Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
  • Hairspring
    • Dec 2022
    In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
    Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
    Anyhow, in my ignorance, I thought maybe the fault was due to some problem in the power supply. A replacement board from a salvage company was only a tenner. However, replacing that the fault is still identical.
    It's an LG 19LD350 19" TV. Any suggestions, please?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
    Is auto dimming turned off?
    • Hairspring
      • Dec 2022
      Thanks for following up. I can't recall. It will be 2 or 3 days before I can check, I'll reply then.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • ahoonid
        MacBook Pro A1398 L2013 weird jumping screen.
        by ahoonid
        Hey everyone.
        I have a 820-3787-06 board from a MBP A1398 which has a screen issue. The problem starts with a bit of noise just like old TVs when booting and when the OS is on, screen jumps are added to the little noise on the screen. The jumps are millisecond and go back to the original place.
        Since there's a little crack in the corner of the screen, I thought it has to be the display. But to my surprise it wasn't since I tried it with a fully functioning screen.
        The same issue isn't happening with an external display. I did a gpu/cpu stress test on external...
        02-07-2024, 05:56 AM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
