Want to remove the LOW Battery Alarm Feature from a Sony Sports FM/AM Radio
  • MAVA
    • Mar 2018
    • 42
    Gentlemen,
    This is my first, I searched and found nothing...
    I have been repairing/designing electronic things, but lately into the repair/modification of the Latest Mercedes Electronic Transmissions. I'm a Moderator on Benzworld.org under the same screen name if you have Mercedes Benz questions PM me there, and I will point you the direction you need to go...
    I'm looking for schematics to a Sony Sports Walkman FM/AM radio Model SRF-M78.
    https://www.manualslib.com/manual/16...n-Srf-M78.html
    I want to tweak the voltage input comparator to turn-OFF this low battery alarm feature that shuts the walkman as the battery gets low. I RATHER LET IT DIE as the batteries die...
    I know this is petty thing, but it was too stupid to at this to the circuit. I bet if I modify this circuit I could get double the run time off the AAA's, but right now it is like 10hrs...
    The only Schematic place I found was this place:
    Maybe someone has it, or point me to another place that may have it, yet maybe I can get close with another model..
    Thank you,
    Martin
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Want to remove the LOW Battery Alarm Feature from a Sony Sports FM/AM Radio
    If you post pictures of th inside we may be able to point you in the right direction.
    EDIT: well, looking at the posts below, the B+ monitoring is built into the main chip, so not removable. And PLL is hit and miss on lower voltage. I was hoping it was old enough to be tuned oscillator based, but nope.
    Follow the white rabbit.
      Try here: https://elektrotanya.com/showresult?...oria=&kat2=all
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        The voltage limit might be there for a reason, one thing is that PLL tuning requires voltages to be accurate and if the voltage isn't high enough or the divider can't divide fast enough due to low voltage, it won't tune properly, can't lock onto a station anymore, and all you'll get is static/noise.
        This is nothing like analog receivers...
        • MAVA
          • Mar 2018
          • 42
          Thank you all for your replies. Budm, the second file contained the schematic. Thank you..
          My guess is with pins 14 Vdo and Pin 11 CE on IC 51 (uPD17015) are responsible
          IC 52 (S-80720AL) the 2.6v Voltage Detector probably goes low right around 2.6v.
          I need to disassemble my unit and power it with the variable bench power supply to watch the states of the Vdo and CE
          Here are the schematics, and the two data sheets(IC51 and IC52)
          Martin
            It looks like all you have to do is to disconnect pin 1 of the Vdetect IC then either GND or pull the empty pad HI, I do not know which IC is actually being used, the one with ACTIVE HIGH, or ACTIVE LOW.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Yeah looks like IC52 (voltage detector) probably will drop towards 0V if the voltage input drops below 2V based on the debug information and data sheet. Removing this IC and just connecting vin to vout (2 to 3) should disable the feature.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                2v for a pair of cells is dead anyway.
                if you use nicd/nimh it will protect your batts from over discharge/reversal.
                i see no point in removing a useful feature.
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Why do you think the designers went to the trouble to design that feature into the product and add the necessary components to implement it? Do you think they are out to force you to buy extra batteries?
                  (Hint: you don't add design effort and recurring cost to a product without a valid reason -- even if that reason is "to sell extra batteries".)
                  You may discover you end up losing all of your station presets because the NVRAM interface doesn't operate reliably with fallling battery voltage. Or, you may discover that some active is forced to operate in its linear region (instead of as a switch) possibly INSIDE one of those chips.
                  Buy better batteries or carry a spare set with you if you want/need more than 10 hours of service life.
                  • mikey5791
                    Sony CFS-5000S radio cassette player no FM reception
                    by mikey5791
                    Hi forum members,
                    In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                    Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                    I opened the casing inside and checked for any dry solder, burned component or loose wires...
                    02-24-2023, 03:48 AM
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • NolesFan
                    sony kd-85x85j Looking for info on how to remove back cover
                    by NolesFan
                    Like the title states. TV is 3 years old and Im getting 6 red blinks, which is backing lighting issue or driver. I just cant find any info on how to remove the panel to access. Any info would be greatly appreciated.
                    03-14-2025, 08:23 PM
                  • UserXP
                    Vintage SONY Digital Clock Radio ICF-C12W no audio
                    by UserXP
                    Dear all,
                    I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                    i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                    My question is, do you know of this brand of capacitors and how bad are...
                    07-21-2025, 08:35 AM
                  • flc1988
                    Sony mbx-247 need to remove battery to turn on (sometimes not)
                    by flc1988
                    Hi, i have a Sony vpceh-30eb. Battery original looks good. Original charger Sometimes, when pressing the power button, the notebook does not light up any led. but if you remove the battery it turns on normally. Sometimes it runs on battery power.
                    08-31-2023, 11:31 AM
