Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
    • Jul 2011
    • 6070
    I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
    https://www.aliexpress.us/item/32568...Cquery_from%3A
    • 31269
    thats a lot of money for 70MHz and only 2 channels.
    i would rather spend more and get a Rygol DH814 and soft-patch it to 250MHz if i didnt already have 6 scopes
      • Jul 2011
      • 6070
      I have several requirements
      Must be battery operated
      Must have data logging capability
      Must be displayable on a iPad for slightly bigger screen
      One reason I like Hantek products in this series of enclosures there is no screen to break yes you can break the screen on an iPad but I have a protective case for all of my iPads and I have several times drop one and the case protected if from breaking
      I watch a tear down of one of there scope unfortunately it was not the model that has the Bluetooth capability but the board a has a space for it and the person doing the review made the comment that he thought it was very well made he also made the a comment about how the battery cells had individual battery management for each battery cell which there were two of them in parallel
      Which would give you long battery life in running time and longevity in the long run if done properly in the beginning
      Can you make a compelling reason for having 4 channels on a scope and what would you this capability for
      I would agree with you that this seems to be a little bit expensive than it should be but is it really that much more expensive for what you are getting
        • 31269
        the rigol DH series is usb-c powered and has usb and ethernet that can send the data to a pc or other device.
        it has a 7inch screen and i think a hdmi output for slave display.
        and it's got 4 channels.
        https://www.youtube.com/watch?v=S8jrpCoZyx8
          • Jul 2011
          • 6070
          I looked at it but I really do not want to spend nearly $400.00 for one I watch his review of this scope but it also has limitations as well so I might be a little confused about what features I really do need they also have one that is primarily used in the automotive industry I going to look at this one as well I will post a link to some time this week
          I just looked at the Hantek automotive scope and it quite a few limitations as well so I really do not know what direction to go in I want something to be able to troubleshoot switching power supplies and buss system and things like this and not sure what else I want to be able to troubleshoot as well
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Damn...really should get a more modern scope. Now have three old CRT Teks (one is ancient DSO). Then what to do with the Teks...
              • 31269
              you keep the tek's
              crt scopes have good uses - like X-Y mode
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                AFAIK nowadays X-Y mode is only good for oscillofun.wav... Think I'd rather want a lighter weight scope with better storage depth... and the money to buy one.
                • GeirAndersen
                  iPad .pcb file collection
                  by GeirAndersen
                  I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                  Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                  IPAD COLLECTION 1
                  +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                  +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                  +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                  +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                  +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                  +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                  12-09-2024, 09:28 AM
                • grimacelord
                  Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
                  by grimacelord
                  Hello.
                  Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
                  If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
                  For example, when I connect the iPad to...
                  04-15-2022, 11:06 AM
                • trepachka
                  iPad Air A1475 Boot loops after replacing battery
                  by trepachka
                  This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                  The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                  I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                  11-08-2024, 03:17 PM
                • ipatch
                  ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                  by ipatch
                  i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                  08-24-2024, 02:36 PM
                • repair-it
                  Need advice testing a samsung power supply board with scope
                  by repair-it
                  I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                  07-12-2025, 11:00 AM
