Anyone have an experience with this board? Ive actaully replaced 2 caps on it before. Worked for a few years. However this time around they all seem good. Ive pulled a few and tested they all test  in range. Checked a few of the diodes they all seem good. dont see any popped resistors or anything. The light and screen power on however the fans never kick on. Havent found a skematic for this board however my guess would be a component in line with the fan.
					Wine Cooler CD-110-B
	Tags: None
 I would put the board in and heat it up a little with a hair dryer and see if it works again.
 Unfortunately it is impossible to read anything at all from these low res pics. Take some straight shot high resolution pictures from top and bottom an upload them using the attachment function.
 Does this wine cooler have a temperature display if it does what is the temperature reading on the screen and does the temperature rise or decrease when you put your finger on the sensor or put ice on the sensor and is temperature that is it reporting is correctComment
 could you redo the pics and focus on the bottom of the board instead on the transformers. There area we are looking at is like totally blurred out on the edge.
 Where the red plug is, there is a 5w gray looking resistor with blackend legs. Looks like it got really hot? What about that bigger capacitor next to it?Last edited by CapLeaker; 06-19-2024, 07:28 PM.Comment
 Which connector goes to the fan(s)? They all seem to be just a fan on/off transistor based on doorswitch or maybe temperature.
 Other wine cooler repair thread here with Hanny controller boards. Many capacitors fail on these boards and you've only replaced two, big spender lol.
 Hanny C-7754E, CD-110-BComment
 why would I replace all the parts when there not broken. I would rather ID what is wrong and fix that part. Not being cheap its more of a pet project at this pointWhich connector goes to the fan(s)? They all seem to be just a fan on/off transistor based on doorswitch or maybe temperature.
 Scientifically, it's best to troubleshoot down to the component-level and find the problem exactly. This worked to make me a good technician because you knew it was fixed.
 But china has made electrolytic capacitors cheap, cost to the penny and lifetime down to the precise year.
 For equipment that is running 24/7 or expensive/important, I'll just "shotgun" the power supply, outright replace all electrolytics. People get mad at me for suggesting this, but why?
 You are forgetting the cost and time of your own labour to take it apart, troubleshoot, drill down to the exact failed capacitor.
 For the $10 I'll spend on top quality capacitors, I replace them all and never need to go in there again. It takes minutes.
 Your personal time worth say $50-$100/hour is way more than the parts costs.Comment
 I second this recommendation for most switching power supply units and for other devices that rely on having high quality capacitors the cost of capacitors is relatively low in cost for capacitors up to 1000uf and under 100uf I usually replace all of them unless they are well known brands and series if they are used 24 hours a day 365 days a year they will get replaced any wayScientifically, it's best to troubleshoot down to the component-level and find the problem exactly. This worked to make me a good technician because you knew it was fixed.
 Because time is money and I personally do not like doing this more than once in 10 years and many hours of continuous heavy use and probably abuse from the power company
 Unless you invest in a good quality ESR meter and even then you are not testing it under load and 100uf capacitors especially startup capacitors it not worth the risk of it being damaged or just bad yes I will check them with a ESR meter even if they are slightly higher in value than a brand new capacitor they still get replaced with a new one in most cases a new cost less than $0.10 for one when you buy 100 at a time
 Here is a story about why you replace capacitors under 100uf regardless of what your ESR meter tell you I have a line conditioner that has two different value capacitors and they tested good with the ESR meter so I reinstall them and a couple of years later it started doing the same issue it had for the reason I took it apart in the first place it would switch between voltage levels for no apparent reason so when I took it apart this time I just replace both of them and it worked fine for many years until just recently it now has an issue with the ground because the wiring fault light is lighting up on the battery backup I have not narrowed down exactly what the issue is yet but this I have another line conditioner that I have recapped and I put in service so I am not in a hurryLast edited by sam_sam_sam; 06-22-2024, 04:56 AM.Comment
 Was just away for the weekend. Just getting back. The fans connect into the red and white ports on the boardComment
			by KYBOSHTrying to a fancy Wine and Can Beverage Cooler which wasnt working.
 Model number AWBC242GGFD
 Previous owner states that it needs a new motor.
 When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
 I pulled out the main control board to give a look.
 Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
			by beetle1303Received this dual doors dual temperature control wine chiller with some unusual issues:
 1) On powered up, all the electronics seemed to be working properly - lights, temperature settings, current temperature, etc, all displayed correctly. But sometimes both zones will get chilled, sometimes upper zone only, and sometimes lower zone only. The temperature displays will show the correct temperature as it chilled (I placed a stand-alone thermometer inside and they compared correctly)
 2) However, the chilling does not stop at the set temperature.
 3) When both zones are chilling,...
			by CapLeakerGot a new victim:
 AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
 A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold! It's cold here at times in Canada, but not that cold!
 B: stuck at some temperature and maybe updating once in 12 hrs or so.
  Easy solution is to go to AcuRite website and purchase the sensor. Right?... Easy solution is to go to AcuRite website and purchase the sensor. Right?...
			by edugimenoHi there!
 I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
 Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
 Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
 When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
			by BleedCapI already posted this on vogons.
 Its a 3d printed custom bracket for socket 478.
 I used this AM4 bracket as a base design.
 Its to be use with cheap generic clip based cpu cooler.
 Reason for doing this is:
 - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
 - New generic cooler is cheaper and can use bigger fan (less noise)
 I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
 The processor that I was using is P4 2.4Ghz prescott....-
- Loading...
