Weirdness with a filtered PWM through a coil
+ More Options
Posts
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    This is connected to the electromagnetic stirrer that I'm working on which I discussed in another post - for those who remember...
    Anyways, I wanted to smooth out the voltage going through the coils as I vary the voltage to get a smooth spin on the magnetic pill. And since I'm doing this project with an Arduino, I only have PWM to work with. So to smooth it out, I use an RC filter which initially works pretty good.
    Here is the input PWM vs filtered output before putting the load on it
    Then, I attach the coil and move the leads of the scope as per this drawing
    However, this is the final result...
    The voltage going through the coil seems to spike pretty quickly on the up and the down swing...
    Using photoshop, this image is more what I would LIKE the wave through the coil to look like.
    Is there anything I can do to smooth it out? I'm assuming that the spiking is because of the inductive properties of the coil?
    sigpic
    • 30970
    Re: Weirdness with a filtered PWM through a coil
    your going to see back emf from the stirer and backpulses from the coil itself - good luck trying to kill that.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Back EMF usually happens when you suddenly cut power or reverse it quickly, no?
      sigpic
        • 30970
        no, your stirer is in constant motion so when you have no coil pulse the stirer will transfer some current back into it. (because it is still in motion)
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          The "stirrer" will be the magnetic pill, and it will be in a liquid that is VERY vicious. It's going to offer plenty of resistance for the coils ... that's why I'm doing this in the first place. When I built one with a neodymium bar magnet (the strongest one I could find) and the same magnet in the pill ... got them as close together as I could, and the bar magnet just couldn't hold the pill down while it spun because the liquid was so thick. When these coils stop, that pill will stop really fast so it MIGHT induce a little emf into the coils for a fraction of a second, but not much, and I doubt it would be more than the mosfet could handle ... I could throw a diode in just in case.
          sigpic
            You need to correct the MOSFET, you show P-CH in your schematic, it will not work, the current will flow through coil straight to circuit ground via body diode of the MOSFET. Did you actually use P-CH MOSFET?
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              No, I am using an IRF520
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                You're dealing with the unpredictable gain of the transistor around its threshold and will be tough to do without a feedback system, perhaps with an op amp. Unless you have special needs I'd say do away with smoothing the pulses with PWM, you'll be fighting it to no avail.
                Plus as you have it now you'll be wasting quite a bit of power... alas it's all a tradeoff anyway.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Here's a corrected schematic
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Yeah the coils do get pretty hot fairly quickly when I apply 19 volts to them through the mosfet, which is still not powerful enough yet so I don't know what the final voltage will be ... I'm considering actually stacking two of these coils and connecting each stacked pair in parallel just because I need more magnetic flux from them ... but I haven't started playing with that yet, I want to get the timing down first.
                    sigpic
                      • 30970
                      i dont see how that circuit works,
                      the fet is voltage-driven, not current driven.
                      so once that 22uf cap gets charged - it stays charged.
                      shouldnt it have a parallel discharge resistor if your trying to use it as a "shock absorber"?
                        Also, are those screen shots of your Oscilloscope or screen shots of the simulation program?
                        The cap will have to be discharged through that 3K5 Ohms resistor when PWM goes low but if the PWM frequency is too high for that RC time constant then the cap will never be discharged completely. It also looks to me that the MOSFET is operating in linear region with that 3V of Gate drive.
                        What is the PWM frequency? Your screen shots are just hard to read/see.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8694
                          He probably programmed the driver to both source and sink current, so yes this should work as long as the RC delay is shorter than the desired low frequency cycle time... much shorter...
                          Scope of course.
                          If he wants to get the input to look like output, needs negative feedback to get amplification ratio down to 1:1.
                          Yep sure is, and he has to in order to get it to work the way he drew it, and then hence the concern about power.
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            My osciliscope.
                            If you click on the screenshot image, it should pull up the full-size version which is exactly what I see on my screen. All of the values are calculated by the software and shown at the bottom of the display under the wave.
                            It works ... you can see by the screenshots of my oscilloscope that it works... I think the cap discharges through the resistor maybe? Or maybe the load that I have attached to it which would be the gate of the mosfet.
                            sigpic
                            • redwire
                              • 3902
                              I see a problem with your project- the coil can only generate one magnetic pole or nothing- let's say it's the North pole. For any kind of motor or spinner, you also need to generate the opposite (South) magnetic pole.
                              Because current can only flow in one direction, the coil only makes a magnetic field to attract the magnet but not repel it.
                              So an H-bridge or AC drive current is needed for both directions. The sine-wave you are trying to make is only half a wave (of current) really. It goes up and back to zero but does not reverse polarity.
                              • chth96
                                How can I test coil whether it is really broken or not?
                                by chth96
                                I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                                I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                                I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                                I want to replace this round black fuse and unidentified coil if it got broken.
                                02-20-2024, 01:07 AM
                                A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                by momaka
                                More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                And a shot of the label:...
                                01-26-2022, 03:26 AM
                              • waterchill
                                What part is this coil from a MacBook A2681 ?
                                by waterchill
                                Hi everyone
                                I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                                So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                                IAny ideas? It is from a MacBook A2681
                                Thank you...
                                08-08-2024, 01:46 AM
                              • Gjackson
                                ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                                by Gjackson
                                Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                                01-13-2024, 10:34 AM
                              • chth96
                                How Can I identify IFT coil?
                                by chth96
                                I have a CD unit which is came from saturn game console.
                                It always perceived Any retail CD or CD-R as Audio-CD.
                                Of course I changed laser head and adjust pot of laser head nearby, but It always failed to perceive as saturn game CD.
                                I think that this problem probably begins When I tighten IFT coil too hard with small screw driver and suddenly I heard some kind of snap or cracking sound
                                I desoldered this IFT coil and It is 7pin IFT coil and written "4120 009 62VK" on the surface.
                                Is there any way to identify its frequency in order...
                                11-11-2022, 05:31 AM
