Need Help with this Circuit Please
    • 30979
    Re: Need Help with this Circuit Please
    well, nothing a couple of jump-wires wont fix.
    • tfs2015
      • Feb 2015
      • 135
      Originally posted by budm
      You just feed the DCV directly to the two main filter caps. Your amp has SMPS power supply or linear power supply?
      The whole PA system uses a SMPS Power supply to supply +/- 15vdc to the mixer and +/- 52vdc to the amplifier section. Going into the amplifier section is a Red Wire that is +52vdc and blue wire for -52vdc and two black wires that provide a return(ground) back to the SMPS. The odd thing is once the two black wires are connected to the amplifier section they are electrically connected together to from one 0V ground wire. You can see this on page 25 of the service manual.
      If there was a way I could get this voltage dropped to +/- 40vdc then I could just use a Amp boards from Sure electronics, or one of the other many designs that are available but with +/- 52 vdc I am kind of stuck on what to do.
      Computer and Small electronics troubleshooting and repair
        Which post has the link to your unit service manual? Post 17 diagram matches your board?
        Modifying the SMPS to drop 52V to around 40V may not be practical (feedback circuit will have to be modified) but can be done, if you drop the 52V to 40 the +/- 15V will also drop by the about the same percentage, 11.5V which mat be still enough to run the OPAMPS..
        Notes from FENDER about the power supply: page 7, it is not tightly regulated for powering the power amp section, so it does not look like it monitors the output to maintain 51V, only monitors it for protection if it gets too low. 52V to 36V is about 30% drops.
        The SMPSU incorporates several protection circuits other than the fuses, including over current protection in which
        the unit will shut down and the protect LED will light and must be reset with the main power switch. Secondly, the
        unit will protect itself if the voltage on the rails sags to below ±33V dc after which it will go into protect mode. The
        reason for this is that during normal operation with 8 ohm loading, the rails will remain at about ±48V dc and with 4
        ohm loading are allowed by design to sag to around 36V at full output. If loads lower than this are applied, either
        the rails will sag lower or the current will be exceeded and the unit will go into the protection mode. The protection
        PCB connected to the amplifier board serves this purpose.
        • tfs2015
          • Feb 2015
          • 135
          So After reading all of this information that you posted, am I stuck with trying to repair the board? Btw there is some sort of glue all over the bottom of it. I have up loaded some more pictures of the bottom and top sides of the board.
          Tom
            • 30979
            glue?
            • tfs2015
              • Feb 2015
              • 135
              ok, maybe not glue, some sort of protective coating I guess.
                • 30979
                you mean the blue coating?
                  Blue solder mask?
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    So the blue solder mask will not prevent you from desoldering the solder. It looks like you have plated throw holes for the components to go in. That is the metal of the hole is all the way through the board and there is a solder pad on each side. This is a good thing. If somehow when you pulled up the components you ripped the trace to the solder pad you can gently scrap off the blue solder mask to expose the trace underneath. You would use an X-acto knife to scrap the blue solder mask, but gently. Then if the trace is close to the solder pad you can use a bare wire about the same diameter as the trace/run. Bend the wire to go throw the hole and enough on top to go to the trace/run. If you are using flux core solder you would clean your iron then tin it place it beside the wire and heat everything together and apply solder. Watch carefully as you do this making sure the wire says in place. Sometimes the wire has a tenancy to stick to the iron. You can kind of roll the iron off to one end if that happens or get some hemostats and clamp it in the middle and solder each end separately. I use to use lacquer red nail polish to then cover the exposed run and jumper back up, by not on the solder pad. I do not know what they use now one of these guys will tell you.
                    • tfs2015
                      • Feb 2015
                      • 135
                      If I remove all of the power transistors from the board I should still be able to test it to see if the rest of it is working OK, right?
                        • 30979
                        depends what you have to test it with.
                        • tfs2015
                          • Feb 2015
                          • 135
                          I would test it by hooking it up to the rest of the PA system and seeing if i get output from the board to the speakers using a input signal from the mixer section. The only thing that I am worried about is burning out the emitter resistors or one of the other components. I can only test the one side because the Left channel bias VR needs to be replaced.
                            I would ALWAYS check to see if you have DCV >1V at the speaker terminals fist before hooking up any speakers or dummy loads to the speaker terminals.
                              • 30979
                              no output transistors = no output.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                So do we have a schematic of this board? Could always test it with a bed of nails if you could afford to by one and then program it to test that board.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  The service manual was uploaded earlier, but here it is again for those who don't wish to become forum members just to see it:
                                  http://music-electronics-forum.com/a..._pd_250_sm.zip
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #57
                                    With the power transistors removed, the rest of the circuit should still actively balance the output to zero volts if all is well.
                                      • 30979
                                      the output to the power-transistor base pins.
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        So let me understand this a little more. What have we establish with the voltages on the power supply? What do we have and what don't we have? Have you read the Theory of Operation and did you do the preliminary test before you opened up the unit? Also, did you verify the updates to make sure the amplifier is running as smooth as can be?
                                        • tfs2015
                                          • Feb 2015
                                          • 135
                                          I updated the components that needed to be updated and reinstalled the power transistors on the right side of the amp and went to power it up and when I did power it up the BD140 transistor Q229 went up in smoke but i don't know why, so I need some help to figure this out.
                                          Tom S.
                                            HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                            This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                            09-12-2024, 02:00 PM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
                                          • SluggerB
                                            Help with trying to fix phone that is not charging (Pics inside)
                                            by SluggerB
                                            I have two TCL A30 phones.
                                            Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                            New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                            My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                            08-12-2024, 08:11 AM
                                          • Tarot Superstars
                                            Short Circuit tester
                                            by Tarot Superstars
                                            Hello.
                                            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                            Link
                                            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                            https://www.youtube.com/watch?v=0eixDdCpiO4
                                            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                            09-25-2023, 09:11 AM
