Wine Enthusiast 170 Bottle N'Finity Wine Cellar Model # 273 02 70
  • magik20
    • Apr 2025
    I'm hoping someone might be able to offer some guidance on repairing a Wine Enthusiast N'finity 170 bottle wine cellar, model 273 02 70.
    I recently acquired this unit for free via Facebook Marketplace, hoping to fix it up as a gift for my wife. I have some basic electronic skills (comfortable with a multimeter, basic soldering, identifying components) but I'm definitely not an advanced technician.
    The main challenge is that when I picked up the unit, the main control/power board had already been removed and the previous owner said it needs a new one. Unfortunately, I have no information from the previous owner about the original symptoms or why they removed the board.
    I've visually inspected the board and don't see any obvious burn marks, scorches, bulging capacitors, or other signs of physical damage. The main fuse also appears to be intact.
    My immediate problem is reconnecting the wiring harness to the board. I've managed to connect the plugs that seem obvious (matching connectors, keyways, etc.). However, I'm left with:
    1. Four unidentified leads: These look like they might be higher power connections (possibly for compressor, fans, heating element?). They don't have obvious unique connectors.
    2. Several small two-pin connectors: I assume these are for various sensors (temperature probes?), maybe LED lighting, or smaller fans.
    I'm hesitant to just guess, especially with the four heavier leads. I really don't want to connect power incorrectly and cause further damage to the board or other components before I even start diagnosing the original issue. The smaller two-pin connectors worry me less about causing damage, but getting them right is obviously important too.
    My Questions:
    1. Does anyone have a wiring diagram, service manual, or even clear photos of the board connections for this specific model (273 02 70)? Particularly showing where these four main power leads connect?
    2. Are there any markings on the board or common colour codes I should look for to identify where these leads connect?
    3. Assuming I can get it wired correctly, what would be the recommended first steps for troubleshooting, given that I don't know the original fault? Should I just power it on and see what happens (lights, fans, compressor attempting to start)?
    4. Are there known common failure points or typical issues with this N'finity 170 model I should be aware of or check first?
    Photos here
    https://photos.app.goo.gl/cMMFuqcBu5dEzxa6A
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    The 4 main power leads are the least of your problem. The 2 wires left on the transformer that are white with blue connectors go to the centre 2 pins marked trans N and trans L. The blue and brown wire go to upper and lower connector marked N and L. These ones you have to be correct. Brown is Live and Blue is Neutral. HV side done.
    I think I see a bad capacitor on the board. I'd check it anyway.
    There should be a little diagram sticker on the back of the fridge or somewhere hidden.
    • ajsterr4
      Wine Enthusiast wine cooler, no power. Model # 272 03 29
      by ajsterr4
      I'm gonna take this thing apart very soon, gonna give it a a look over. Check for burn marks and bulged caps.
      I read to check for continuity throughout, I have a multimeter, what process should I follow? How can I check for bad fuses as well?
      Any info helps, I got this unit for free. Thanks to everyone here....
      11-30-2019, 03:44 PM
    • Jneub007
      Haier HVTB18DABB Wine fridge thermoelectric board - bad caps?
      by Jneub007
      Hi! Hope you can lend me some advice.
      I am attempting to repair a Haier HVTB18DABB thermoelectric wine fridge. Both fans work, but the temps are not changing in the dual zones. Upon inspection, I believe this cap (pictured) and possibly another may be the culprits - based on the base of the caps and what looks to be dried dark liquid at the base. Assuming that is abnormal?
      Do you agree and which product do you suggest replacing with?
      Very much appreciated! Let me know if more info needed. ...
      01-20-2025, 11:50 AM
    • gggorast
      Request for Intel Serpent Canyon NUC 12 Enthusiast Mini PC schematics/boardview
      by gggorast
      my Intel Serpent Canyon NUC 12 Enthusiast PC model RNUC12SNKi7200U lost video output while watching video on YouTube.
      • I tried different cables and monitors and it keep loosing signal.
      • The monitor "see" the PC connected to it but there is no image on it when boots.
      • I can hear that the PC is rebooting fine to Windows desktop.
      • In very rear occasions I can manage to get the image out but after restart or switched display port or to HDMI it wont give image again.
      • What might be the problem? How to fix it?
      Any one by any chance have the schematic or boardview for this NUC...
      11-16-2024, 06:18 PM
    • KYBOSH
      Wine and Beverage Cooler Control Board Repair Attempt
      by KYBOSH
      Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
      Model number AWBC242GGFD
      Previous owner states that it needs a new motor.
      When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
      I pulled out the main control board to give a look.
      Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
      07-18-2024, 11:52 PM
    • edugimeno
      Wine cooler flickers at startup and doesn't cool enough
      by edugimeno
      Hi there!
      I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
      Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
      Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
      When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
      03-01-2025, 04:51 AM
