Replacement for LED DIMMER chip
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello I have a led lamp with 3 TP8005S chips. one is shorted but cant find a replace part around.
    .. is it easy to replace with another option? it is just on /off led lamp for scooter... low beam and high beam are working just fine...
    Marcelo J
  • marce002
    • May 2018
    • 316
    • Argentine
    this is the shorted part. looks like mosfet.... found led drivers from burned house applianced leds , but theyare not suitable for this, they are buck led drivers 8 pins. any help will be muuuch apreciated.thks
    Marcelo J
    • truclacicr
      • Apr 2019
      • 352
      • australia
      This supplier is regarded as trustworthy by the people at EEVblog:
      https://www.lcsc.com/product-detail/LED-Drivers_TPOWER-TP8005_C382140.html
      https://www.lcsc.com/datasheet/lcsc_datasheet_2407090923_TPOWER-TP8005_C382140.pdf
      (datasheet}
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • ebugs
        Asus laptop EC/SIO chip replacement
        by ebugs
        Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
        I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
        I found the EC chip...
        09-14-2024, 02:09 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • capoplays
        Help with BIOS update on Dell G15 5515 after chip replacement
        by capoplays
        Hey everyone,
        I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
        The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
        When I check the BIOS using the F12 menu Flash...
        10-24-2025, 06:53 AM
