Philips cdr-765
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Philips cdr-765
    I have one of these old cdrs and the only discs it will burn or recognize are cdrw discs.
    They stopped making cdr for music years ago. They had the blue-ish tint to them.
    There is a modchip in Italy that claims it will use the cheap cdr discs for computers.
    Has anybody used this? What chip are they selling?
    master hoarder
    • May 2008
    • 12170
    Re: Philips cdr-765
    Interesting find.
    I've seen old CD players not read CD-RW discs with music, but never a properly-burned CD-Rs (i.e. closed session/DAO). That said, I have seen those blue-tinted music discs and always wondered what makes them so special for music, as I've never had problems with my burned music CDs.
    What program are you using to burn your music? And which OS. Windows 10 has the habit to immediately format optical media upon insertion (with a prompt, of course). Many people just click stuff to "OK" the prompt, and they end up with an open-session disc that may not be very compatible with older stuff.
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Re: Philips cdr-765
      I meant to say that it won't record on any cdrs that don't have the blue tint. I use it to copy old albums and reel to reel tapes. I can burn them to a cdrw and then copy on my computer but it's a pain.
        • 31010
        Re: Philips cdr-765
        there was a scam at one time where some audio recorders would only write to discs that had a specific i.d. on them,
        these "audio" cdr's cost a lot and there may have been some government scam involved such as a "piracy tax" in some country's like holland.
        where is philips based??
        • R_J
          • Jun 2012
          • 9535
          Re: Philips cdr-765
          I found some old info here, http://audiokarma.org/forums/index.p...corder.138057/ maybe the sony music cdr will work
          • petehall347
            • Jan 2015
            • 4426
            Re: Philips cdr-765
            i have an old recorder from philips . i could never find the discs so its stored away . i remember the discs had to be slow burn ones . maybe 4x . i cant remember properly . i did read up about the mod chips .
            i was rather pissed off at the thought of paying tax on my own material . sony minidisks also had a similar problem .
              master hoarder
              • May 2008
              • 12170
              Re: Philips cdr-765
              Oh I see what is going on now. The Philips cdr-765 is one of those component systems and you are using it to record CDs, but it won't work with CD-Rs that aren't the blue-tinted ones specially made for music recording.
              Hmmm... If the mod chips is not expensive, then perhaps do give it a try. I have no idea what it is or how it works, as this is the first time I hear of one for this kind of use. My guess would be that it probably communicates with the main IC in the system over a standard serial protocol and just inserts a valid CD-R serial number when the system's IC looks for one, so you can record to any CD-R.
              • petehall347
                • Jan 2015
                • 4426
                Re: Philips cdr-765
                yes .like protocols and handshakes sort of voodoo ..
                • R_J
                  • Jun 2012
                  • 9535
                  Re: Philips cdr-765
                  Some people that have ordered and received the mod chip did not get any instalation instructions with it.
                  So why not just use your pc to burn cd's?
                    master hoarder
                    • May 2008
                    • 12170
                    Re: Philips cdr-765
                    From my understanding of the OP's description, he is using this CD-R deck to record directly from reel-to-reel or another music CD directly to a CD-R/CD-RW disc.
                    Yes, you can do all that through a computer (for the reel-to-reel recording, you just feed the audio through the line-in jack and use recording software), but I can understand where there are cases where it is more convenient to just use the CD deck to do all that.
                    In any case, I am all for ripping out DRM software and hardware out of my equipment when it is easily possible. Stupid things like this make me feel zero sympathy for the recording industry. When they learn to have more sensible DRM ideas, the whole "piracy" community may become more sensible as well.
                      • 31010
                      Re: Philips cdr-765
                      if you hunt, you may find the modchip code or hacked firmware - it's pretty obsolete afterall.
                      • hasefroch
                        • Apr 2013
                        • 42
                        • Argentina
                        Re: Philips cdr-765
                        IIRC, these recorders were modded adding a switch to open and close the cd tray without using the 'eject' key. Then, you needed one music cd or cdrw 'officialy' accepted , put it in, close the tray. When the recorder is ready, you open the tray with your switch and replace that cd for a cheap / standard one, close the tray (again with your added switch) and done!
                        Most of those recorders verified the kind of media when closing the tray, not before starting to record, so that leave margin to fool it changing the disc.
                          • 31010
                          Re: Philips cdr-765
                          that wont work.
                          the laser will only focus on the first disk.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Re: Philips cdr-765
                            I have a CD player that does not like these "newer" CD-Rs that are mostly silvery with a slight green-blue tinge. Nor the gray CD-RWs.
                            However the really old dark azo-blue dye CDRs it has no problems playing them.
                            Probably a different problem, but just my observations with different colored discs. I also might have to try burning on a different burner to rule that out, though the silvery cdrs work on other players.
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              Re: Philips cdr-765
                              is that a funai built unit?
                              if so i remember an undocumented menu that could disable that.
                              the dvd units simply show options and a you should not be here message.
                              the menu on the cd is cryptic but it should be searchable .
                              apex had the same trick.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                Re: Philips cdr-765
                                This thing will play any cd or cdr/rw. It will only record on cdrw or the very hard to get blue backed audio cd-r discs.
                                • G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                  by G33RT
                                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                  It does power up when pressing the power button.
                                  I already try the power button while plugin the plug with no result.
                                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                  Could this be an PSU or eMMC issue ?
                                  07-19-2025, 03:43 AM
                                • aidanmo
                                  Philips 43PUS7506/12 - Loud blown out sound
                                  by aidanmo
                                  I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                  I thought maybe the speakers got damaged, so I replaced them - no dice.
                                  • Using the internal speakers, it always happens.
                                  • Using the headphone jack, it never happens.
                                  • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                  02-28-2025, 03:13 PM
                                • Cornito
                                  Philips 50PUH6400 bad color and gosting / slow motion on one side
                                  by Cornito
                                  Hello Team,
                                  New issue on LCD panel where I need to find out the cause and the potential solution.
                                  This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                  I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                  When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                  I've checked voltages, no issue found comparing right and left side of the panel driver.
                                  VHG VGL CKV... are the sames on...
                                  03-08-2024, 06:41 AM
                                • spantor
                                  Activate power board Philips 40PFH40009/88 tv
                                  by spantor
                                  Hello partners.
                                  Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                  The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                  02-11-2024, 05:07 PM
                                • tuner2000i
                                  Philips 65PUS8518/12 distorted image after main board replacement
                                  by tuner2000i
                                  hello everyone,
                                  I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                  The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                  07-15-2025, 01:15 PM
