Microwave Issue
    master hoarder
    • May 2008
    • 12175
    Re: Microwave Issue
    Isolation and MW transformers are quite different, though.
    Because MW traffos have to handle a lot of power while still trying to make them fairly compact, manufacturers usually keep the number of primary (and thus secondary) turns a bit small. This, however, lowers the inductance (and resistance) of the transformer's primary, which causes fairly large current to be drawn even at no load. For this reason, MW transformers also aren't usually rated for continuous duty cycle. On that note, most "long" MW cooking presets typically switch the MW to "medium" power - i.e. they cycle the transformer on and off periodically to allow it to cool. If you leave a MW transformer plugged into the wall continuously, even with no load, it will eventually overheat and burn itself out.
    • drykid
      Matsui 175S microwave fuse replacement
      by drykid
      I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
      Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
      12-21-2020, 01:15 PM
    • corrize
      A funny fuse story – Lumix LX100 II
      by corrize
      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
      10-19-2023, 09:58 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • ugamazing
      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
      by ugamazing
      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
      12-17-2024, 07:05 PM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
