Wine cooler flickers at startup and doesn't cool enough
  • edugimeno
    • May 2017
    • 568
    • Spain
    Hi there!
    I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
    Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
    Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
    When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some minor intermitent dimming) and it technically works..it allows you to select a different temperature and it shows it onscreen
    But the inner temp is mild, the back radiator is not even warm and the noise at the main (and only) board is loud. There is a chirping all the time, which varies depending on the load (disconnecting fans changes it)
    I found one of the 2 HV input side large caps bulky, so I replaced it and expected it to be fixed, but no. Then I swapped the other one with no result.
    Then I swapped both larger caps at the lower left side, close to the outputs, same effect. None of the other capacitors (expect the first 220v) had any external sign of damage or aging.
    Should I keep swapping the smaller ones too?
    Also the tein radiator at the HV side (top) get too hot. I measured the fan&peltier voltage and it flikers between 2.5-3.3V, which should be 12V, The fans turn but slowly. The peltier cell won't do much with 3v...
    Is this a cap problem or am I missing something else? Hopefully the noise it makes sounds familiar to someone.
    https://www.youtube.com/shorts/bAWuz...ZDaYgTsP9rT3si
    Thanks!!
    • 30928
    slow startup is caps,
    given how they put some of them next to big resistors they are probably all cooked.
    • edugimeno
      • May 2017
      • 568
      • Spain
      ok so I should change those smaller ones by the low voltaje side right?
      Would that relate to the high temp.at the choppers heatsinls?
      Also when the screen has already settled, the chirping sound keeps gong and still 3v present at the fans and peltier output...makes sense?
      • CapLeaker
        Leaking Member
        • 7982
        Well… definitely change all caps near a heatsink or any other heat source like resistors etc. These would be primary suspects and those I would go for first. Then look at anything that is heavy and can get hot like Mosfets and diodes on a heatsink, transformers etc and check them for cold solder joints.
        edit: your video with that buzzing sound… sounds to me a transformer is arcing.
          • 30928
          use low esr caps like panasonic FR
          • edugimeno
            • May 2017
            • 568
            • Spain
            That could be, I thought It was a heavy switching noise but it could be arcing. I Will check in full darkness
            If so whats the common source of arcing? Bad solder?
            And posible solution?
            Thanks!!
            • CapLeaker
              Leaking Member
              • 7982
              Thanks!!
              Sounds to me a transformer or something is arcing on the high voltage side of the PSU. Take a wooden or plastic big cooking spoon and take a listen. Could be bad isolation between the windings for one reason or other. First you got to find out what is making that arcing noise.
              It’s not a ticking noise, indicating something wrong in the secondary,
              • edugimeno
                • May 2017
                • 568
                • Spain
                Thanks! But I got a bit lost on the wooden spoon usage for this...
                Could you please elaborate?.
                Thanks!!!
                • CapLeaker
                  Leaking Member
                  • 7982
                  Thanks!!!
                  Put one end of a non conductive spoon like a wooden or plastic cooking spoon on a transformer and the other end put your ear to it. Almost like a stethoscope. Sound travels.
                  • edugimeno
                    • May 2017
                    • 568
                    • Spain
                    Gotcha!! I understand now. Ok yeah I will 1) try to see if I can spot the spark under no light, and 2) see if I can hear what part is having that noise with that method, thanks!
                    • edugimeno
                      • May 2017
                      • 568
                      • Spain
                      Updates... I fu**d up... Went there (I have it at my country house), checked for visible sparks at full dark. Nothing on either side
                      Used the wood spoon method that ​
                      CapLeaker
                      suggested, and found the noise coming from the larger transformed in the middle of the board.
                      Took it out of the chassis and started redoing some solders around the transformers area. Put it back in place and turned on. Bang...At least it was quick and felt like whatever exploded was instant and damaged no more.
                      Found one of the 2 (probably) chopper transistors split into 2 pieces. You can see the pictures. Turned around and found a short in two of the transformers leads I made while resoldering...
                      Don't you love to find that your friends wine cooler is way worse now than when he gave it to you for repair...?
                      Ok I will undo the short and find the transistor (labeled 13005.2), seems to be MJE13005-2, easily found in Amazon.
                      Will be back with news as soon as I get it
                      • CapLeaker
                        Leaking Member
                        • 7982
                        Well, shit happens… that's why something like a “dim bulb tester” is a must repairing switch mode power supplies. I have these at my bench at work and at home. Obviously there is or was a short somewhere in the primary on that power supply. Take that bad Mosfet out and check the 3 pads on the board for shorts. Problem now is that full power went to the gate drive circuit of the Mosfet including the PWM. There could be more damage there. Check it out.
                        • edugimeno
                          • May 2017
                          • 568
                          • Spain
                          Yes, what looks weird is that the short right now is at the SECONDARY of the transformer powered by that mosfet, not the primary. Would a short in the secondary make the Q driving the primary blow so hard? and quick? Or should I look for something else. Maybe I should try to link all this to the original issue of the clicking noise and only 2-3V delivered at output...
                          • CapLeaker
                            Leaking Member
                            • 7982
                            A short on the secondary? Check the ultra fast rectifier diode.
                            • edugimeno
                              • May 2017
                              • 568
                              • Spain
                              Are we talking about the guy circled in red in this picture? Testing on-.board it measures 0,5v in one direction and 1.2v in the other. His "twin" on the other transformer has near zero values on tboth ways, but the suspect side has a blown mosfet connected to it..
                              So you believe the short I made in the secondary should not be enough to blow the mosfet driving the primary?
                              Thanks!
                              • CapLeaker
                                Leaking Member
                                • 7982
                                If you made a short on the secondary most PSU’s should shut down. No, that diode isn’t it. Look at your second picture, that one from the bottom. You see traces. About in the middle of the board there is about a 15mm space with nothing that separates the primary from the secondary. The rectifier diode is mounted on that big black heatsink. If that diode has 3 legs, anode on each side with a common cathode. That red square on the second picture is the secondary side of the power supply. The transformer is where the primary is separated from the secondary. Look hard on that bottom picture again, it seems there is a broken solder joint and one maybe 2 shorts on traces. Maybe redo the bottom picture, straight shot with some light, high resolution.
                                • edugimeno
                                  • May 2017
                                  • 568
                                  • Spain
                                  Thanks a lot.
                                  The part placed on the black large heatsink is labeled STPS2045C, you are right, it's a schottky diode, I will test it later on out of the board. Also I can't really tell which bad solder point you are refering to, can you explain maybe drawing on one of my pictures?
                                  Thanks a lot!
                                  • CapLeaker
                                    Leaking Member
                                    • 7982
                                    … just to point out a few. In that red little box there is a solder blob that shorts to pads out. The rest either have circles or just shoddy soldering. You have to go through the whole board and clean stuff up.
                                    • edugimeno
                                      • May 2017
                                      • 568
                                      • Spain
                                      Ok I see. Yes those pads are looking bad but the connection is ok, I will redo them anyway.
                                      There is a 0Ohm across lead 1&3 of the schottky diode but I believe this is internally created in the diode...oh wait, I just checked the datasheet and it's not a single diode between lead 1-3 to lead 2, its a twin diode so leads 1&3 should not have that short... I will recheck that but someone mentioned that such a short in the secondary wouldn't make the mosfet in the primary burn immediatly...
                                      The new mosfet is in its way but aside from removing the short in the secontary, I need to:
                                      1) Find out what made mosfet to burn, in case it was not the short by the schottky diode
                                      2) Find the original problem, a clicking noise in the supply voltage that would make the screen power cycle for several seconds after plugging in.
                                      I have later on realized that this PS is PWM driven so it won't put out either 0 or 12V to the peltier and fans, I found other posts on this forum and they said it would provide a proportional voltage depending on how far it is from the set temperature, and I had set it to 12ºC, while the room temperature was 13-14ºC, so maybe the 3V I measured at the fan&peltier was not a problem, just a reduced controlled power.
                                      • CapLeaker
                                        Leaking Member
                                        • 7982
                                        Look at that arrow. There is a solder blob between those pins. That definitely needs to be removed. That diode package with 3 legs has 2 diodes (outer pins) and the middle pin is a common cathode. Measure each outer pin to the middle pin in both ways. One way you get an open and the other way you should see something like 0.2V of a voltage drop with your DMM set to diode mode.
                                        Once everything looks good in the secondary and has no shorts on the output, then look at the primary.
                                        Mosfet can burn for different reasons, by either input voltage, too much heat, gate drive circuit of the mosfet stuck on, bad capacitor(s), etc.
                                        • KYBOSH
                                          Wine and Beverage Cooler Control Board Repair Attempt
                                          by KYBOSH
                                          Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
                                          Model number AWBC242GGFD
                                          Previous owner states that it needs a new motor.
                                          When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
                                          I pulled out the main control board to give a look.
                                          Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
                                          07-18-2024, 11:52 PM
                                        • watergremlin0
                                          Wine Cooler CD-110-B
                                          by watergremlin0
                                          Anyone have an experience with this board? Ive actaully replaced 2 caps on it before. Worked for a few years. However this time around they all seem good. Ive pulled a few and tested they all test in range. Checked a few of the diodes they all seem good. dont see any popped resistors or anything. The light and screen power on however the fans never kick on. Havent found a skematic for this board however my guess would be a component in line with the fan.
                                          06-18-2024, 08:03 PM
                                        • magik20
                                          Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
                                          by magik20
                                          I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
                                          I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
                                          The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a...
                                          04-30-2025, 04:46 PM
                                        • BleedCap
                                          OLD Socket 478 custom bracket + NEW generic cooler
                                          by BleedCap
                                          I already posted this on vogons.
                                          Its a 3d printed custom bracket for socket 478.
                                          I used this AM4 bracket as a base design.
                                          Its to be use with cheap generic clip based cpu cooler.
                                          Reason for doing this is:
                                          - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                                          - New generic cooler is cheaper and can use bigger fan (less noise)
                                          I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                                          The processor that I was using is P4 2.4Ghz prescott....
                                          11-05-2023, 08:09 PM
                                        • beetle1303
                                          EuropAce EWC 913 Wine Cooler power board fuse blow /shorted
                                          by beetle1303
                                          I am a occasional hobbyist home electronic / electrical goods repairer without formal training in electronics/electricity. I learned from here and Youtube mostly.
                                          I was given a EuropAce wine cooler model EWC 913, with no power supply - totally dead.
                                          I opened up everything, and zoom into the power supply board (see attached pics), the board part# is Hanny10-12b, PCB110729M1, Rev0.
                                          There are 2 fuses, 1 is OK, 1 was burnt. I disconnected all the input and output cables, put the power board stand-alone on a table, and replaced the burnt fuse. I burnt immediately upon power-on....
                                          04-06-2020, 09:11 AM
