View Post
KENWOOD KA-701 POWERS ON, NO RELAY CLICK
Originally posted by CapLeaker View PostThese XZxxx zeners are a bit weird numbered. For example a XZ051 equals a 5.1V zener. It is NOT a 51V zener.
So what you are looking at is a XZ100 zener. That makes it a 10V. Check it out like petehall347 said above.
Originally posted by CapLeaker View PostGeez... all that is broken? Can't be.
The 1N60 is a germanium diode. It is still available for sale for example futurelec.com. Also 1N34A, BAT41,1N60P etc.
WZ series zener diodes are 0.5 Watt type. Again a WZ240 = 24V. WZ300 = 30V.
As for the plate resistors... I dunno. Are they bad?
Originally posted by CapLeaker View PostI get the germanium diodes… they can break by just using too much heat. The resistors, I'd leave alone unless they are burnt, open, or out of tolerance. Definitely change all the caps then.
Well parts came in and, most of the resistors have to be returned, so It will be another week at least before I can get started. I do have the big output transistors so I'm going to start there, then the smaller Trans. Caps will follow. At that point I should have the resistors. I will change everything around Q11, because of the short I caused. I,'LL post pics of each step. Thanks guys, and have a great weekend.
Originally posted by rccrasher65 View PostStarting on Tuesday replacing, some components. I will start with Q11, and do those 4 transistors, then the caps, followed by the 4 big output transistors. I'll post some pics as I go along.
Originally posted by CapLeaker View PostHa! You not the only one that can swear like @#$&! There are MUCH worse things than an amp! But this is just about a daily thing these days.
Just a quick check of resistors in area of Q11, Q9 found res.23 smoked, open, res1 smoked, open.most other look good so far,and testing fine, but will double check them all. My new resistors are same value as on parts list, but are considerably smaller in physical size, will this be a problem.
you mean R11 and R23. These should have the same wattage rating (size) than the old ones. I think they should be a standard 1/4w resistor. R11 should be a 3.5kohm and R23 should be 82ohm.
If you put a smaller wattage rated resistor in, it may not be able to handle the current and go "poof" or overheat.
Originally posted by CapLeaker View Postyou mean R11 and R23. These should have the same wattage rating (size) than the old ones. I think they should be a standard 1/4w resistor. R11 should be a 3.5kohm and R23 should be 82ohm.
