Here is a good used source for 18650 batteries
    • Jul 2011
    • 6055
    Re: Here is a good used source for 18650 batteries
    Originally posted by eccerr0r
    sigh. miss the "good old days" when balancing is chemically done, like in lead acid batteries...
    Just add water.
    I agree with you on this one to but I think those days are long gone
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      You still can do it with flooded lead acid batteries though with AGM/SLA you can't really... technically you need balancing circuitry for AGM/SLA too...
        • Jul 2011
        • 6055
        Well what I have found out is that you have to set the voltage at 21.5 for it to work correctly if go pass this point it goes into an error if go lower than 20.5 then it does not charge correctly but the charging circuit does not seem to get very warm so the issue is with the primary side of this switching power supply it is not designed correctly it should not over heat the switching transformer like this
        You set it for 20.1 volt however it does not completely charge the battery fully it about 4.1 volts per cell which I could live with
        But where do I find a switching power supply that has an output of 21 volts this is hard to find 24 volts is more common
        One thing I noticed is that the capacitors in this device are not very good ESR values
        ( at least 1/3 higher than a brand name capacitor )
        for a new non brand capacitors
        So I am going to replace the capacitors that are less than 100uf and see if this makes a difference or not
        Well changing the capacitors helped however it still over heating the switching transformer so just got discussed with this issue and did some modification
        ( removed the circuit board from the case and removed the balancing wire connector from the battery charger connector to the battery pack and put the balancing connector for the SkyRc IMAX b6 battery tester )
        So now I can recharge my battery packs with worrying about the charger going up in smoke
        Just want a to able to charge these battery packs
        I might still use this battery charger for very low amp hour battery pack 5c1p to not stress the battery charger
          • Jul 2011
          • 6055
          One note that was about 60% charged
            • Jul 2011
            • 6055
            Here is an update about the battery pack for this battery operated air compressor
            I have decided to use the batteries that I commented about on this post https://www.badcaps.net/forum/showth...sam_sam&page=9
            I have enough batteries that tested above 8600 milliamperes hours out of 16 batteries I need 5 batteries that were close to the same milliamperes hours so I have enough to build one battery pack
            I going to buy another set of 8 of them and see if I can get some that are close enough to the ones that I have to make another battery pack of 5 battery cells to make another pack
            All batteries tested above 8 amperes hours but I did not have enough of them that had the same or nearly the same milliamperes hours either I would have 3 that were close to 8310 to 8350 milliamperes two were around 8400 to 8450
            some were at 8100 to 8300 milliamperes hours
            I just have to buy the metal enclosure that Battery Hookup has to houses this type of battery
            I will post some pictures when I am finished building it
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              hmm... whats the lowest price to get 1kWh (don't care what voltage) that will survive at least 2000 x 100% DoD cycles from when I take shipment...
                • Jul 2011
                • 6055
                Are you being serious about this or you just kidding
                I have thought about getting this if when I have the money to buy a set of them
                https://batteryhookup.com/products/6...-2-3v-20ah-lto
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  how did I make it sound like I'm kidding? I guess there's a lot of constraints but they are realistic... and no weight or volume constraints... I did accidentally omit the power requirement, would like at least get 800W out of it, though 1kW is an even number.
                  That LTO battery set would be about $700 for that 1kWh...
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Incidentally the SPIM08HP's. to get 1kWh I'd just need 34 pieces...
                    now is there something even cheaper as I'd still need protection. I do have 4x 4S protection/balance boards rated at 30A... which actually is sufficient if I use all four boards in series for 60V as a 16S...
                    hmm...actually if I do 16S2P that would be just under 1kWh and I don't need to buy protection boards! Though that's still a chunk of money.
                    also 8S4P config would work too, working at the limits of the protection board if I only use 2 (30V 32A@1C). However at 60V it'd be less loss when converting to 170VDC.
                    947Wh (32 cells) would weigh just under 10kg =~ 22 pounds. Sigh. Sillyness is that this battery would only hold $0.10 worth of electricity... Still $130-ish/kWh.
                    hmm other options on batteryhookup - The samsung EV 43.2V 8.5Ah packs, if I get 7, would be $250 and would be $97/kWh. The 7pcs Jeep 44.4V 9.8Ah packs for $300 is however about $100/kWh.
                      • Jul 2011
                      • 6055
                      For what I want to do I just need a battery pack that has enough power to last for a certain amount of time and then I would have to recharge them and the BMS/balancing/protection board cost makes me not want to go to big in milliamperes hours output
                      Now for the battery operated air compressor battery pack I thought about making it more than 16 milliamperes hours pack but after you run it for a while continuously it does start getting warm but this is just something that I going to use to blow things off with when fabricating a plastic part and just want something also that is portable and easy to move to another location without having to be concerned about a power outlet or extension cord
                        • Jul 2011
                        • 6055
                        See below—>
                          • Jul 2011
                          • 6055
                          how did I make it sound like I'm kidding…..hmm... (don't care what voltage) that will survive at least 2000 x 100% DoD cycles from when I take shipment...
                          It just has to with the way you said
                          ( I do not care about what the voltage is and will survive 2000 X 100% DoD cycles ) from when I take shipment
                          Those are some very thigh specs except for the voltage requirement ( can I ask you why you need 170 volts dc for I am curious about this what do you have in mind )
                          The problem with battery hookup is that when you see that they have something you might want unless you buy it when you see and you come back a day later you might not see it anymore because it has sold out
                            • Jul 2011
                            • 6055
                            Now I found something at battery hookup that is bad ass
                            https://batteryhookup.com/products/d...ery-bms-switch
                            This is a cool little device it has two speed controller and it has a built in battery pack that surround the motor and it is powerful little motor with a battery fuel gauge on it I bought two of them but I going to buy a couple more of them for just the controller for a motor and compact it is
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              170V=peak(120VAC RMS) and I doubt I'll get a 170V power pack, I'll have to make a boost or other SMPS converter anyway.
                              The 2000x 100% DoD cycles is simply to ensure I don't start losing cells after 5 cycles.
                              Nothing very peculiar at all IMHO.
                                • Jul 2011
                                • 6055
                                I'll have to make a SMPS converter .
                                You might be interested in YouTube video that I just watch
                                https://m.youtube.com/watch?v=InWO8bmO7WA
                                  • 31124
                                  if you want a couple of hundred volts then go to a scrapyard and look at some honda hybrids.
                                  they use NiMH cells banked to give 180-200v
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Have to use SMPS to boost because I need to control and regulate the voltage too, so battery voltage still won't matter...
                                      • Jul 2011
                                      • 6055
                                      Can I ask you what you have in mind making because now you have me more curious than ever of you are thinking about making
                                        • Jul 2011
                                        • 6055
                                        There is one downside of this device and it the charging controller does not have current control so I have to buy 24 volt li-ion battery charger power that limits the current or get buck converter with current control and limit it only one amp
                                        Unfortunately they have sold out of them for now
                                          • Jul 2011
                                          • 6055
                                          What years did they make these cars with NiMH batteries in them
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
