PowerColor rx 5700xt dual fan : current sense resistor
  • youpla
    • Jun 2020
    • 17
    • France
    I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
    The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
    The card wasn’t displaying anything after this fix.
    When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
    I tried to resolder it with a hot air station, but the resistor wouldn’t stick—probably because the pads under resistor are damaged.
    Does anyone know the exact resistance value (in ohms) of the current sense resistor (shunt) for this GPU ?
    I suspect it’s in the 0.01Ω to 0.05Ω range perhaps less, but I need confirmation.
    Best regards, Nicolas
  • youpla
    • Jun 2020
    • 17
    • France
    Nobody have a clue about value of this shunt resistor?
    • youpla
      • Jun 2020
      • 17
      • France
      I just bought some 0-ohm resistors. Do you think there’s any risk in replacing the missing shunt resistor with a 0-ohm resistor ?
      I’m asking because the original shunt was a low-value resistor (likely 0.01–0.05 ohms), and I’m not sure if using a 0-ohm resistor could cause issues like:
      • Instability in the voltage regulation (since the current sense feedback would be lost),
      • Overcurrent risks (if the GPU’s power controller can’t measure current properly)
      • Potential damage to the GPU or other components.
      Has anyone tried this on a PowerColor RX 5700 XT (or similar GPU) ?
      Any advice would be greatly appreciated !
      • zlr8r
        Lenovo Yoga Slim 6 14IRH8 Schematic for resistor value
        by zlr8r
        Hey Guys, not sure if this is correct part of forum to ask but, could anyone tell me what value this resistor is near the EC chip (ITE IT5571VQ-128) on a Lenovo Yoga Slim 6 14IRH8 motherboard please ?
        (in the image , i have de-soldered the resistor and moved it up so its not making contact on both sides)
        thanks in advance
        06-21-2026, 06:01 AM
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • Darren Hibbert
        Replacing a Current Sense Resistor
        by Darren Hibbert
        Hi.
        Quick question.
        I have a laptop that is completely dead. I opened it up and it looks like the current sense resistor is blown. However, because it's blown, the value printed on the top has disintegrated and there is no schematic available for this particular laptop (Dynabook Portege) so I'm not sure what to replace it with.
        04-08-2024, 08:36 PM
      • mikey5791
        by mikey5791
        Hi to all forum members,
        12-26-2024, 04:55 AM
      • ezenia
        NANKADF WPS3010H 30V 10A PSU missing resistor value identification
        by ezenia
        I have this NANKADF WPS3010H 30V 10A PSU that I am in the process of repairing. During my troubleshooting, I noticed a missing resistor next to the TL494C chip.
        I have marked the missing resistor location in this image below:
        I'm aware Q3 and Q4 are missing. These were removed by me (waiting for replacement parts). I am just stuck on the missing resistor since I can't find any proper close-ups of this board online nor do any schematics/boardviews exist. I've come across some YouTube teardown videos of similar PSUs with the TL494C chip....
        06-26-2026, 08:11 PM
