Hi there!
I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some minor intermitent dimming) and it technically works..it allows you to select a different temperature and it shows it onscreen
But the inner temp is mild, the back radiator is not even warm and the noise at the main (and only) board is loud. There is a chirping all the time, which varies depending on the load (disconnecting fans changes it)
I found one of the 2 HV input side large caps bulky, so I replaced it and expected it to be fixed, but no. Then I swapped the other one with no result.
Then I swapped both larger caps at the lower left side, close to the outputs, same effect. None of the other capacitors (expect the first 220v) had any external sign of damage or aging.
Should I keep swapping the smaller ones too?
Also the tein radiator at the HV side (top) get too hot. I measured the fan&peltier voltage and it flikers between 2.5-3.3V, which should be 12V, The fans turn but slowly. The peltier cell won't do much with 3v...
Is this a cap problem or am I missing something else? Hopefully the noise it makes sounds familiar to someone.
https://www.youtube.com/shorts/bAWuz...ZDaYgTsP9rT3si
Thanks!!
Thanks!!
