Found a transformer at a thrift store and am curious...
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I don't know a whole lot about transformers beyond what they do functionally ... I've never made a circuit that incorporated a transformer so I've never had to spec one out or even figure out how they connect. The one time I tried to re-use a transformer from a circuit I connected it wrong and literally made a loud bang when I connected power to it ...
    Anyways, I found this one at a thrift store for $1.25 and was wondering if it could be used to step down 120V AC ... it looks like it was used somehow in an audio circuit as each side has what looks like a Common pin then a selection of wattage and on the other side, a choice of 4, 8, or 16 Ohms, which I assume is relevant to the speaker you're connecting it to...
    Why would a transformer be used in audio in the first place?
    sigpic
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    Re: Found a transformer at a thrift store and am curious...
    If you're younger than around 50 years or so, and unless you've studied old circuits, yes these are pretty much gone in today's electronics. In the past amplifying devices could not deal with speakers directly due to impedance mismatch. Specifically vacuum tubes and ancient transistors cannot deal with them.
    Current transistors can deal with speakers directly and thus transformers used in this manner are now obsolete.
    There are other uses for transformers in speaker circuits too other than the impedance mismatch but not as frequently used anymore either (speaker multiplexing)... And one purpose that may still be used (same reason why power transmission lines are high voltage...)
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I'm 48 and I studied electronics in a two year program at the local junior college back in 1990.
      This makes sense to me ... especially when using vacuum tubes... it had to be difficult building any kind of precision into a vacuum tube back then.
      So can this transformer be used to step down 120V AC into something ... lower than 120???
      sigpic
        It is typical line matching transformer use in PA system with multiple speakers.
        Lots of solid state PA amp still comes with 70V line out.
        https://www.belden.com/blog/broadcas...peaker-systems
        https://www.ebay.com.sg/itm/Realisti...x/273847933272
        https://www.ebay.com/itm/Realistic-3...-/113287352821
        https://en.wikipedia.org/wiki/Consta...speaker_system
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8709
          Yeah you probably never studied them unless you found a vacuum tube or ancient transistor radio and took it apart. These things were by low impedance transistor 1970s designs. The 1960s vacuum tubes and transistors were their last stand.
          Problem with speakers is that they're current controlled. I*R drop due to long wires makes sense to use higher voltage in long distance speaker runs.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I remember in the 70's, we had a Zenith television in the living room ... it was a kit that my dad built. At least once a month, he was always tinkering with that thing with a mirror in front of the screen and him behind the TV looking at the screen with the mirror, tinkering with settings. The television was a large floor unit ... a piece of furniture really ... it had a real "clicker" for a remote (not sure how those worked exactly) and it had two dials that had to be mounted on a motor because the clicker would physically turn the dials one channel at a time. When it would hit U(UHF) then the UHF dial would turn until it made a rotation at which point it would go through channels 2 to 13 before hitting U again.
            I remember going with him to Thrifty's quite often with a handful of vacuum tubes that he would check in their tester then sometimes hed end up buying a tube or two ...
            lol ... boy im glad we're past those days....
            sigpic
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8709
              Or is it better to long for those days again where the FRUs are much smaller?
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                FRUs?
                sigpic
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8709
                  Field Replacement Unit (i.e. replace a single transistor instead of a full PCB or even IC if a single transistor failed.)
                  Granted a single IC is physically smaller than a vacuum tube, but the IC probably has lots of good transistors in it
                  • R_J
                    • 9623
                    Here is a new 70 volt line transformer in the box, ebay $15.00
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8709
                      BTW I missed the original question, whether it can step down 120VAC. I doubt it or at least it probably would get hot. It was clearly designed for the audio range. You're better off locating a transformer marked for line voltage use.
                      • redwire
                        • 3912
                        OP you have a 10W 70 volt line audio matching transformer. It is used for bigger paging and PA speaker installations.
                        It is not suitable for use as a mains power transformer. It does not have high voltage isolation between primary and secondary, and at 120VAC it would be saturated. That and paper wrap is not the greatest for flammability.
                        The turns ratio is about 5.5:1 using the 16 ohm tap.
                        • PeteS in CA
                          • Aug 2005
                          • 3583
                          • USA, Unsure of Planet
                          Radio Shack speaker transformer, used to match to 16, 8, or 4 ohm speakers.
                          PeteS in CA
                          • Sparkey55
                            • Jan 2010
                            • 1523
                            I use some that are similar to that in my R-390A receivers to match 600 ohms to 4 ohms 6"x9" speakers.
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              Which ... from a design / quality perspective concerning the overall scope of the circuit, is probably a good thing...
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                So I got a deal at $1.25
                                sigpic
                                  • 31285
                                  only if you need it or can sell it.
                                  otherwise your out $1.25 - you could get a nice beer for that!
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    Tell me please where I can get a NICE beer for $1.25 .... anywhere ....
                                    sigpic
                                      • 31285
                                      i just drank one - a Shepard Neame "Bishops Finger"
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8709
                                        However from a enduser repair point of view, you have to get the exact same IC instead of the possibility of substitutions and jury rig fixes...
                                        I guess my fix count of stereo amplifiers is now 2. One of them I had to buy the STK IC module to repair it, the other I just took a random (well not totally random) transistor and stuck it in... both now fixed. The first one I had to wait weeks before I got the part. The second one I had an acceptable substitute in my junk bin. Not a perfect substitute but it still works nevertheless.
                                        The IC solution probably is cheaper to produce as there's no need to tweak pots to align the amplifier - all done for you. So basically it's all a matter of assembly costs. But when it fails, time to locate a possibly unobtainium IC...
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
