"Kinetic" 433Mhz transmitter/receiver discussion
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks.
    TL;DR: has anyone tried pairing one of THESE "kinetic" battery-less switches with THESE generic remote modules ?
    Details: I recently got hit by this craze of wanting to add remote controls to the lights around my house, so I went with those generic 433Mhz remote relay modules found everywhere, which are really basic, easy to use and work well, since I used them before in other projects. What I like most about them is they accept all kinds of 433Mhz remotes that float around Aliexpress, since they're all the same under the hood, save for the differences in appearance.
    I thought I found the perfect solution without any headaches, but what flipped that around is this: I want to install RF wall switches to cover the holes left by the original wired ones and lo and behold, someone thought of this and basically threw the guts of a normal 433Mhz remote module inside a plastic shell with a flipper thing on the front that pushes the buttons inside, which is the same thing except it sticks to the wall - problem solved As I was getting ready to order a bunch of these, I came across something that looked even more tempting and interesting: a battery-free 433Mhz wall switch ! The so-called "kinetic" switch is their way of saying they don't require batteries. Without digging too much into the technology itself and how it operates - since I'm mostly focused on the aspect part now - I bought one myself from a shop in your country (knowing I can just return it if it doesn't work) and tried pairing it with one of those cheap relay modules I already had: long story short, it didn't work - it didn't pair.
    Ok, so apparently these kinetic switches don't play well with the generic 433Mhz modules I know and love so much, ALTHOUGH - and this is where it gets slightly annoying - the specs seem to be the same ! Check out THIS page on Ali which sells something very similar to what I got - it may not be the same exact product, but I bet it's the same thing. So we got:
    - Frequency: 433Mhz on both kinds - check. Got that out of the way straight away.
    -"Learning Code" (1527) on the switch itself and Learning Code(1527) on both the "official" receiver and the "cheapo" one - so check. Logic would dictate it's the same thing.
    -RF Working Mode: Superheterodyne Reception - check.
    -Modulation Mode: ASK - check....
    So what's going on ? There's probably more to it than that, like some sort of "data burst" the remote sends which is only understood by the "official" receiver. It can't be pre-programmed from the factory given they sell the transmitters separately and give you instructions on how to pair them, so there must be something in the radio wave itself that only their receivers pick up....either that or mine is broken and the "piezo" doesn't work, which makes me thing about how durable they are in the long run, despite their appeal of not requiring batteries. It's the same principle as a Bic lighter: the crystal probably dies eventually, so you're left with a hunk of plastic, in which case a regular battery remote wins in the long run. Since I want to return it, I'm not going to crack it open, though I was aching to do so...
    It's probably the same reason why original "Paradox" alarm panels for instance don't accept generic China remotes - I know this because I tried it myself at work, although I haven't tried it the other way around: Paradox remote on cheapo receiver. This opens up two questions: why the incompatibility between the two and would it work the other way around ? Would the receiver for those kinetic switches accept a "standard" remote ?
    EDIT: BigClive did a video on something very similar and at around 4:26 he mentions how it won't work with a regular 433Mhz switch, so the microcontroller is probably different, despite the specs being similar, at least on paper - I need a crash-course on 433Mhz remotes
    Wattevah...
  • jesterace
    Samsung B2030HD IR Remote Receiver Dead, shorted micom?
    by jesterace
    I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
    Tried installing latest firmware but no change.
    TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
    Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
    10-26-2022, 02:20 AM
  • CdDvdFlash
    DSE GE6878 possible TV receiver dying remote not working well
    by CdDvdFlash
    For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
    07-03-2024, 03:55 AM
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
