Need Help with this Circuit Please
  • rievax_60
    • May 2012
    • 897
    • australia
    #101
    Re: Need Help with this Circuit Please
    That's right. I would set it very low on that amplifier. Try to set it to 2mv across the total emitter resistance. The main reason is to check that it isn't too high. Just need to be very careful with the meter probe to not slip and short out something.
      Typical idling current on the output transistor is about 15~20mA. What is the Emitter resistor value?
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Bud M is that set at a current just below turn on of the transistor or just after turn on?
          http://sound.westhost.com/articles/amp-classes.htm
          15~20mA are what I see in most service manuals for setting up the idling current to reduce crossover distortion. You can see it on the scope.
          http://www.eetimes.com/document.asp?doc_id=1274880
          • rievax_60
            • May 2012
            • 897
            • australia
            #105
            This amplifier is unusual. The drive transistor collectors are fed by resistors from the main rails. The manual explains how this provides short circuit protection at low output levels.
            It's odd that the manual doesn't seem to mention setting the idle current.
            The idle current should be set lower than usual on this amplifier. Under 10ma.
            I worked on an old Pioneer model that had no idle current adjustment. The idle current was set to zero but with the BE voltage set to almost turning on. It sounded fine.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Is this with a AB amplifier? I know from memory in an AB amp one wants to keep the amp on the verge of turning on. As I remember vaguely to turn off a transistor before one turns on in their crossover frequencies and yet have them on the verge of turning on so there is no delay in the turn on time which would eliminate dead frequencies response at the crossover point. I actually studied this online a couple years ago on Analog Devices Courses. They actually use to test you and you would get feedback as to how you did and if you passed and were OK to go on to the next level, but like with all things I study like this I forget almost as fast as I learned it. I guess I will assume that the 15 to 20 mA are on bipolar transistors in a AB push pull, is the E current, E= B +C current or virtually C current, on the verge of turning on the transistor out of is Knee region.
              • rievax_60
                • May 2012
                • 897
                • australia
                #107
                What ever the idle current should be, it is more important that it should be checked. Not a good idea to put an amplifier into service in an unknown state.
                That is an informative link, http://sound.westhost.com/articles/amp-classes.htm
                I met a very unusual design of output stage lately, Yamaha's floating balanced amplifier,
                • tfs2015
                  • Feb 2015
                  • 135
                  Everything is working good except for a popping sound is heard when the unit is powered down and I cannot figure out why any help would be greatly appreciated
                  Computer and Small electronics troubleshooting and repair
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    I have heard of this before can't remember the cause. You might take a DC voltage reading from the Speaker L to speaker ground same for the right speaker. There should be near O volts DC. The other thing might be the bounce of voltage when you turn off the switch. You might be able to check this by just unplugging the power cable when the amp is on and see if the amp pops. Just remember to turn the switch off before you plug it back in. It should not really matter just good practice, I think.
                      It sounds like the preamp section shuts down before the power amp section.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Question, are you also saying that the power amp is shutting down to fast? I'm I wrong to think that there is some DC charge that is collapsing through the speaker?
                          When you have preamp and power amp, the proper way to shut down the system is to turn off the power amp first then the preamp, on boot up mode the preamp should be on first and then the power amp.
                          That is one of the reason you can hear a thump, but you can easily verify that by grounding the input of the power amp and see if the thump is still present, if it is still there then he will need to look in the power amp section, if it is not there then he will have to look at the preamp section. He should also look with the scope to see how big the amplitude is going into the speaker.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            So there you go follow BudM's instructions. Let us know your results.
                            • tfs2015
                              • Feb 2015
                              • 135
                              Ok when I turn the power switch on both the mixer and the power amp receive power at the same time, so all I can do is ground the input of power amp to see if it makes that same noise. If I remember correctly if I unplug the reverb board power that sound that is heard when turning the power switch to the unit off is not heard anymore but I need to confirm that and I will let you know.
                                http://www.prosoundweb.com/article/t...er_sequencing/
                                http://www.behindthemixer.com/pow-po...e-right-order/
                                http://www.sweetwater.com/insync/pow...-off-sequence/
                                http://www.longbeachindependent.com/...-sound-system/
                                You should have power sequencer.
                                  Page 8 of the user manual.
                                  POWERING UP
                                  Turn the Power Switch to the ON position. The Power
                                  LED will illuminate green and the system will turn on. If
                                  other powered equipment is to be attached to the system,
                                  it is always advisable to turn on your Passport last. In this
                                  way any transient spikes and thumps caused by other
                                  equipment will not be amplified and sent to your system
                                  speakers. For the same reasons it is advisable to turn off
                                  your Passport system first before turning off the attached
                                  equipment.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Seems a pretty convincing argument. I just wonder why they would not make it so there is no chance of this happening, no matter what was power up or down at any sequence. You know that some guitar players are not even going to read the manuals of the amp they are just going to use them. This would really be the case if they have a few drinks in them. Then they will wonder what went wrong with there amp and figured it is just cheap equipment and go down the street and pick up another amp. Seems the manufacturer would make it so this does not happen so there names would not be cursed at.
                                    • tfs2015
                                      • Feb 2015
                                      • 135
                                      If I just turn on the Passport with no input going to it and then turn it back off, it is still making that sound through the speakers. If I unplug the Reverb board power and then shut down I don't hear that sound through the speakers. I notice that with my car amps when you shut them off, they turn off nice and quiet with no noise from the speakers.
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        Perhaps some leaky (electrically leaky, not physically) DC blocking caps north of or in the reverb unit.
                                          is the reverb unit a stand alone with its own AC power? is the output of the reverb unit feeding the the power amp inputs.
                                          Lots of good pro audio processing equipment will have Muting transistor or relay on the audio line out so when power is shutdown the output will be disengaged, power amp will also have speaker protection relay that will disconnect the speaker when power is turned off.
                                            HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                            09-12-2024, 02:00 PM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • SluggerB
                                            Help with trying to fix phone that is not charging (Pics inside)
                                            by SluggerB
                                            I have two TCL A30 phones.
                                            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                            New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                            08-12-2024, 08:11 AM
                                          • Tarot Superstars
                                            Short Circuit tester
                                            by Tarot Superstars
                                            Hello.
                                            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                            Link
                                            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                            https://www.youtube.com/watch?v=0eixDdCpiO4
                                            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                            09-25-2023, 09:11 AM
                                          • Alimash
                                            op amp circuit function?
                                            by Alimash
                                            I am repairing a ups which doesn't turn on ,it has the following ICs:
                                            SG3525 used to drive inverter mosfets.
                                            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                            A LM358 and TL074 for control mechanism and of course the uController.
                                            The SG3525 is shutting down every time the ups is turned on.
                                            I want your help to know the function of LM358 and TL074 in the system.
                                            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                            07-31-2025, 07:45 AM
