Wine and Beverage Cooler Control Board Repair Attempt
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
    Model number AWBC242GGFD
    Previous owner states that it needs a new motor.
Name:	Screenshot 2024-07-19 at 1.38.06 AM.png
Name:	2024-07-19 01.23.09.jpg
    When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
    I pulled out the main control board to give a look.
Name:	2024-07-19 01.22.40.jpg
Name:	2024-07-19 01.22.17.jpg
    Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
    After some inspection I noticed an IC which looked a bit off even from under the conformal protective coating.
    Sure enough I think i found a pinhole in the IC.
Name:	2024-07-19 01.22.30.jpg
    Question is... what's the best way to ID this IC?
    I could try to get as much of the coating off the chip as I can in order to read what is left of the markings but with the hole dead in the center I doubt I'd be able read it properly.
    Any advice would be greatly appreciated!
    Thank you in advance!
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Got some paint stripper and acetone and got it cleaned up.
    I dodged a bullet as the hole JUST missed the manufacter's part number.
    This appears to be a Three-way 50V SOP-8 Darlington Transistor Arrays from LANKE.
    I have no experience with these transistors so I will do some research as I look for a suitable replacement.
    If anyone knows of a good local (US mainland) source for these I'd appreciate the tip.
    Im only seeing them on Aliexpress.
    Edit to add:
    Just placed an order with AE.
    Time it would take to find someone local (if they even exist) I will have already received the package.
    10 ICs for $4US is hard to beat.
    Click image for larger version  Name:	20240719_020701.jpg Views:	0 Size:	974.5 KB ID:	3312036
      • 31126
      ULN2001D - thats a driver - so you need to see if what it drives is shorted.
      the datasheet is incomplete and only seems to show the pinout for the 7way version
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        Thank you STJ.
        I found the SOP-8 datasheet but it is on Chinese and impossible for me to discern much from it without a translation. Dont know how to translate a pdf file though.
          • 31126
          it's the same as the datasheet i posted just shorter,
          B's are inputs, C's are outputs.
          E is ground and COM goes to the positive supply to the thing it drives.
          unless it drives inductive loads like relays or solenoids you wont even need COM, it's just for the reverse protection diodes.
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            So should i follow the 3rd track to see where it leads in order to find any potential shorted components?
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              Im having a look at the pics of the driver and I dont see anything inline (direcly connected to it) which would be shorted.
              The traces leads to a relay (3C/output) and to the controller chip (3B/input).
              The input also terminates to a blank whole where a through-hole resistor would have been.
Name:	Screenshot 2024-07-19 at 5.40.31 PM.png
              I will clean off the controller chip to check if it is damaged as well. If i can find a datasheet I maybe be able to determine where that pin is connected to and see if there are any shorted components upstream.
              • redwire
                • Dec 2010
                • 3912
                The IC has three output drivers which are driving the relays. BUT one output also goes to the red connector X6 so whatever connects there is shorted.
                The IC is like a half or mini version of a ULN2001.
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  Good eye redwire.
                  I didnt see that.
                  I went to check and its the connector for the fan that blows over then condenser.
                  It reads 2.4Mohms which is in-line with similar computer case fans i have laying around.
                  l cleaned off the controller chip and it looks perfectly fine.
                  Click image for larger version  Name:	20240719_195152.jpg Views:	0 Size:	2.30 MB ID:	3312597
                  I tested the 3 relays by running 12V across the leads and they all work fine with healthy clicks.
                  • redwire
                    • Dec 2010
                    • 3912
                    Um I wouldn't trust a 2.4MEG reading to tell me the fan is OK. Power it up see how it does on 12V. What is X6 3rd pin for? I wonder if the LED strips are OK, not shorted or if they are what goes to the blown IC.
                    Don't apply 12V power to a relay coil in-circuit, that causes reverse current to flow. I would check the IC did not short 12V power to the input pins, that would take out the MCU as well.
                    • KYBOSH
                      • Oct 2011
                      • 581
                      • Unknown
                      Right on Sir.
                      Fan checks out. pulls 0.063 A on 12v.
                      The 3rd (middle) pin on X6 is connected to absolutely nothing.
                      Seems to be simply serve as a guide or support.
                      Interior lights LED use 3 wires (white, black, blue) and come from the X3 connector.
                      The LEDs tested good at the connectors.
                      Not sure what else i can check without a replacement darlington.
                      I am getting 12v to this transistor as it does get hot when plugged in (confirmed via FLIR).
                      From a quick glance the darlington activates the 3 relays there which power up the compressor or something hefty as they are connected to the connector with the thick gauge wires.
                      Edit to add:
                      thanks also for the tip on not running testing relays while in-circuit. Im not familiar with the perils of reverse current but I will look that up as well.
                        • 31126
                        i would test the relays with a 9v battery to make sure they click,
                        other than that, these chips can randomly fail.
                        i have maybe 50 or more of the 8way version, i use them to fix gambling machines that use them for all types of stuff.
                        • redwire
                          • Dec 2010
                          • 3912
                          This thread I posted what happens when you power a relay on a board that has power off- current flows backwards. Using a bench PSU or maybe the 9V battery. It's best to have the board under it's own (12V) power and just ground the relay pin, shorting the driver output to GND to click the relay - although this doesn't tell you much anyhow. I've heard a click but burnt contacts left it open-circuit some of the time. If it's welded closed, the load would stay on.
                          Did the insulation in the relay fail, contacts to coil?
                          Fridge compressor motors generate huge spikes when the relay/contactor opens. I had a big ice cream machine 208V that would start an arc across the terminal block due to this (I added a MOV), and another cooler that would eat contactors up they only lasted a year. I think it also bags the motor if the winding's insulation gets damaged. This is the 4-6kV league.
                          If this compressor generates a HV spike, it might have made it the over to the relay coil and thus destroyed the driver IC. Or maybe a mains spike did it.
                          • KYBOSH
                            • Oct 2011
                            • 581
                            • Unknown
                            So i got the Darlingtons in today and i promptly installed it on the board.
                            Sadly the unit did not spring back to life.
                            I pulled the board and started looking around for anything that i missed, diodes, resistors, transistors. They looked okay.
                            Started pulling the ceramic caps off the boards to test them.
                            Came across C2 and it was cracked at the top end cap.
                            You would have never have known unless you actually went to desolder it off the board.
                            C8's value fluctuates as well. Between 400-600 nF.
                            My question is what value do you guys think that cracked and dodgy ceramic caps are??
                            Im also not sure about C9. Its reading in µF where as everything else is showing reading nF.
                            Thanks in advance!
Name:	Screen Shot 2024-07-30 at 4.18.16 PM.png
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              redwire
                              stj
                              Any advice on the ceramic cap situation above?
                              Thanks in advance
                              • redwire
                                • Dec 2010
                                • 3912
                                C8's value is written under it, observe the same text above C9. "105" so a 1uF decoupling cap I think.
                                Check if you have DC power 12V (for relays) and 5V for the MCU from Vreg? U1.
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  What a delightful tip! I did not realize that those numbers were the values for the SMDs!
                                  I cant remember ever seeing values printed on the board like that.
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    Some of the boards out of china have part values written on them, here and there. Usually resistors but the oddball (bigger) caps standout as well.
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      Thanks for the tip! I studied up on decoupling capacitors last night.
                                      You are correct by the way: 105 is code for 1uF. I think i change out C8 and C10 for fresh ones.
                                      The other ones seem to be rated for 100 nF so I will swap out C2 and C15 for fresh ones as well.
                                      I'll check for voltage after I get those sorted.
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        So it took me a while to get my book of assorted diodes and caps in but i finally got it and replaced the questionable caps.
                                        Still no joy though. Cant figure out what's wrong with this board. I tested the resistors again. Some where reading low on the board but good when taken out of circuit.
                                        I checked for voltage going to the relays.
                                        JK1 has 11.5v going to it, while the others (JK2 and JK3) have none.
                                        Two things funny about JK1 (JZC-32F). When I looked at it with the FLIR it was markedly warmer than the rest of the board.
                                        I thought it might be shorted but then I took it out of circuit and tested it test fine (although in retrospect i tested it at 30V rather than the nominal 12v... will go back and check it again).
                                        Next I checked U1 for voltage.
                                        At first the readings were dodgy but after touching up the solder joints i was getting a solid 11.52 and 5.02 between pins.
                                        Not sure where to go from here....
                                        Of note, when I was testing the electrolytic capacitors next to the small transformer i mistakenly put one in backwards.
                                        When i installed the board back unto the fridge the control panel inside started lighting up but it was blinking off and on.
                                        This went on for a few seconds until i unplugged the unit to have a look at the board again and I immediately noticed the mistake I made.
                                        So this sign of life is good news. I just have to figure out what I am missing. Doesnt seem to be a short but I cant find the bad component.
                                        It could be a fault IC/Controller but I dont know how to test for that.
                                        edit to add:
                                        just checked that relay and applied 11v to it and it works just fine.
                                        • edugimeno
                                          Wine cooler flickers at startup and doesn't cool enough
                                          by edugimeno
                                          Hi there!
                                          I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
                                          Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
                                          Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
                                          When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
                                          03-01-2025, 04:51 AM
                                        • watergremlin0
                                          Wine Cooler CD-110-B
                                          by watergremlin0
                                          Anyone have an experience with this board? Ive actaully replaced 2 caps on it before. Worked for a few years. However this time around they all seem good. Ive pulled a few and tested they all test in range. Checked a few of the diodes they all seem good. dont see any popped resistors or anything. The light and screen power on however the fans never kick on. Havent found a skematic for this board however my guess would be a component in line with the fan.
                                          06-18-2024, 08:03 PM
                                        • Yanleb
                                          LG 60PK550 Logic Control Board EBR63450301
                                          by Yanleb
                                          Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                          C57: 3.30V
                                          C61:...
                                          07-20-2023, 12:38 AM
                                        • BleedCap
                                          OLD Socket 478 custom bracket + NEW generic cooler
                                          by BleedCap
                                          I already posted this on vogons.
                                          Its a 3d printed custom bracket for socket 478.
                                          I used this AM4 bracket as a base design.
                                          Its to be use with cheap generic clip based cpu cooler.
                                          Reason for doing this is:
                                          - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                                          - New generic cooler is cheaper and can use bigger fan (less noise)
                                          I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                                          The processor that I was using is P4 2.4Ghz prescott....
                                          11-05-2023, 08:09 PM
                                        • harp
                                          triac phase control 0-100%
                                          by harp
                                          Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
                                          06-02-2024, 09:00 AM
