KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 619
    I think I got it see if these help I can get better now that I know what I'm doing.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      be very careful with those bias diodes that are screwed to the heat sink .the wires tend to break off right next to the body and are hard to find new ones and also not easy to fix .
      • CapLeaker
        Leaking Member
        • 8147
        I see some saaad looking resistors that are crispy. Those caps near that heat sink should be changed out too...
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          yep it needs a good old looking at and any substitute transistors carefully selecting
          • rccrasher65
            • Mar 2014
            • 619
            Can you circle what you are talking about, thanks
            • rccrasher65
              • Mar 2014
              • 619
              Can you highlight what resistors look bad, I plan on replacing, most of the components on that board anyway.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                #27
                these things
Name:	Screenshot from 2025-04-21 22-37-37.png
                • CapLeaker
                  Leaking Member
                  • 8147
                  Here! Click image for larger version
                  • rccrasher65
                    • Mar 2014
                    • 619
                    Yea,I saw those, actually they test good, but are getting replaced anyway. Thanks. Some parts are coming on Wed, this week.
                    • rccrasher65
                      • Mar 2014
                      • 619
                      these things
                      Thanks, I thought that's what you were talking about. There will be no need to touch them at all.
                      • rccrasher65
                        • Mar 2014
                        • 619
                        some transistors are arriving today! I'm going to start with the 4 big output trans. first then Q11, Q10, ect. I'm going to place an order for some new resistors, as well as new caps.
                        • rccrasher65
                          • Mar 2014
                          • 619
                          Most of my parts will arrive on Friday, I'm going to start with Q11, 10, 9 ect first, then the smaller transistors, followed by the caps on the board. For the 4 big output Transistors ,can I use arctic silver 5 thermal compound? Also, any secrets loosening the transistor screws in a tight space. 50 yrs old original never touched.
                          • CapLeaker
                            Leaking Member
                            • 8147
                            You may take the transistors with the heatsink out. Then change the transistors on the heatsink and put the new mounted transistors with the heat sink back in. Always mount the transistors first before soldering, otherwise you risk damage. I suggest you clean and replace all old thermal paste on everything that is mounted on a heat sink, as the original paste is 50 years old and hard as a rock. Use 99% alcohol to clean the thermal paste.
                            • petehall347
                              • Jan 2015
                              • 4426
                              • United Kingdom
                              #34
                              can I use arctic silver 5 thermal compound? .
                              get some proper white stuff for the job . all that arctic silver stuff is not right for amplifiers
                              • rccrasher65
                                • Mar 2014
                                • 619
                                Thanks, for the advice. So it's best to remove the whole heat sink from the unit first, then remove old transistors, replace old compound with new, and place new transistors on heat sink. I'll order some white thermal compound too.
                                • rccrasher65
                                  • Mar 2014
                                  • 619
                                  Ok, I'll give that a try, will need to order white thermal compound. THANKS
                                  • CapLeaker
                                    Leaking Member
                                    • 8147
                                    You can leave the transistors on the heatsink, you just have to desolder them first from the PCB. Then pull the heat sink with the transistors attached off the board. The important thing is you mount the transistors with the thermal paste to the heatsink first. Then solder.
                                    • rccrasher65
                                      • Mar 2014
                                      • 619
                                      Sounds good, I got them, one screw head was a little jacked up, but it came out. I'm still stumped on one diode, it's the zener diode XZ-100, kenwood part number is V11-4104-10. I have found really no answere for a replacement, just guessing it could be a 10v, not really sure, hoping someone could give it a shot in finding out an equivalent. Looking foreward to my parts all arriving on friday and Mon, at the latest.
                                      • petehall347
                                        • Jan 2015
                                        • 4426
                                        • United Kingdom
                                        #39
                                        d9 d10 is it ? remove one and use resistor and 2x 9v batteries and volt meter .
                                        • CapLeaker
                                          Leaking Member
                                          • 8147
                                          These XZxxx zeners are a bit weird numbered. For example a XZ051 equals a 5.1V zener. It is NOT a 51V zener.
                                          So what you are looking at is a XZ100 zener. That makes it a 10V. Check it out like petehall347 said above.
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • DXseekerMO
                                            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                            by DXseekerMO
                                            Hello everyone!
                                            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                            Yes
                                            0%
                                            1
                                            All backlight strips are the same quality
                                            0%
                                            1
                                            No
                                            0%
                                            0
                                            12-16-2021, 03:58 PM
                                          • malogro
                                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                            by malogro
                                            Hello all,
                                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                            Intro:
                                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                            04-14-2023, 04:44 PM
