Running a microcontroller in car - power supply aspects
    • 30977
    Re: Running a microcontroller in car - power supply aspects
    the resistance will be in the datasheet
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #162
      Right, though that's assuming there IS a datasheet for these things
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        #163
        Yes, turns out I was almost right: the specs give a 27ohm resistance.
        Wattevah...
          • 30977
          nice parts, i like the way the contacts have low current pcb pins too.
          you could use the mcu to detect relay failure or motor/wiring issues through those pins!
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            #165
            Kinda running low on pins on the Mini TBH, though not a bad idea in the long run.
            Wattevah...
            • redwire
              • 3902
              You can use a resistor to lower the coil voltage from 12V to 5V. Like 47R and dissipating ~1.5W, regardless if a resistor or vreg or zener etc. the heat is made by something.
              A relay coil is mostly a resistor anyway, just wirewound with copper. They need a constant amount of power (not current/voltage) to work, so a 5V coil and 12V coil are the same power.
              If the relays are only on for a few seconds, then 1W resistors would work. Just takes up space.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                put a reverse biased 7V zener diode in series
                But yeah unfortunately damage's done, should have got the 12V units. Resistor is cheaper than zener, but you may need to calculate an appropriate value. And you can't get away with power consumption, it'll be significant, most of the relays I've seen when an option is given, the power consumption is the same when they're run at their rated voltages, meaning if you have to run on higher voltages, it will use more power overall.
                ... unless you PWM the input and filter it... HMM... heh heh heh...
                  • 30977
                  it's not an issue, the buck convertor can easily drive the arduino and the relays.
                  • CG2
                    Meaco Arete One / Deye Dehumidifier not working
                    by CG2
                    I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
                    Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
                    08-17-2024, 07:47 AM
                  • Kambi13
                    Samsung NP370E4K No backlight running on battery
                    by Kambi13
                    Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
                    Tried different battery - no change
                    Tried different screen - no change
                    Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
                    09-04-2023, 11:06 AM
                  • Dannyx
                    "Kinetic" 433Mhz transmitter/receiver discussion
                    by Dannyx
                    Good day folks.
                    TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
                    Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the...
                    03-08-2022, 11:01 AM
                  • Skgod
                    Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                    by Skgod
                    Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                    Black screen, freeze
                    The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                    When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                    So can anyone tell me what would be the possible cause?...
                    10-16-2024, 08:11 PM
                  • FALKLAN
                    Running Line Voltage and Integrating LED Pods - Automotive
                    by FALKLAN
                    Howdy everyone! I hope all is well where ever you are!
                    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                    02-05-2025, 12:30 AM
