How much capacitance do we consider
  • sam67
    • 256
    I have bought some caps from RS- on line from here in uk..
    The caps i got were pan FM and pan FC just been measuring the caps with My micro 4 ESR meter ..now the 2200 uf 10v the Esr is fine yet the capacitance is 2300 over 100 ,is this a big deal or not ? Just wondered because we all seem to focus on ESR but surly the capacitance has to be questioned if it's way off.
  • berniedd
    • Mar 2007
    • 119
    Re: How much capacitance do we consider
    No big deal. Electrolytics can be 50% off from their rated capacitance and still be considered okay.
      master hoarder
      • May 2008
      • 12170
      Electrolytic capacitors usually have a 20% tolerance. That means when they come out of the factory, their capacitance can be either 20% higher or 20% lower than the stated value. Most circuits that use electrolytic capacitors should be able to cope with this variation just fine.
      Not sure about 50% though. Some circuits could tolerate it, others might not.
      • Radio Fox
        • Jan 2010
        • 281
        The Panasonic FM & FC range (like many others) have a +/- 20% tolerance, so a reading of 2300uF for a 2200uF capacitor is less than 5%, which is good.
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
          • 31010
          that 20% is effected by temperature anyway.
          put one in the fridge and one on a radiator or against a cup of coffee for a while - then meter them again!
          the cold one will meter lower capacitance than the hot one.
          • amp
            • 6
            I was pulling some standard brown kzb? 3300uf caps off a am2 biostar motherboard with 2 bad and 3 good ones. The good had 3900 capacitance, the budging ones had more around 1000. Thought 3900 was a bit high, but at like 0.01 esr its hard to trash them.
            Swapped them with all 3300uf used rubycon's all reporting 3100 capacitance. Considering the power rail was lacking a good -4500 before capacitance and the computer would still run for a few hours. 3900 makes me think they were over-rated knowing they are bad quality and would degrade after a few years.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              +- 20%
              20% of 3300uF would be 825uF..
              so that cap could be somewhere within 2475uF and 4125uF and would still be in spec..
              edit: it's KZG most likely.. a series of Nippon ChemiCon caps that doesn't like heat. at all..
                • 31010
                you need to recap your calculator,
                20% of 3300 = 660!
                • shadow
                  • Feb 2007
                  • 732
                  good one there
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    uhm.. typo when i put it into google calc.. was 3AM when i posted that.. + a couple beers.. lol
                      ACER Veriton 6610G Veriton M i5-2300 Specification for Upgrade or Repair
                      This specification for the ACER Veriton 6610G can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton 6610G boardview and Veriton 6610G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
                      09-12-2024, 03:36 PM
                    • Junkrepair
                      Calculating ESR from tan delta -- tan delta's dependence on capacitance
                      by Junkrepair
                      I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                      I found this nice little description of the conversion:
                      Calculating capacitor ESR from Tan(delta)
                      https://forum.digikey.com/t/calculat...-from-tan/2633
                      It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                      06-12-2023, 02:45 PM
                    • Sparklingx
                      SMD ceramic capacitor capacitance & voltage
                      by Sparklingx
                      what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                      09-12-2024, 01:04 AM
                    • Antonynl
                      Capacitance and voltage of tantalum?
                      by Antonynl
                      I have a tantalum capacitors with indicators EB 21 that measures only 22pF. See attached picture.
                      Since this is a windmeter that is normally in a very high mast I would like to get the correct replacement capacitor.
                      Is there somebody that can tell me what the capacitance and voltage of this capacitor are?
                      I don't feel confident that I can figure this out myself after searching around
                      Cheers!!
                      04-14-2024, 03:19 PM
                    • SwedishDiesel
                      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                      by SwedishDiesel
                      Howdy folks,
                      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                      10-30-2021, 12:47 AM
