Harman/Kardon Onyx Bluetooth Speaker - No Power
  • minhluanvk297
    • Feb 2016
    • viet nam
    #161
    Re: Harman/Kardon Onyx Bluetooth Speaker - No Power
    https://www.5giay.vn/threads/chuyen-...tudio.8273931/
    • pluton23
      • Mar 2017
      • 11
      Please help with the repair Harman Kardon Onyx Studio. On the main board burned out capacitors. To replace them i need to know the type and capacity. My speaker works but is not charging. If someone has good advice how to restore the speaker (and what type of capacitors inside) I would be very grateful. Thanks
        If you can give us the P/N as printed on that IC 700 then we can look at the spec sheet to see what pin 2 of that IC is for. From the look of it those caps (C7013, 712, 711, 714, 701) are filter caps connected in parallel, MLCC (Multi Layer Ceramic Capacitor, they fail in shorted out condition mode) type, C 712, 711, 714, 701 should be the same value, the C713 is probably <1 uF.
        You can remove the one that is not damaged c712 and measure the capacitance.
        You should also clean up the board so we can see the traces better.
        IC 600 looks to be the same setup.
        • pluton23
          • Mar 2017
          • 11
          if I understand correctly the question )
          S\N FC0005-0188023
          IC 6132A-ONYXST
            We need the P/N as printed on top of that IC U700
            https://www.badcaps.net/forum/attach...1&d=1490356626
            • pluton23
              • Mar 2017
              • 11
              P\N printed on main board (may be the white paper label?) or on the case?
                Please see attached picture.
                BTW, do you proper tools to do SMD repair?
                Did you clean the board yet so we can see how bad the damage is?
                • pluton23
                  • Mar 2017
                  • 11
                  Thanks a lot for your willing to help, I really appreciate it, only tomorrow will be able to write everything in details. Another problem is swollen capacitor p1352 (blue barrel to the right and "down"), it would have to change. Special tools i have not yet, I want to get information about the type of the burnt capacitors and replace it with a new (by soldering).
                    Once we get the P/N of that IC the we can find the specification sheet for the IC to find out what those caps connected to pin 2 are for then we can go further, I am sure that they are just filter caps connected in parallel.
                    And when you clean up the board to inspect the traces then we will know how bad the damage is.
                    • pluton23
                      • Mar 2017
                      • 11
                      U700 number 54331 TI 3134 ZC 83 G4
                      U600 - the same
                      I've cleaned up the board, please see attached file.
                      thanks in advance
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4919
                        • New Zealand
                        #171
                        Burnt component seems to be L701, which would imply a short circuit somewhere.
                        I also notice C633 (Big electrolytic, bottom right) is bulging.
                        U700 is a TPS54331, of which the burnt inductor would have been feeding Pin 2. Pin 2 is the input, so the U700 has probably shorted to ground and caused the burnt L701.
                        My theory then is that either:
                        1) Unit was connected to too high a voltage (at least 30v), Which blew C633 and also U700 - did you connect it to a 30v or higher supply?
                        2) C633 failed by itself, causing a supply voltage drop which meant U700 overworked and overheated, then shorted.
                        The burnt section of board will probably be conductive. You will likely have to scrape it out.
                        -David VanHorn
                        • pluton23
                          • Mar 2017
                          • 11
                          we can only guess what really happened to the speaker, I bought it already broken
                          • pluton23
                            • Mar 2017
                            • 11
                            Could you find the specification sheet about burnt capasitors' and resistors' types ? Thank you.
                              Just remove ONE of those cap as suggested earlier and check the capacitance.
                              • pluton23
                                • Mar 2017
                                • 11
                                Please tell me what is the resistor the fuse in place С701 (burnt, most damaged). In a parallel module U600 it is not (only 3 capacitors), I can't determine its type.
                                С711, С712, С713, С714 - everything is clear, but with this С701 is a mystery.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4919
                                  • New Zealand
                                  #176
                                  The burnt component is L701. It's an inductor, not a capacitor. See photos posted earlier in the thread.
                                  -David VanHorn
                                  • pluton23
                                    • Mar 2017
                                    • 11
                                    how to identify this inductor to replace it with new?
                                    соuld you send specific information about this part?
                                    thanks.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4919
                                      • New Zealand
                                      #178
                                      Unfortunately I don't know what value or properties it has.
                                      -David VanHorn
                                        So those 4 caps connected in parallel to the output side (which feed pin 2 input pin of the IC) of L701 are all OK and not shorted?
                                        I wish you will show the pictures of the board after clean up.
                                        You need to verify if there are any shorted circuit before even trying to locate the replacement inductor.
                                        • pluton23
                                          • Mar 2017
                                          • 11
                                          cleaned up board
                                          • funky2x
                                            Harman kardon onyx studio 7 Smd code
                                            by funky2x
                                            Cant find what smd code Y0DVA.
                                            sitting in Harman kardon onyx studio 7. Appreciate any help.
                                            05-29-2025, 03:44 PM
                                          • dorfman
                                            Dell Harman Kardon Dead Left Speaker
                                            by dorfman
                                            Working on an early 2000s dell / harman kardon computer speakers.
                                            Suddenly only the right speaker works. No sound is coming out of the left. Also, the right is much louder than when both speakers were working. The minimum volume setting sounds much louder than where I previously set it (half way). And the loudness difference between minimum and maximum position on the knob is small compared to when both were working.
                                            I checked the signal wire for continuity from the board to the jack. Both channels and the ground are continuous with low resistance and not shorted...
                                            09-03-2022, 05:39 AM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • magneh
                                            Harman Kardon Aura Studio 2 speaker - no power - how to identify IC?
                                            by magneh
                                            Hi
                                            Long story short, Harman Kardon Aura Studio 2 speaker, no power.
                                            Disassembled, found burned IC, maybe the 5V regulator? not sure
                                            No schematics
                                            IC marking: 225S2 (see pic)
                                            Board ref: 40-KS320U-PSK2G
                                            Thanks for any help!...
                                            09-16-2021, 08:41 AM
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
