Microwave Issue
  • jamesmcuk
    • Apr 2016
    • 20
    Microwave Issue
    Hi guys, hope someone an give me a little help here. I bought a broken microwave with the intention of fixing it. The output to the HV circuit is working and after some investigation I found a HV fuse that had blown that was in a plastic carrier under the fan. Anyway I decided to order a new fuse and diode which is strapped across the case and the 2300v cap. Before I replaced these items the microwave hummed normally and it appears to work but there was no heat. Since replacing the fuse - i think the diode was OK - it now make a very loud buzzing noise when on and still no heat. I have tested the Magnatron and it tests as it should with a DMM. I have tested the Cap and it also tests as it should with the modest Cap test on my DMM. It also has no short to case and the discharge resistor is also testing out as good at 10MOhm. In short I now don't know which component Transformer, Magnatron or Cap could be bad. Any help appreciated. I have a Multi Function 1000v tester at hand could I use this to test the components further for breakdown under high voltage?
    James
  • redwire
    • 3900
    Re: Microwave Issue
    Can you give us a make and model number, that helps for the schematic.
    Some microwave ovens use both a rectifier and a protection (across capacitor) diode.
    If the new HV fuse is not blowing, then something has changed and gone open-circuit. So looking for shorts or breakdown is second on the list.
    A microwave oven rectifier diode is usually high voltage drop ~11V due to the stack of diodes inside. So you cannot test it for open with a multimeter unless you have a power supply or a couple 9V PP3's.
    When repairing things, it's best to track down and find the failed part instead of just replacing parts. One failed part can damage others and a person can get lost with what the original problem is.
    I would ensure the new diode is the right part and in correctly, was the old one good. Inspecting the magnetron for evidence of arcs, as that may be what originally popped the fuse.
    • jamesmcuk
      • Apr 2016
      • 20
      Re: Microwave Issue
      Hi, Thanks for the reply. its a whirlpool jq280 which is not common here in the UK but I do have this link https://www.manualslib.com/manual/98...?page=5#manual
      I agree about replacing parts but I did the diode as its was cheap and as you say something difficult to test with a DMM. I do think the old one was probably good though looking at the DMM readings.
      The diode has crimped on tags that are different so its defo in correctly. I haven't yet removed the magatron so maybe thats the next step to see if there is any sign of arcing?
      Thanks again
      James
      • Sparkey55
        • Jan 2010
        • 1523
        Re: Microwave Issue
        Check for continuity of the tube filament; could be open.
        • redwire
          • 3900
          Re: Microwave Issue
          +1
          The majority of magnetrons are 3.3VAC >10A filaments, so with the transformer disconnected expect under 0.33 ohms.
          I would check continuity from filament to housing and tap it, bang it a bit. What may have happened is the magnetron filament arced and later popped the HV fuse but now the filament short-circuit has cleared, vanished.
          Toshiba Magnetrons for Microwave Ovens has some datasheets etc. if you know the tube number.
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            Re: Microwave Issue
            You should also check the capacitor as i've had many microwaves stop working because of it.
            Edit: realised you may have already have done that.
            I'm not a expert, I'm just doing my best.
            • jamesmcuk
              • Apr 2016
              • 20
              Re: Microwave Issue
              Thanks for the replies guys. I have as you note Ruky checked all the items bar the secondary transformer winding on the HV circuit and they appear to test OK but thats not to say the cap which is reading correctly isn't breaking down under 2kv.
              Mag is giving me 0.19 to 0.2 on filament and open circuit filament to case but I haven't tried banging on it or removing it to check for damage so I will do that today.
              I have read people saying the waveguide could be faulty but I am not sure how, isn't that just a metal guide?
              Thanks again.
              • R_J
                • 9514
                Re: Microwave Issue
                Check if you have high voltage, I doubt your meter can measure over 2000 volts so, you can dissconnect the magnatron high voltage lead, turn on the microwave for a few seconds, turn it off and see if the capacitor charged by checking if there is any voltage on it either with your meter or by shorting it with a screwdriver. or you can place the high voltage lead about a 1/4 inch or less from ground and see if it produces an arc when turned on.
                But I suspect the magnatron is bad. you can't check a magnatron, you can only check if the filament is open or shorted to case.
                wave guides don't go bad.
                  master hoarder
                  • May 2008
                  • 12164
                  • Bulgaria
                  Re: Microwave Issue
                  You can check the high voltage with a regular multimeter if you build a proper resistor divider circuit.
                  Assuming the output voltage should be around 2000V, ten 100 kOhm resistors in series will divide the voltage so that each has about 200V on it. So if you measure, let's say, 226V across a resistor, then the voltage is likely somewhere around 2260V (i.e. 10x that value, more or less, assuming all resistors have close to 100 kOhm resistance.)
                  Now here is one important consideration when building such voltage divider circuits: power dissipation. With 200V across each resistor, the expected power dissipation, Pd, will be (200^2)/100000 = 40000/100000 = 0.4 Watts. So you will need resistors rated for at least 1/2 Watts each. And if the expected output voltage is double (i.e. 4000V), then the resistors power rating should be quadrupled - i.e. use 2W resistors.
                  • redwire
                    • 3900
                    Re: Microwave Issue
                    I would say that's not right because the circuit is a half-wave voltage doubler and it does not output pure DC.
                    If you use a scope and HV probe, you will see 1/2 wave pulsating DC from +11V to -4,000V. If the magnetron is open-circuit, the no-load voltages go much higher than (loaded) 2kV out of the transformer. The portion of the sine-wave where the cap is charged is also not seen then.
                    Really good information for microwave oven repair is here: https://repairfaq.org/sam/micfaq.htm#mictstmag
                    snippet from Testing the Magnetron:
                    A magnetron with an open filament will result in no heat but no other symptoms. The bad connection may be internal (in which case the magnetron will need to be replaced) or external at the filament terminals (which may be repairable).
                    A magnetron with with a short between the filament/cathode and anode will likely result in a loud hum from the HV transformer and/or magnetron when the cook cycle is initiated but the main fuse will probably not blow. However, note that the actual wattage drawn from the power line will probably be much lower than under normal conditions. Although there will be a high current flowing in the HV transformer secondary through the HV capacitor (likely causing a loud hum or buzz), the real power consumed will be reduced since the current and voltage will be out of phase (due to the series capacitor) and the power factor will be low. A reading on an AC line wattmeter of 300 W compared to the normal 1,200 to 1,500 W would be reasonable.
                      master hoarder
                      • May 2008
                      • 12164
                      • Bulgaria
                      Re: Microwave Issue
                      Thank you for the detailed info, redwire!
                      Learning something new every day.
                        • Jul 2011
                        • 6020
                        Re: Microwave Issue
                        You can also check the Magnatron output with a small cfl tube inside the microwave oven
                        You should only use one that is only about 2” long with the terminal end taped if the magnetron is working the cfl should glow if it does not then it is bad
                        One note this should not be more than 30 seconds at time and the cfl should be in center of the turn table
                        You need to use caution when doing this test
                        • desert-rat
                          • Mar 2014
                          • 4103
                          Re: Microwave Issue
                          You can check the pri and sec power trn. with the wires off. The ovens I have checked have had open pri. trn. Its cheeper to get a new oven than a power transformer .
                          • jamesmcuk
                            • Apr 2016
                            • 20
                            Re: Microwave Issue
                            Once again thanks for all the replies and detailed responses. I have checked the magnatron for signs of arcing and there is none. I have tried shorting the cap after trying cook and noting happens, no spark. The cap tests out as working with my meter as I say. The only component I haven't tested is the transformer which is the bit that I think is making all the noise. I have looked at replacement caps and the diode is on the other terminal to mine does it make any difference? I guess I am going to try and test the secondary winding of the transformer.
                            • R_J
                              • 9514
                              Re: Microwave Issue
                              If you have a current clamp, disconnect the cap, diode, & magnatron and check the curent draw on the primary, it should be almost 0, If no current clamp try an incandescent lamp in series with the primary, if the lamp lights up and stays lit, you have a shorted transformer.
                              • jamesmcuk
                                • Apr 2016
                                • 20
                                Re: Microwave Issue
                                I have a current clamp so will try that. However by the noise it's making I would suspect it's ok on the primary as it started to make the much louder buzzing having replaced the HV fuse. I would suspect if anything a broken secondary but I dont have a meter or other bits to test it properly. Thanks for the reply.
                                • R_J
                                  • 9514
                                  Re: Microwave Issue
                                  If there is a short in the secondary it will show high current on the primary
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Re: Microwave Issue
                                    Well, it's a step up transformer with roughly a 1:10 ratio I would assume.
                                    So 2.3kV output with 230v input.
                                    So if you feed it 24vac on the primary you should see around 240vac on the secondary...
                                    As for the magnetron heating element that is only ca 3v with 240vac on the primary.
                                    So that is safe to measure without a high voltage probe.
                                    (Well, safe as in if you make a mistake and measure the wrong secondary you blow up your meter but as you are working with a microwave I better hope you already understand the risks involved!)
                                      • Jul 2011
                                      • 6020
                                      Re: Microwave Issue
                                      Not exactly because this is high current transformer
                                      When you power the transformer up with no load your amperage might be around 6 or 7 amp and your transformer should be humming a little bit
                                      If when you use a incandescent light bulb in series with transformer it might start off being real bright and then reduce brightness a little bit
                                      This is only going to tell you that you do not have an open transformer and not much else
                                      • R_J
                                        • 9514
                                        Re: Microwave Issue
                                        If you are drawing 6 - 7 amps unloaded, Thats a bit high, unloaded it will draw a couple amps.
                                        I just went and check one that I have, it is for 110vac input, and it draws just under 2 amps unloaded.
                                        I also checked it with a lamp in series and it does light up quite a bit, so I was wrong in post 15
                                        Just for comparison I also check a regular isolation transformer I have and unloaded it was 300ma.
                                        • drykid
                                          Matsui 175S microwave fuse replacement
                                          by drykid
                                          I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                          Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                          12-21-2020, 01:15 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
