Kind of a different question...
    Re: Kind of a different question...
    Did you set to AC Micro Amp scale?
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Originally posted by stj
      your meter is not showing it right - i'v seen that with flukes before, i think they filter out high frequency stuff.
      60 Hz is ... high frequency?
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        NO, I did Amps and milliamps and figured if I couldn't see any milliamps ... why would I go fishing for microamps? Just didn't make sense at the time ...
        sigpic
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          And of course, because you brought it up, I went and checked also for microamps on the AC setting and I got ZIP! Yet when I switch to AC voltage and put the terminal back into the voltage port I still get a solid 6 volts
          sigpic
            • 31029
            humor me - try it with other meters
            or scope the laptop casing!!! - no need to use the ground-clip
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Here it is ... scope lead hanging right off the case ...
              sigpic
                • 31029
                wow - that's a nice sine!!
                notice it's 60Hz too.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Yeah once I put a little force on the probe, the wave went from something noisy to that beauty right there ...
                  But what this is telling me, is that I have AC running through my laptop ... I'm not sure what to think about that ...
                  sigpic
                    • 31029
                    what confuses me is that psu's usually couple the output negative to the rectified side of the input.
                    so you shouldnt see a 60Hz wave.
                    at worst you should see a 100Hz rectified sine with lots of dampening from the primary cap!
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Really doesn't matter if it's AC or not, just matters how much absolute current can pass through. Ideally that capacitor is small enough (in capacitance) that no more than 1mA will pass through or so, with any "proper" AC voltage presented at the input.
                      If you plug it into a GFCI outlet, short the case of the laptop to ground, and it trips, then you know you have a problem...
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Apple Sauce?
                        sigpic
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Is there ANY risk of damage to the laptop doing that?
                          sigpic
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            Nope, you're just taking the stray voltage and sending it where it should've been in the first place.
                            Permanently Retired Systems:
                            Kooky and Kool Systems
                            sigpic
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #54
                              Well it's normal to see a 50Hz or 60Hz backgroud due to the house wiring.
                              Just so you don't confuse yourself you might want to watch this video.
                              https://www.youtube.com/watch?v=yKb7xIsPjVM
                              The filter that stj mentions is present in all hand held meters.
                              But a scope will not have it, and this picks this noise up, same for a high-end bench dmm.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                Thank you for that video. It makes perfect sense. But I'm not sure how this phenomenon applies to my readings when I have the meter on current reading vs. voltage reading. As we saw, the voltage reading was consistent between the Fluke meter and the oscilloscope ... and I can't take a current reading with the scope to demonstrate that the ZERO reading I was getting from the Fluke was due to the fact that it averages the reading over one power cycle...
                                However, I suppose it stands to reason, that where there is voltage, there has to be current ... and where the Fluke reads 6 volts yet 0 amps even at the microamp level ... I suppose this explanation is as good as any ... the other explanation could be that the actual amperage is less than one microamp.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  An update on the original topic here ... I purchased this power cord for my MBP power brick and it has a spring-loaded flat piece of metal that grabs onto the metal disc that protrudes from the charger and I verified that the metal is connected to the ground pin on the plug. When I connected it to my charger and plugged it in, the vibration that I was getting from the chassis is now gone ... so it appears that the only way to properly ground a mac book charger is by purchasing one of these cables.
                                  sigpic
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    Yes, you're returning the Y-cap leakage thru the EGC; the case (and V-) are now at GND potential. Or thru a resistor of 10-1000 ohms.
                                    Measure the resistance from the case to the line plug's ground pin with a DMM!
                                    "pokemon go... to hell!"
                                    EOL it...
                                    All style and no substance.
                                    guilty,guilty,guilty,guilty!
                                    guilty of being cheap-made!
                                      • 31029
                                      i find it interesting that some chinese company has to correct apples mistakes!
                                      • akc1956
                                        • Nov 2021
                                        • 9
                                        • Thailand
                                        #59
                                        Mine has the the contacts in the plug and they have continuity to plug earth pin. It is a A1466 macbook air, early 2015
                                          • 31029
                                          that may have earth continuity,
                                          but all the apple chargers i'v seen for the u.s. only have 2 pins.
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
