Car LED Headlights dimmer?
    Re: Car LED Headlights dimmer?
    If it is boost/buck type circuit inside to maintain constant current then I do not expect it to dim down when placing resistor (or MOSFET) in series to cause it to dim down, and if you lower the input Voltage to the regulated circuit then input current will go higher to maintain the same output power.
    His second picture shows dimmer lights and lower current draw.
    • redwire
      • 3912
      A picture of the pcb inside the LED lamp would help.
      BigClive did a teardown of one with a fan on the end and datasheets of QX9920 IC and sch.
      https://www.youtube.com/watch?v=CX_uFs5vKc0
      • capwizard
        • Jun 2016
        • 1991
        Originally posted by redwire
        I think we're assuming the LED headlamp is like a light bulb, a linear load.
        But inside is most likely a boost/buck converter.
        So supplying the LED lamp with 10V or 15V should give the same (constant) power to the LED's and not really dim it.
        The led light dimmer worked very good wild range adjustment, the very good linear adjustment from very dark to maximum brightness.
        When I pulled the led light out, no heat dissipation, led overheat right away, not enough time for meter to read. Pic1, 2, 3
        • redwire
          • 3912
          You can lower the buck-converter output current by removing one or two of the three sense resistors R2, R3, R4 that are 0.25R each.
          If the 6-pin IC is QX9920, roughly... all three = 3A, two = 2A, one =1A current to the LED's. The fan is 9V so it might be a 9V LED array.
          I'm guessing:
          9V 3A to the LED's is 12V 2.25A input
          9V 2A to the LED's is 12V 1.5A input
          9V 1A to the LED's is 12V 0.75A input
          • capwizard
            • Jun 2016
            • 1991
            Your inference is very correct.
            BigClive, He explained very well. I can add a little bit more here.
            COB LEDs are 3 in each row and 10 in each line. Total 30 in my case. If leds are 3.3v then driver voltage will be 9.9v.
            This is like putting all the LEDs of a 50-inch TV on two sides of one stick. That's why the stick is so hot. I have been using it for half a year, so far so good maybe is because of the fan.
            One thing I don't understand is why they don't use 12 volts directly.
              • 31281
              because a car is not 12v, it's as low as 11 when stopped with a low battery and as high as 14.8 when charging (or worse if the alternator is shit)
              • capwizard
                • Jun 2016
                • 1991
                Originally posted by budm
                The Voltage reading of 12.17V @.177A, is it the Voltage reading on the LED terminal or on the input feeding Voltage to the circuit. What is the Voltage between S and D pin of the MOSFET? Once you know that then you can calculate the Power dissipation of the MOSFET.
                The Voltage reading of 12.17V @.177A is it the input feeding Voltage to the circuit.
                Sorry took a long time to answer this question because of pic1. As sti predicted, the breadboard is melted.
                So I added a heat sink. Circuits are too simple to be true. Let's test for 3 days.
                Next, I gonna put two led headlights to one MOSFET see what's going on?
                  I cannot tell from the pictures as to what Voltage you have between the S & D pin of the MOSFET.
                  • capwizard
                    • Jun 2016
                    • 1991
                    I soldered Fluke test leads on S and D pins of mosfet already.
                    Full lightness is 11.9v at 2.478A.
                    12.4v at 0.178A
                    12.18v at 0.102A
                      https://www.badcaps.net/forum/attach...1&d=1549771216
                      That cannot be right since the MOSFET is in series with the load, so if you have 11.9 V at full brightness between S and D then the load will barely has any Voltage on it.
                      And at 11.9V @ 2.478A that will be lots of Wattage.
                      • capwizard
                        • Jun 2016
                        • 1991
                        I connected two led lights together, reading is from a 12v power input at full brightness. Pic 1
                        • capwizard
                          • Jun 2016
                          • 1991
                          12.24v @ 4.825A for two lights. Mosfet is 50A that means OK.
                            But as you know in series circuit, if you have 12V between S and D pin then how can you have any Voltage left for the LED?
                            BTW, it is not just the current rating, you have to consider the power dissipation also to keep the junction temperature at the safe level so proper heatsink is required.
                            Right now you are operating the MOSFET in linear region.
                            https://cdn.badcaps-static.com/pdfs/...f668f60e6d.pdf
                            https://www.powerelectronics.com/dis...mode-operation
                            • capwizard
                              • Jun 2016
                              • 1991
                              My bad, I am so Inteligente, series the meter leads to S and D, it should be parallel.
                              I used a more simple circuit and in the future only use one resistor.
                              • capwizard
                                • Jun 2016
                                • 1991
                                I used a more simple circuit and in the future only use one resistor. Because potentiometer is not easy to find in Africa.
                                My idea is car has dim lights during the day. At night auto turn on and switch with full or half full light.
                                Pic 4 is at full brightness.
                                I double posted again...cellphone.
                                I have a dream......can we use this idea applies to the tv led backlight, forced to the people who refuse to reduce their brightness.
                                  Well, when Data does not make any sense then you know something is not done right. Data is important to me.
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    MOSFETs Withstand Stress of Linear-Mode Operation....in this article I can't find fig. 1 ,2, 3, 4, 5 ?
                                    an extended forward-bias safe operating area (FBSOA).
                                    MOSFET is subjected to high thermal stress due to the simultaneous occurrence of high drain voltage and current resulting in high power dissipation. When the thermo-electrical stress exceeds some critical limit, thermal hot spots occur in the silicon causing the device to fail.
                                      • 31281
                                      yes, so use PWM like it already does.
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        Or, a big heat sink? PWM IC is not easy to find in Africa.
                                        I used half brightness, mosfet is not hot at all.
                                        When I used full brightness, mosfet is getting hot, still touchable, the way to solve this problem is full brightness just bypass it.
                                        No needs mosfet just use a coil from a hairdryer make 2.5A x 12v=30w current limit resistor.
                                          • 31281
                                          you think africa cant get arduino nano's??
                                          • marce002
                                            Replacement for LED DIMMER chip
                                            by marce002
                                            Hello I have a led lamp with 3 TP8005S chips. one is shorted but cant find a replace part around.
                                            .. is it easy to replace with another option? it is just on /off led lamp for scooter... low beam and high beam are working just fine...
                                            11-16-2024, 04:17 PM
                                          • CG2
                                            LED uplighter dimmer burnt resistor
                                            by CG2
                                            I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                                            02-14-2024, 09:23 AM
                                          • Hairspring
                                            Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
                                            by Hairspring
                                            In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
                                            Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
                                            Anyhow,...
                                            12-04-2022, 11:18 AM
                                          • MrCreosote
                                            2 Belkin KVM switches have dim VGA output
                                            by MrCreosote
                                            When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                                            4-port Omniview Pro2 f1dz104t
                                            8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                                            The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                                            AD ADAPTER:
                                            There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                                            08-15-2023, 08:26 PM
                                          • Storyteller12
                                            Sony XBR-65X850E No Power
                                            by Storyteller12
                                            Tv won't turn on. Not sure if there is a standby light on this TV but I'm not seeing any.
                                            Checked the usual diodes that go bad and all test good. When plugged in 2 show 100v and the other 2 50v when plugged in.
                                            Below is reading for CN6401
                                            1) 0v - blinking
                                            2) 0v - pwm1 dimmer
                                            3) 0v - DC dimmer
                                            4) 0v - 0wm2 dimmer
                                            5) 3.5v - Standby
                                            6) 0v - pwm3 dimmer
                                            7) 0v - BL On
                                            8) 2.6v BL Error
                                            9) 3.5v PWR On
                                            10-12,19-24) 0v - ground
                                            13-18) 12v all pins - 12v reg
                                            07-26-2023, 12:15 PM
