Harman/Kardon Onyx Bluetooth Speaker - No Power
  • caphair
    • Nov 2011
    • 1249
    Had this speaker for a year and it recently stopped powering on.
    Tested voltage output of the wall charger and its outputting correct voltage. Checked voltage from charger at the circuit board connector and the voltage is making its way there.
    Anyone know anything about these or the issue, or what steps I could take next?
    • 31044
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    foto's ?
    • caphair
      • Nov 2011
      • 1249
      Let me know if you need any more/specifics. Left black connector is 19v dc from the charger, the right white connector is what the battery plugs into.
      The battery is rated at 3.7v 2600mah and it seems full at 4.1v
      I'm curious isn't the charger at an output of 19v overkill for it? Or is that meant to charge it faster?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4958
        • New Zealand
        19v would be overkill (literally!) if it were connected straight to the battery but there will be some voltage step-down circuitry and a charge management circuit somewhere in between the two. There is likely also a boost converter somewhere for when it's running off battery.
        Doesn't look like there's a schematic anywhere so you'll have to do this the hard way...
        I see several possible DC-DC converter circuits there.
        One based around U702 and Q701
        Another based on U700,
        Another on U600.
        Another circuit based on U701 and Q700 it seems too.
        You will need to investigate all these and ensure they are all working. Checking voltage rails is the first thing to do when something doesn't work.
        Post part numbers on all those chips if you aren't sure what they're doing.
        I do see what might be a hole blown in Q701. You should inspect that more carefully.
        U400 is probably a microcontroller to control everything.
        The Audio Amps will be under the heatsinks. Class D ones going by all the output inductors.
        -David VanHorn
        • caphair
          • Nov 2011
          • 1249
          @Agent thank you I'll take a look later when I'm at home.
          This unit turns on by a push button that needs to be held in for 3 seconds. Not sure if that bit helps but I've always wondered exactly how buttons like that work.
          I'm curious about what you said here:
          "19v would be overkill (literally!) if it were connected straight to the battery but there will be some voltage step-down circuitry and a charge management circuit somewhere in between the two. There is likely also a boost converter somewhere for when it's running off battery."
          What's the point in all that rather than just using say a 5v charger connected more directly to the battery like in most other electronics? Why step it down, etc with added circuitry?
            • 31044
            when you lower the voltage the current increases.
            also, 19v supplies are easy to get from laptop makers.
            • caphair
              • Nov 2011
              • 1249
              Oh right. Nice.
              If I'm to do voltage tests on those rails would voltage be present with it off or is it a thing where I need to try powering on while measuring?
                • 31044
                well you need voltage to test for it
                • caphair
                  • Nov 2011
                  • 1249
                  Lol I wasn't sure if there'd be standby voltage at input pins regardless if it's on or not
                    • 31044
                    check what this black mark is!
                    • dj_ricoh
                      • 2073
                      i got a nude L speaker and i took out the charging board and i use a 3.8v adapter and connected straight to the battery socket and left the battery there.
                      its running like this for half a year
                      sad part its when its charges the battery to full i have to shut it down because it goes in protection mode and stops the bluetooth.
                      the only way you can test is to go to the battery straight.
                      then trace back that charging
                      • caphair
                        • Nov 2011
                        • 1249
                        I believe it's charging fine the battery had a full charge. I even tried connecting external 4v from a dc power supply to the battery terminals on the board and it still wouldn't power up.
                        • caphair
                          • Nov 2011
                          • 1249
                          Just examined it closer, it's just a symbol not a burn mark.
                          There are two power connections labeled "power button a" and "b" one is high at 4.1v that drops to 3.8v when pressed and the other becomes high at 4.1v. But as soon as power button is released the values go back.
                            • 31044
                            the other becomes high at 4.1v ??
                            • caphair
                              • Nov 2011
                              • 1249
                              Oops! The other goes high from 0v to 3.8v
                              There's a 3.3v line on the power/volume controller board that gets 3.26v when power button pressed and even the power led goes high to 1.2v
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4958
                                • New Zealand
                                The button is just a normal button. The microcontroller or such would wait for you to hold it for 3 seconds before triggering the power-on sequence.
                                -David VanHorn
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  Ok thanks. So with the tests I've just conducted, where should I go from here? Is it a mcu issue? When the power "a" is high and power "b" low at 0v and I press and hold power button "a" goes from 4.1 to 3.8v and then "b" goes from 0v to 3.8v
                                  Shouldn't "a" go to 0v when it's powered on? Rather than both being at 3.8v
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4958
                                    • New Zealand
                                    Not necessarily. There are many ways to detect a switch press, and we don't know the exact circuitry involved here.
                                    Do you know where the power button connects to physically? Is it across Points A and B, or something else?
                                    -David VanHorn
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      I did a continuity test and seems one leg of the switch connects to power "a" and another leg of the switch connects to power "b"
                                      Is that what you meant?
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Also when I tried powering with a power supply set to 4.1v across battery terminals on the board, at first initial pressing of the power switch it draws 334ma then drops to 30ma with power button still being pressed
                                        • funky2x
                                          Harman kardon onyx studio 7 Smd code
                                          by funky2x
                                          Cant find what smd code Y0DVA.
                                          sitting in Harman kardon onyx studio 7. Appreciate any help.
                                          05-29-2025, 03:44 PM
                                        • dorfman
                                          Dell Harman Kardon Dead Left Speaker
                                          by dorfman
                                          Working on an early 2000s dell / harman kardon computer speakers.
                                          Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
                                          I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted...
                                          09-03-2022, 05:39 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • magneh
                                          Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
                                          by magneh
                                          Hi
                                          Long story short, Harman Kardon Aura Studio 2 speaker, no power.
                                          Disassembled, found burned IC, maybe the 5V regulator? not sure
                                          No schematics
                                          IC marking: 225S2 (see pic)
                                          Board ref: 40-KS320U-PSK2G
                                          Thanks for any help!...
                                          09-16-2021, 08:41 AM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
