HIFONICS ZXi 1008 car amp has output on one channel only
  • tfs2015
    • Feb 2015
    • 135
    Dear Forum Members,
    I have the above listed amp that a friend of mine dropped off for me to look at. He said that only one channel of the two had output signal to speakers. I tested the amp and found this to be the case. I don't have a schematic for this amp so I am a little at a loss here.
    Things I have checked so far:
    I Got +40, -40 volts dc on the supply rail to the output transistors which are C4467 and A1694
    The op amps are MJM4588L's. I can't find a pin out for these to tell if any of them are bad.
    If I am understanding the supply rail voltage correctly then the power supply part of the amp is functioning OK.
    Any help would be greatly appreciated.
    Tom
    Computer and Small electronics troubleshooting and repair
  • tfs2015
    • Feb 2015
    • 135
    Re: HIFONICS ZXi 1008 car amp has output on one channel only
    I made a mistake op amps are 4558L
    • diif
      • Feb 2014
      • 6978
      • England
      This should be the datasheet.
      • tfs2015
        • Feb 2015
        • 135
        Thank you.
        A friend of mine made the suggestion to me that one of the inputs is not being grounded properly, but without a schematic I don't believe there is a way I can test this. So any help would be greatly appreciated.
        Tom
        • diif
          • Feb 2014
          • 6978
          • England
          Check for shorts, check the voltage going in, you have the good side to compare against.
            • 31288
            how about some inside foto's?
            • tfs2015
              • Feb 2015
              • 135
              Here are some photos of the component side of the board. looks like the photos got rotated 180 degrees for some reason
              • tfs2015
                • Feb 2015
                • 135
                can someone tell me how to upload photos without them getting rotated 180 degrees?
                  • 31288
                  they arent rotated by the forum, that's your photo's!!
                    • 31288
                    o.k. car unit - parallel output design.
                    you need to resolder all those big white resistors that burned the board,
                    you need to check all the BIG transistors for shorts between the 3 legs.
                    and you need to check all the gray resistors with a meter.
                    i assume you have a meter & know the colour codes?
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      Use a graphic editor and rotate the pics, save and then upload.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Windows photo viewer will rotate the photos, open the photo, click the rotate right or left icon then close the viewer. The rotated photo is saved automatically.
                          • 31288
                          better yet, dont hold the camera at that angle when you take foto's
                          i'll assume it was a smartfone with a gyro in it - some of those re-orientate the image based on the angle of the fone.
                          • tfs2015
                            • Feb 2015
                            • 135
                            That black stuff around the resistors is a coating of some kind
                            • tfs2015
                              • Feb 2015
                              • 135
                              I can trace the audio signal out of the op amps after that I am not sure where it goes. I wish I knew how to turn my computer into an o scope so that I can see the input and output signals better. I appreciate all the help I can get to get this working for my friend.
                              • tfs2015
                                • Feb 2015
                                • 135
                                Am I going to have to pull all the power transistors off of the board to test them?
                                  • 31288
                                  not unless you detect a short in more than one
                                  • tfs2015
                                    • Feb 2015
                                    • 135
                                    All I am able to tell is that there is rail voltage getting to them but I. Am not getting any out from them and no shorts across the legs. Could a bad ground be causing no output from the big white resistors on the board?
                                      • 31288
                                      no.
                                      are any outputs shorted to ground?
                                      btw - have you got an esr meter?
                                      • tfs2015
                                        • Feb 2015
                                        • 135
                                        no I don't have an esr meter and no none of the outputs are shorted to ground. I did find if I turn the input up to a real high level that I can get just a little bit of output on the bad channel but the power transistors on the bad channel never warm up.
                                        • FrancescoV
                                          Onkyo HT-R390 no sound output, video output ok
                                          by FrancescoV
                                          Good morning everyone,
                                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                          The firmware reported is the following:
                                          M:1.00/11107BLP
                                          D:?.??/????????
                                          O:1.00/11107AL
                                          The DSP firmware given the question marks seems corrupt.
                                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                          05-11-2025, 02:59 AM
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • afminguela
                                          No signal right output master channel - TRAKTOR KONTROL S4 MK1
                                          by afminguela
                                          HI,
                                          i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
                                          One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
                                          i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
                                          and I concluded that is a hardware issue.
                                          As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
                                          Does...
                                          05-11-2023, 05:58 AM
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
