats fine . some things are built right on the edge of everything .unlike the in the old days when everything was overrated .
                        there are probably guidelines around that say what current can pass through copper safely . i dont have a clue as never designed a circuit board .
                          BTW, the MOX can handle high temperature than Carbon film.
                          So did you swap the 180 Ohms resistors?
                          You can also see surface temperature rise chart (MO-MOX PDF) that 1W MOX at 50% of power rating, the surface temperature rise is 37.5c = 99F temp rise above ambient temperature..
                          So you have Vdrops of 6.2V on 180 Ohms resistor, so power dissipation is about 0.2Watts, according to the chart, the temp rise at 0.25Watts is about 22c = 72F temperature rise above ambient temperature.You indicate 100F reading? if ambient is 25c (77F) then you are way below the rating.
                          Not many companies publish surface temperature.
                          I am still looking for Carbon film surface temperature rise rating.
                          Learning about resistor:
                          https://eepower.com/resistor-guide/
                          https://eepower.com/resistor-guide/r...ilm-resistor/#
                          • SluggerB
                            • Aug 2020
                            • 747
                            • US
                            #113
                            Question, I thought the same amount of current was going through the resistor, and the resistance is the same (180 Ohms) so the same amount of power is being sent down the rail. But the 2W resistor can dissipate heat faster. Are you saying the 2W resistor will allow more voltage to flow through V+ rail vs the 1W one? Or that of there was some sort of power surge, it would be able to withstand that better, and not burn out, and it would pass that excess power down the rail?
                            I did read that metal oxide resistors can tolerate a higher temperature, but I don't know if it normally runs hotter under the same load compared to a carbon film one.
                            The 2W resistors show up tomorrow. The only replacement is the original repair replacing the burned up 1W 180 Ohm Carbon film resistor with a 1W 180 Ohm Metal Oxide resistor. I guess I could swap the V- carbon filter resistor with a 180 Ohm metal oxide resistor and see if that gets hot. I have 9 of them
                            Well, around 100F is when I stopped measuring and turned the machine off.
                            according to the chart, the temp rise at 0.25Watts is about 22c = 72F temperature rise above ambient temperature. if ambient is 25c (77F) then you are way below the rating.
                            The room I am working in is about 64F-68F. Yes, I love the cold. So would that mean that the normal operating temp for that resistor would be 141F-145F?
                            Yeah I had little success finding any of that as well
                            • SluggerB
                              • Aug 2020
                              • 747
                              • US
                              #114
                              So looking at https://cdn.badcaps-static.com/pdfs/...eef2e50ff9.pdf (I don't have this brand but I'm assuming different brands will not have wildly different properties) the Thermal impedance (°C/watt) for a 1W resistor is 110. Does that mean the temp rise of 0.25W would be ((110 * 0.25) * 9/5) + 32 = 81.5F? If so I am over that temp already.
                                It's the temperature rise, so if your room is 70F and the resistor is at 100F that means the temp rise is only 30F well below the expected which is good well within safe limit of the rating.
                                And if you raise the body above the board that should help cooling, it is not good idea to mount power resistor against the board.
                                So 25c (77f) ambient + 27.5c (81.5f) rise = 52.5c (126.5f).
                                • SluggerB
                                  • Aug 2020
                                  • 747
                                  • US
                                  #116
                                  And if you raise the body above the board that should hep cooling.
                                  I'm going to do that with the 2W resistor, I'm going to keep the legs a little longer, and I'm putting a piece of heat resistant tape on the board under the resistor. I've hit that stuff with 350 degree hot air and it didn't even crinkle.
                                  And worse case scenario, since you have to buy all these things in batches, I have enough spare parts to completely replace the V+ power rail 7 more times lol
                                    Is your meter True R.M.S? If it is, set the meter to AC Volt then check the Voltage of each legs of 180 Ohms resistors against Ground.
                                    • Trumpetrousers
                                      • Aug 2020
                                      • 5
                                      #118
                                      Budm has given unfailing good advice.
                                      It is always good practice to raise power resistors off the board. It was very common to see this in the through hole era and further back.
                                      No need for any fancy tape though.
                                      Resistors convert electrical energy to heat with 100% efficiency whether they are carbon or metal oxide. The area of dissipation is the most critical, if they are of the same size they should get equally hot if the same value. (Though I should look at Budm's temperature chart before saying that...Though the physics say I ought to be correct). Ie. Metal Oxide resistors can be smaller as they can withstand more heat.
                                      It is much more sensible to replace these with a 2W and not worry about the board or downstream components, If enough current is flowing to destroy a 1W, then everything will have suffered enough never mind before you get to the amount needed to frazzle a 2W. With the same logic, these are not intended as a fuse apart from a pretty poor one.
                                      So in conclusion if they are dissipating a certain wattage, and both are very close to the same, then that wattage is all turned to heat, the surface area and the thermal resistance of the component to ambient along with airflow will determine the body temperature. Both should be very similar...
                                      • SluggerB
                                        • Aug 2020
                                        • 747
                                        • US
                                        #119
                                        It is not
                                        The 2W resistors showed up, I will be putting it in this evening. My big worry is that the one pad is a little damaged so it will be tricky to get it in without causing further damage. I am going to melt the solder but not suck it off, while meted pull the leg of the 1W resistor out, and then insert the leg of the 2W resistor in, leaving a lot of height from the board. I figure the tape can't hurt since that spot on the board is already charred black. I ave been doing some reading and it does look like you can go arbitrarily large on a resistor value and be fine barring edge issues like impedence and such.
                                        I also noticed there is a fan in the unit, but I have never seen it run. I don't know if it is actually hooked up to a thermistor or any kind of sensor, from memory it looks like it is just running right from the power supply and so should be spinning all the time. I will take a look, I have a bunch of old PC fans I could replace it with if it went bad, I have plenty of experience working with those from my building PC days.
                                        After I replace the resistor I'm going to reattached all the pulled component so the unit is fully functional and try playing music on it for a solid 30 minutes and see if it can take it. If so I will consider the project finished and a success. If something breaks, I will report back
                                        • Trumpetrousers
                                          • Aug 2020
                                          • 5
                                          #120
                                          You can always scrape a bit of the green resist off the track to get more copper area to solder to.
                                          • mikey5791
                                            by mikey5791
                                            Hi to all forum members,
                                            12-26-2024, 04:55 AM
                                          • youpla
                                            PowerColor rx 5700xt dual fan : current sense resistor
                                            by youpla
                                            I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
                                            The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
                                            The card wasn’t displaying anything after this fix.
                                            When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
                                            I tried to resolder it with a hot air station, but the resistor wouldn’t...
                                            12-01-2025, 07:52 AM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
