Can a microwave oven be used to reflow solder joint?
  • tmhobadcap
    • Apr 2019
    • 156
    • CANADA
    I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
    Is that possible? I do not want to try this unless I have a spare microwave oven.
    (I do not mean to suggest somebody to try this. It may be very dangerous. If you want to try, you are taking your own risk.)
  • R_J
    • Jun 2012
    • 9623
    Re: Can a microwave oven be used to reflow solder joint?
    In a word NO. The microwave energy will NOT heat the solder and any coils/ circles of wire will likely be destroyed.
    • tmhobadcap
      • Apr 2019
      • 156
      • CANADA
      Thank you!
        master hoarder
        • May 2008
        • 12175
        Well, whoever that somebody is... take your broken LED light bulb and hit him/her on the head with it, then tell them you heard from someone else that this is an alternative way to fix a dead LED bulb too.
        • petehall347
          • Jan 2015
          • 4448
          you can use an LED light bulb in a microwave
          • R_J
            • Jun 2012
            • 9623
            If you mean the lamp that lights the cavity, yes you can because it is outside the cavity and not exposed to the microwave energy.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3266
                • Singapore
                yea i've seen some weird and shocking things in my life. this one definitely takes the cake as one of the most weird and shocking i've ever heard! eek indeed!
                  • 31284
                  i thought the "rumor" somebody spread about fastcharging iphones with contactless charging in the microwave was better!!
                  • Matias80
                    • Nov 2020
                    • 7
                    • ARGETINA
                    The LEDs of the lamps are usually 30mA and inside they have 1, 2 or 3 LEDs, generating drops from 2.7v to almost 11v, I test them with a current limited laboratory source. Normally the LEDs burn out in those cases you can directly bypass and go
                    • brethin
                      • Dec 2008
                      • 1907
                      This thread needs to die, it's like a Biden commercial full of shit and worthless.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Microwave ovens do NOT like metal ... it's a great way to make a bunch of sparks and potentially ruin the element.
                        Now, a CONVENTIONAL oven could potentially reflow solder at the right temp. I had a 2007 Mac Pro video card stop working, and I stuck it in the gas oven at like 400 or 450 I think (might have been higher I can't remember) for 10 minutes (might have been longer), then took it out and let it cool and it worked fine after that. I can only assume there were some micro-fractures in a solder joint somewhere. The computer was about 9 years old when I did that.
                        Mike
                        sigpic
                        • valvashon
                          Sharp R-930CS microwave/convection oven, dim display
                          by valvashon
                          Older microwave/convection oven I picked for free on Marketplace. Previous owner replaced turntable motor which didn't fit in the mounting hole properly. Shaft was at an angle causing plastic thing that fits onto it to eventually break. Filed the hole bigger, fitted the motor correctly, put on a new plastic thing, all (almost) is OK.
                          The fluorescent display is quite dim. The camera doesn't see what the eye sees so these pictures are brighter than what the display really looks like:
                          As you can see even from these pictures, the tops and bottoms of the...
                          11-14-2025, 12:34 PM
                        • valvashon
                          Toshiba EM131A5C-BS microwave oven- noisy EE16 2.7 mH inductor
                          by valvashon
                          This poor microwave oven was purchased by my former employer in 2019 (it's a 7/2018 build) and lasted for about 3 months before making a terrible noise when in use. I determined that it was the main transformer and contacted Toshiba. They asked for a picture of the cord cut in half and the serial number, and then credited my boss' credit card. Rather than sending it to the e-waste, I bought a transformer on eBay and thought I'd try flipping it. Discovered that used microwave ovens aren't worth much but in for a penny, in for a pound as they say. It sat in my basement getting kicked and shoved...
                          02-20-2024, 10:38 AM
                        • bpjl
                          SEF 551.10 - Error starting the reflow oven.
                          by bpjl
                          When starting the SEF 551.10 reflow oven, the following problem occurs:
                          It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                          PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                          10-17-2024, 06:30 AM
                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                          - No Clean Formulations
                          - Low residue
                          - Range of activity to deal with different component solderability
                          - Halide free
                          - Suitable for dispensing
                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                          Both products are supplied in syringes or cartridges for application by dispensing....
                          10-07-2024, 06:02 AM
                        • goodpsusearch
                          Daewoo microwave oven repair
                          by goodpsusearch
                          One day my microwave oven stopped heating.
                          It would turn on and rotate the plate but no heat.
                          I removed the cover and checked components with digital multimeter.
                          Found that the high voltage fuse was blown.
                          This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
                          Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
                          I replaced fuse and tried to heat up a glass of water.
                          Strange noise...
                          01-24-2021, 03:56 PM
