Harman/Kardon Onyx Bluetooth Speaker - No Power
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    https://www.badcaps.net/forum/attach...8&d=1490813608
    Check the RESISTANCE between the two legs of C713 (the smallest cap of the four caps) to see what it shows. Make sure to report if the reading is in Ohm, K Ohm, or M Ohm.
    BTW, that black carbon on the board should be removed, it is conductive.
    • pluton23
      • Mar 2017
      • 11
      C713 = 0.6 Ohm, but i have only usual multimeter now.
      Black carbon will be removed certainly, i have not started the repair, only wiped with alcohol.
        Well, more likely one of those 4 caps is shorted out or the IC itself. I would carefully remove hose caps one at a time to see if the shorts will go away.
        • army_wang
          • Oct 2017
          • 3
          • china
          #184
          Harman/Kardon Onyx schematic diagram
          • Agent24
            I see dead caps
            • Oct 2007
            • 5012
            • New Zealand
            #185
            Nice! Thanks
            -David VanHorn
            • svipmt
              • Jun 2016
              • 4
              I'm bad english . I have onyx studio no power . I checked board see D300 explosive and U700 short circuit . I have replace new D300,U700 and still not work ? Anybody help me fix this ? thank
              • Agent24
                I see dead caps
                • Oct 2007
                • 5012
                • New Zealand
                #187
                Are you getting 4.7v from the new U700?
                -David VanHorn
                • svipmt
                  • Jun 2016
                  • 4
                  I removed C306 and turned on ok but not charging battery . I connect apdator and remove battery and check Vbat pin is 0V
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5012
                    • New Zealand
                    #189
                    U701 is probably faulty, or C706 shorted?
                    -David VanHorn
                    • svipmt
                      • Jun 2016
                      • 4
                      I no find replace U701 IC . You can help me new solution ? . I plan to mod a extend power stepdown module for charging battery
                      • svipmt
                        • Jun 2016
                        • 4
                        Finally . I modding power charging battery by LM7805 and everything is OK . But charging battery near 8 hours when battery is very low,can't to start system :P . I'm no care because I alway using power apdater,sometime i go out to use on battery . Thank a lot
                        • Quantum IC
                          • Sep 2021
                          • 20
                          Hello everyone
                          I have the same Onyx Studio that does not turn on.
                          The BC57E687C Bluetooth chip gets warm after 1 minute with the AC adapter connected.
                          I hope youcan help me please.
                          • csabikat
                            • Jun 2023
                            • Szlovákia
                            #193
                            Hi AGENT24!
                            I have an ONYX STUDIO 4. I plugged my scooter charger into it. The charger IC is burnt out. That's all it looks like visually. I would like to fix it. Unfortunately, I can't find a plan for it anywhere. Could you help me? I can't find a service manual link either.
                            Thanks in advance
                            • csabikat
                              • Jun 2023
                              • Szlovákia
                              #194
                              Originally posted by csabikat
                              Hi AGENT24!
                              Thanks in advance
                              Hello everyone!
                              Here is the Onyx studio 4 service manual
                              • QwertyChouskie
                                • Nov 2023
                                • 4
                                I have a Onyx Studio that doesn't power on. No components look visually damaged. I noticed that BT_3.3V was only at ~3.0v, after some measuring around, I found that L600 had ~3.3v coming in but only ~3.0v going out. I bypassed it for testing with a small jumper, now BT_3.3V measures at ~3.275v, but the speaker still doesn't work. Battery is fully charged at almost exactly 4.2v. I tried removing C306 but it didn't seem to change anything. Any other ideas where to look?
                                Plugging the USB port into my laptop and running `lsusb` doesn't show the speaker, not sure if this info helps.
