Baofeng walkie talkie UV-16 PRO Mate not charging via usb type c.
  • thesame
    • Mar 2018
    • 141
    • Romania
    I use to charge it via type c and It stopped charging , with the usb c connected i measure 5V on the pins that are going to the battery , and on the working one i can measure 9V on the pins, after opening it i found this sot23 smd marking ACA9E burnt, and i don't know what to replace it with. Some people say it can be SY8008CAAC wich is a Synchronous Step Down Regulator others say it could be voltage detector like XC6114B545MR.
    • 31260
    it's a 2 cell battery, so logically it's a boost convertor.
    maybe next time,add a thermal pad to couple it to the metal shell
    • thesame
      • Mar 2018
      • 141
      • Romania
      So how can i find the right part to replace it?
        • 31260
        not sure,
        these codes are a pain in the ass to trace.
        can you work out where the pins go?
        • thesame
          • Mar 2018
          • 141
          • Romania
          I have removed the ic from the board so i can see the traces, with the ic on the board the small smd ( i think its a diode) under the usb port on the right it was shorted but after removing the ic its not shorted anymore. I have tryed to deliver 7v on the charging port since the walkie still works on battery and i have voltage on the diode and the capacitor under the burnt ic . I have also tested with the multimeters the pins from the ic conected to the type c port pins.
          • thesame
            • Mar 2018
            • 141
            • Romania
            I have also opened the other walkie talkie and measured the voltages on the working ic with the type c connected, i have attached it here.
              • 31260
              thats a great picture, i can draw a schematic from that!
              btw, do these radio's still have contacts on the back of the battery for a cradle like older radio's?
              • thesame
                • Mar 2018
                • 141
                • Romania
                Yep the battery can be charged in the dock also it has external contacts too, but i'm interested in chargin it in the car where i have the usb cables available, thats why i bought them in the first place for the type c port.
                  • 31260
                  well the pinout of that boost convertor is:
                  1 - output
                  2 - OC
                  3 - gnd
                  4 - FB
                  6 - V-in
                  i didnt find a match yet, it's unusual.
                  most convertors use pin2 for ground.
                  • thesame
                    • Mar 2018
                    • 141
                    • Romania
                    You ment 5 . V-in , because it has only 5 pins ? I took another picture with the coil removed.
                      • 31260
                      thats contentious.
                      technically pin5 is missing,
                      some companies call the last pin pin5 others call it pin6
                      • R_J
                        • 9607
                        FAN2500SX, has those markings I also see PAM3103 (ACAyw) but different pinout
                        None show an inductor as part of the circuit.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5083
                          • New Zealand
                          Thought I had it with the XC6367 from Torex, but the pinout is all wrong. And it uses an external transistor anyway.
                          Annoying when you don't know which part of the code is part number and which is lot/factory/date etc code.
                          If you can get your hands on (or PCB photos of) another radio the same model but different year production it may help
                          -David VanHorn
                            • 31260
                            it's a new-ish model though.
                            • CapLeaker
                              Leaking Member
                              • 8342
                              Found that too… but that doesn’t help either, lol.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5083
                                • New Zealand
                                I guess it's a new chip too that nobody's heard of yet.
                                I wonder if trawling through DC-DC converters on LCSC or something would help...
                                Why don't they just use a MC34063 if all it's doing is charging a battery not like efficiency matters in that scenario.
                                Has anyone tried asking Baofeng what chip they used? Probably they'll ignore you but who knows, maybe they'd be helpful. Lol.
                                -David VanHorn
                                • thesame
                                  • Mar 2018
                                  • 141
                                  • Romania
                                  I have tryed to contact them vi aliexpress where i bought them to ask about a schematic or a service manual , but sadly no one is answering the chat.
                                  • thesame
                                    • Mar 2018
                                    • 141
                                    • Romania
                                    Someone sugested to measure the voltage on R56 in paralel when conecting an 100 ohm rezistor on the charging pins whith the usb c connected , R56 in paralel without the 100ohm i get 0,000 v with the 100ohm resistor on the pins i get 0.058v. Then he sugested that may be a current sense rezistor that complicate the ic even more. The test was done on the working board not on the broken one.
                                      • 31260
                                      it's the overcurrent protection input (OC).
                                      probably.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5083
                                        • New Zealand
                                        Better off to contact Baofeng directly:https://www.baofengradio.com/pages/customer-service
                                        -David VanHorn
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
                                        • Scoff
                                          HP Probook 470 G4 - Power and Charging Problem
                                          by Scoff
                                          Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                          Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                          07-03-2023, 09:28 AM
                                        • SluggerB
                                          Help with trying to fix phone that is not charging (Pics inside)
                                          by SluggerB
                                          I have two TCL A30 phones.
                                          Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                          New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                          My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                          08-12-2024, 08:11 AM
                                        • Wang Tingting
                                          Acer Nitro 5 AN515-57-536Q not charging
                                          by Wang Tingting
                                          I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
                                          report is also good for battery.
                                          Following https://www.badcaps.net/forum/troubl...arging-circuit,
                                          • DCIN/VCC: 19.1
                                          • ACIN/ACDET: 3v
                                          • REGN/VDD: 6v
                                          • CMSRC : 19v
                                          • ACOK: 3.3v
                                          • ACDRV: it is 19v, not 25V(when charging, the ACDRV
                                          09-10-2025, 01:46 PM
