Found a transformer at a thrift store and am curious...
  • petehall347
    • Jan 2015
    • 4449
    Re: Found a transformer at a thrift store and am curious...
    Originally posted by eccerr0r
    However from a enduser repair point of view, you have to get the exact same IC instead of the possibility of substitutions and jury rig fixes...
    I guess my fix count of stereo amplifiers is now 2. One of them I had to buy the STK IC module to repair it, the other I just took a random (well not totally random) transistor and stuck it in... both now fixed. The first one I had to wait weeks before I got the part. The second one I had an acceptable substitute in my junk bin. Not a perfect substitute but it still works nevertheless.
    The IC solution probably is cheaper to produce as there's no need to tweak pots to align the amplifier - all done for you. So basically it's all a matter of assembly costs. But when it fails, time to locate a possibly unobtainium IC...
    it is possible to buy a kit to build stk packs .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8710
      If only radios came with the aftermarket STK packs and sell them at the same price of the hybrid...
      • learnmore
        Help choosing replacement transformer for Levoit 600S SMPS
        by learnmore
        Hello Community,
        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
        Peace
        LM...
        11-04-2025, 09:35 AM
      • ohren
        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
        by ohren
        Hello!
        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
        Measured voltages with no load:
        After rectifier diodes
        12V: 6.17 V
        5V: 5.67 V
        Secondary transformer pins AC measurement (really don't know if this says anything)
        12V: 2-2.5 V
        5V: 1.04 V
        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
        03-18-2023, 10:33 AM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • dennis_elx33
        3PHASE STEP-DOWN Transformer in Check
        by dennis_elx33
        Hello All,
        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
        Problem statement: Power tripped Off
        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
        Action Done:
        1) Replaced the faulty parts with good spare.
        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
        12-02-2024, 06:52 AM
        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-06-2024, 04:40 PM
