Here is a good used source for 18650 batteries
    • Jul 2011
    • 6047
    Re: Here is a good used source for 18650 batteries
    1500mAh is more than good enough for flashlights and USB power banks, and certainly better than some of the crap China will sell you...
    This is very true I have seen a lot worse batteries before I would not even think about using
    I might have a use for these in some solar lights in the yard because the ones that they sell for this purpose are real crap
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      #62
      You may be interested in this thread about rolling your own - quite literally.
      A working TV? How boring!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Thought that li-ion cells usually are specced for capacity from 4.1 or 4.2V (and even worse some people use 4.3V) to cutoff, so you will get more capacity than just using 3.9V.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          #64
          I know I've read a lot of battery papers and 4.05V is the sweet spot for maximum voltage. Above that, the lifespan of a Lithium battery decreases exponentially.
            • Jul 2011
            • 6047
            For testing purposes I just use 4.2 but what ever the BMS protection board does is fine as long as it not over 4.25 and not less than 3.8
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              BMS tend to stop charging at 4.3V or so. They don't care about lifetime, they only care about rapid autodisassembly of the cells...
                • Jul 2011
                • 6047
                Well I have taken apart the air compressor and it does have two battery voltage monitor modules and a dual input module that separates the battery inputs but is not isolated from each other
                One module controls the motor which has three wires so I not sure what type of motor it is the other module has the battery wires going to it
                So my plan to have two power supply battery packs is going to work all I have to do now is do testing on a bunch of batteries and get them in battery pack cases and hook them up and put the air compressor case parts back together and do some real world testing
                Well I have bought two of the 5 amp hour battery pack and they are using Samsung 2500 batteries this why the battery pack preform so much better well worth the money for these battery packs right now they have a sale on save $18.00 when buying two battery packs
                I would have taken them back and got my money back if they had not been brand name batteries
                My plans have changed I will probably buy two more of them when they go back on sale again
                  • Jul 2011
                  • 6047
                  Here is the more
                  Just as I thought the BMS balancing protection board is part of the charging board look at the top and bottom of this board I have never seen this before done like this
                  I like the idea that you can use the battery connector in another case if you want to
                  When I charged the 1.5 amp hour battery I did not notice this issue it’s when I was charging the 5 amp hour battery is when I noticed this —>
                  There is an issue with the switching transformer for this battery charger the transformer gets very HOT to the touch and you can smell that it getting very hot
                  I going to see if there a way to modify this charger because I do not like the fact that the transformer is getting this hot
                  Even if this might mean that I have to use my SkyRc charger to charge the battery packs
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I've noticed some "current limiting" PSUs don't *really* current limit, rather it just depends on the controller from self destructing, so it's really "wattage limiting"... Not sure if this is the case when "wattage limiting" still allows the transformer to overheat.
                      • Jul 2011
                      • 6047
                      Is there a solution to this issue
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #71
                        Yes there is. Most power supply designs from the past 20 years use current mode controllers, so the quickest and easiest solution is to increase the value of the resistor in the source of the primary switching MOSFET.
                          • Jul 2011
                          • 6047
                          Can you please point out the resistor in question so I know for sure which one you are talking about
                          I have decided to take a different route on this charger but I also have another one so please post what you have in mind and I will give it a try
                            • Jul 2011
                            • 6047
                            Well what I have found out is that you have to set the voltage at 21.5 for it to work correctly if go pass this point it goes into an error if go lower than 20.5 then it does not charge correctly but the charging circuit does not seem to get very warm so the issue is with the primary side of this switching power supply it is not designed correctly it should not over heat the switching transformer like this
                            You set it for 20.1 volt however it does not completely charge the battery fully it about 4.1 volts per cell which I could live with
                            But where do I find a switching power supply that has an output of 21 volts this is hard to find 24 volts is more common
                            One thing I noticed is that the capacitors in this device are not very good ESR values
                            ( at least 1/3 higher than a brand name capacitor )
                            for a new non brand capacitors
                            So I am going to replace the capacitors that are less than 100uf and see if this makes a difference or not
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              This is actually wrong, it still simply limits the wattage.
                              To get full current limiting you have to design your own add-on circuitry.
                                • Jul 2011
                                • 6047
                                How would I go about doing this project part number would be very helpful thanks
                                Are we talking about a LM338 or something similar using it in current mode
                                The next question is exactly where do you put the current limiter right after the ( rectifier ) the back to back diode coming from the switching transformer or somewhere else
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  It's probably not worth the effort as you have to redesign the whole circuit for true current limiting for SMPS chargers - a significant change is necessary starting with current detection. Of course the current detection needs to be at the battery pack when dealing with switching supplies.
                                  The "simple" solution using the LM338/LM317 as current is not as simple as one would think because of the voltage drop.
                                    • Jul 2011
                                    • 6047
                                    I found a 21 volt battery charger made for 18650 4.2 volt cells and also found a balancing board only from the same EBAY seller so I going to order and will have to wait a month to get the parts
                                    Charger
                                    https://www.ebay.com/itm/13341551537...MAAOSw9dteblyQ
                                    Balancing board
                                    https://www.ebay.com/itm/19226128370...sAAOSw3mdZdaQT
                                    I will have to remove one battery cell parts to make it 5 battery cell but this is fairly easy to do
                                    Other options
                                    https://www.ebay.com/itm/19202702378...kAAOSwTzpfn4FZ
                                    https://www.ebay.com/itm/39353821908...Cclp%3A2334524
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      interesting...now they make balancing boards without protection, like they had make protection boards without balancing. Really need to have both functions IMHO.
                                        • Jul 2011
                                        • 6047
                                        I would agree with you on this but a lot of times you can find protection boards all day long but finding both is a lot harder to find
                                        I like the idea that someone thought about doing this because now it is going to be a lot easier to get things together at least for me it will be
                                        Because I need a 32 volt BMS balancing protection board for a battery operated LED yard that I have that the switching power supply fried because of bad capacitors that leaked all over an encapsulated board what a mess in the metal enclosure that was made for the switching power supply board
                                        My son works nights and on his days off he want to clean his car in middle of the night and I do not want another yard light near the house on every night yea I know I could put one out there that has switch but he would not remember to turn it off so if I put a solar LED yard light out there and he forgets to turn off the switch he just will not have any light that night ( yea I know that you might find this mean oh well )
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          sigh. miss the "good old days" when balancing is chemically done, like in lead acid batteries...
                                          Just add water.
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
