who's up for an experiment?
    • 31111
    it seems to me that the thing about audio caps is pretty unsettled.
    it also seems to me that it's easy to settle.
    does anybody have a scope and a frequency generator that can sweep a sinewave from 15Hz to 20KHz ?
    the idea is to slowly sweep through the audio frequency range with a cap between the generator and scope to see how much distortion and signal loss is incurred across the sweep.
    i know they arent uniform across the range, but we are looking for a relativly flat response.
    and i am wondering how well a poly would work as an audio dc-blocker - because i'v not seen anybody try with poly's before!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: who's up for an experiment?
    If only I could read in the waveforms from my DSO... my crappy DDS can be computer controlled...
    However I think it'd be more than just the cap. The input impedance of the scope is typically 1M but amplifiers do not usually have it as high...
      Lots of info out there, just need to find the time to validate it.
      http://sound.westhost.com/articles/capacitors.htm
      You also need the equipment that can check the distortion easily.
      http://conradhoffman.com/cap_measurements_100606.html
      https://cdn.badcaps-static.com/pdfs/...578c335e37.pdf
      https://linearaudio.nl/cyril-bateman...sound-articles
      http://www.reliablecapacitors.com/pickcap.htm
      https://www.youtube.com/watch?v=xfAgOdOrJ1c
      • Khron
        • Sep 2006
        • 1350
        • Finland
        That's no biggie - just add a 10k or something, in parallel with the scope input
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • 31111
          i really am seriously curious about using poly's - the esr is next to nothing - i wonder how flat it is though?
          • montemcguire
            • Mar 2015
            • 15
            The typical distortion of a capacitor itself is really low, well below 1 part per million even with a faulty cap. Better caps are on the order of dozens of parts per billion - essentially residual for some of the best distortion measurement setups.
            So, an oscilloscope, or even a plain-jane spectrum analyzer is pretty much useless - there is no way at all to resolve distortion on this scale. The best analyzers, e.g. an Audio Precision APx-555, can measure the distortion of faulty caps, but you still have to scrape the residual of the machine. Pricey gear though, but it does work!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              One could say that tube vs transistor is pretty unsettled but people already settled it the way they feel like, anyway, despite much lower THD in one...
                • 31111
                it's not a matter of distortion, it's about checking the amount the signal exiting the cap rises and falls as you sweep through the frequency range.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Which is determined by XC (in series with the feed/source) and load impedance.
                  Even a 1u cap will be flat from 10Hz to 20+ kHz into that 1meg scope input.
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • Logistics
                    • Apr 2007
                    • 721
                    This is one of those topics which always comes down to very core facts: Everyone hears differently, and no matter what math on paper tell you, (which is that a properly functioning capacitor should not sound different than another) in actual practice, capacitors of different materials sound different. I've seen it first-hand by replacing electrolytics in the signal path of my sound-cards with new, low-impedance electrolytics, bipolar electrolytic, and finally, film capacitors. And film capacitors are hand-down superior sounding to any electrolytic.
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      STJ ; Someone should start the experimenting ..from somewhere , and here , it's you the starter ..
                      By the way i never seen big size polymers , but i'll assume there should be , at very high prices , right ?
                        • 31111
                        i dont have the equipment - i do digital work.
                        as for big poly's - i know you can get 2000uf because i used one to upgrade a motherboard the other day.
                        https://www.rapidonline.com/w-rth-pt...0x12-5-61-2954
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          Me too , due to lot of projected projects ..
                          Imagine a motherboard fully polymer ! , or even an Amp with 4700mf polymers, that would be something .
                          Thanks man .
                          • Logistics
                            • Apr 2007
                            • 721
                            So much easier to just complete the experiment by installing said polymers, and giving it a listen. In my opinion, most people who worry about "distortion" are listening on gear that has much more to worry about than distortion. But I believe this is because people mistakenly conclude that if their music sounds like crap, on their current listening setup, it must be due to distortion.
                            While a polymer cap may bring something beneficial to the table which a normal electrolytic will not, it's still not the correct solution for audio.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              Before you go all crazy on capacitor tests for audio, remember the RECORDINGS that you are listening to have been done thru a mixing console where they went thru 10s if not 100s of electrolytic capacitors. Just some food for thought. I will not even go thru the whole mixing/mastering process when sometimes distortion is added intentionally to "color" the mix.
                              A working TV? How boring!
                              • repair-it
                                Need advice testing a samsung power supply board with scope
                                by repair-it
                                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                07-12-2025, 11:00 AM
                              • Dannyx
                                Wind generator charger schematics (or load of baloney ?)
                                by Dannyx
                                Good day folks. A former colleague of mine recommended me to a relative of his and I got to speak to this man today in person. He's a bit of a mad scientist/tinkerer sort-of guy - just my kind of weirdo Apparently this chap builds all sorts of generators and wind turbines in his little shop at home and sells them here and there. He even showed me some footage of some of his inventions in action out in the field. However, as he himself very kindly put it, he's not good with electronics - he just designs and builds the generators (from scratch, I might add) and turns to others for the electronic...
                                09-16-2022, 11:13 AM
                              • PM5K
                                Inverter Generator Repair
                                by PM5K
                                I have an inverter generator that has two bad caps. One blew and the other was swollen.
                                My main issue is that the power supply
                                is encased in some type of epoxy.
                                My main concerns are regarding the epoxy and its purpose. I can imagine that it helps with vibration should I also be concerned with sparks since it's a gasoline generator?
                                The plan is to break off the old caps, cut the old legs off, clear out the solder points, then solder from the top since I cant get to the backside of the board.
                                This means that the legs of the caps...
                                01-13-2023, 03:15 PM
                              • EasyGoing1
                                Reading input and output of bridge rectifier on the same scope?
                                by EasyGoing1
                                I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                06-26-2022, 12:52 AM
                                Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
                                I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
                                https://www.aliexpress.us/item/32568...3333736563%21s...
                                04-12-2025, 10:24 PM
