Cement resistor swap in Harman Kardon AVR
  • PowellSkier
    • Jun 2024
    • US
    Would I be able to swap a 0.27 Ohm Kx2 5W resistor for a 0.22 Ohm Jx2 5W resistor in a Harman/Kardon AVR? Cement type.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    If you really have nothing else, yeah you probably can. Due to ambiguity in the English language you could either lose a bit of speaker protection or power output.
      • 31262
      make sure you dont replace a metal oxide ceramic with a wirewound ceramic!
      • PowellSkier
        • Jun 2024
        • US
        Nope, just the big white sign-post looking thing, with 3 legs.
        • R_J
          • Jun 2012
          • 9610
          That is likely the dual emitter resistor, it may upset the output if you only replace the one section, and it should be with the correct value
          • PowellSkier
            Harman/Kardon AVR 645 returning to stand-by after a few seconds.
            by PowellSkier
            A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
            06-17-2024, 11:43 AM
          • funky2x
            Harman kardon onyx studio 7 Smd code
            by funky2x
            Cant find what smd code Y0DVA.
            sitting in Harman kardon onyx studio 7. Appreciate any help.
            05-29-2025, 03:44 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • mikey5791
            by mikey5791
            Hi to all forum members,
            12-26-2024, 04:55 AM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
