Can these speakers be repaired?
  • Keshenatech1
    • Apr 2018
    • 149
    I was asked to look at some guitar amps by the owner of the local pawn shop. One is a Kustom model 11-L and the problem with it is "no sound". It has 2 12" speakers in parallel and I found the 1/4" jack coming from the speaker harness going into the amp measures wide open, no continuity whatsoever. At first I suspected a broken wire but the problem is on the speakers themselves. I don't know if someone vandalized it, or if it deteriorated, but both leads on both speakers coming from the cones to the terminals are severed. The leads are a very soft flexible material with cloth woven in. Before getting close to the cone with a soldering iron, I experimented with the end still on the terminal attempting to solder some stranded copper wire to it. Even with the use of extra flux and a good amount of heat from a wide chisel tip, the solder refused to bond to the lead and my copper wire fell right off. As you can see in the pictures, I only have just over 1/4" of material to work with in a couple spots. Does anyone know how to make a reliable connection to the ends of the leads or if it's even possible, or are these speakers junk?
    • 31055
    Re: Can these speakers be repaired?
    professionals can re-cone them.
    they completely replace the coil and paper parts.
    i think you can buy the parts seperatly but you need to get the coil diameter just right.
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      cut the dust covers off and solder new tinsel leads to the coil wire .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I've repaired a 5¼" (IIRC) woofer with the same problem before, it is possible, though my situation probably belongs in the "worthless repair" thread...
        Key thing is that you don't use any of the old tinsel wire, you have to get rid of all of the old tinsel wire up into the cone. Solder the new tinsel wire to the coil in the cone. and yes you need to get more tinsel wire.
        Since it was a 5¼" driver i was cheap and did not find new tinsel wire for it. Made my own homemade voice coil wire, alas I doubt it will last forever, but neither did the original tinsel wire so no big deal...
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          +1
          This would probably be the easiest solution.
          And if you don't care much about doing an ulta-proper repair, you can even forgo using new tinsel leads and just use regular stranded copper wire. Just pick one with finer strands inside so it's a little more flexible, and it will be fine. Make sure not to leave too much slack so that the wire flaps somewhere on the cone and makes ugly farting noises.
          So does mine when I "repaired" these pieces of garbage. But hey, I was curious to see how bad they would sound... and they delivered.
          I suppose many things are fixable, even if they seem like they aren't. At the end of the day, it's just down to how much time you want to spend/waste with something... and what kind of satisfaction you'd get out of it (if any.)
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Or hits the basket and shorts the amp!
            Pick your battles, buuut...
            Sometimes, that becomes the (rewarding) challenge, all in itself.
            "pokemon go... to hell!"
            EOL it...
            All style and no substance.
            guilty,guilty,guilty,guilty!
            guilty of being cheap-made!
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              also make sure you have enough slack so that the wire doesn't rip out the paper cone when the amplifier is turned up to 11 ... but that probably is why they got blown in the first place.
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                at a pinch new solder wick will work for tinsel wire ..if all else fails fit some G12 speakers .
                • tibimakai
                  • Jan 2012
                  • 3680
                  Yes, just replace the tinsel wire, found some on Ebay. I did this on a 10" Klipsch subwoofer.
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    When your solder tip isn't working well , buy some Lemon salt (very cheap) , and dip the tip head into it , in a cup . You can also mix it with Glycerine for a practical mold ..
                    Don't tell anyone I told you so ..lol ..
                    • Keshenatech1
                      • Apr 2018
                      • 149
                      I found a pair of 12" 70W guitar amp speakers on Amazon Prime for only $45. Thought that would be more cost efficient for the customer than the hours I'd spend trying to re-lead the old ones. But just one problem, they don't quite fit. Same diameter, same number of mounting holes. but won't quite fit over the 4 studs. The holes in the original speakers are larger and more oblong than the smaller round holes in the new ones. Should I attempt to file or drill them out bigger, or send them back while I still can?
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        use a round file . drilling will prove difficult unless you have a spot weld drill bit . even then it would be hit and miss lining it up .
                        • Keshenatech1
                          • Apr 2018
                          • 149
                          Thanks for the suggestion. Borrowed a round file from my tool box at work for the weekend and minimal filing I got them to fit and install. Most of the issue was just the thick gasket material covering most of the inside edges of the holes so once I got that out of the way I only had to do a little metal filing in a couple spots.
                          Now I have one further question. I'm not sure if I should continue here or start a new thread. But my original speakers as you can see in the picture are labeled 8-16 ohms. I've never seen that before. Usually a 4, 8, or 16 but not a varying range like that. My new speakers are rated at 8 ohms each so in parallel it's putting 4 ohms load on the amp. It sounds great but after about 1/2 hour of playing, it got very warm near the output transistors. If the original speakers were close to 16 ohms, I'm wondering if I should wire the new ones in series for less load on the amp. It's a 70's vintage Kustom brand model 11-L guitar amp, and I can't find any specs or documentation on it online, or have any idea if it's "normal" for those to run hot. What do you guys think?
                          • Keshenatech1
                            • Apr 2018
                            • 149
                            Update: I rewired it putting the 2 speakers in series and it still runs hot. Still sounds good too. I'm going to leave it because the static resistance of the old speakers (alligator clip leads on what's left of the lead wire) measure around 12 ohms and my new ones with the 8 ohm impedance rating measure just over 6. So I figure it's better to go a little high than too low and overload the amp. Hopefully the running hot is normal and that nothing burns out. I did read somewhere that these old amps are biased high but haven't had much experience working on them.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Happened to Garret Claridge in one of his videos trying to blow up a pair of 8" Cerwin Vega woofers.
                              This one, actually:
                              https://www.youtube.com/watch?v=sK7CO9KOgqU
                              +1
                              • alfatv
                                • Sep 2020
                                • 353
                                Turn off the volume, then
                                - Check if it's still running hot
                                - Measure DC voltage across the speakers
                                  Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                  by momaka
                                  More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                  02-15-2022, 12:43 AM
                                • goodpsusearch
                                  Speakers damaged from children. Can this tweeter be repaired?
                                  by goodpsusearch
                                  I got these speakers that seem to be damaged from the previous owners small children.
                                  As you can see on the first pic, the tweeter's outer membrane has been totally ripped.
                                  I also post another pic with the other speaker that survived...
                                  Is this beyond repair?
                                  I have no clue about soft dome tweeters.
                                  12-26-2023, 05:18 PM
                                • Widget
                                  Logitech R20 speakers - Replacing one of the speakers.
                                  by Widget
                                  Hi guys,
                                  I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                                  Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                                  Printed on the back of the Logitech speaker is;
                                  LOGITECH...
                                  05-29-2024, 07:07 AM
                                • wnlewis
                                  New wire for my RDE3340 Whirlpool electric range
                                  by wnlewis
                                  OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                  Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                  This is a Whirlpool RDE3340 electric range.
                                  The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                  Where may I find parts...
                                  01-08-2025, 11:21 PM
                                • emeskay
                                  Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                  by emeskay
                                  We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                  08-06-2024, 07:13 AM
