LED uplighter dimmer burnt resistor
  • CG2
    • Nov 2022
    • 37
    I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple way to calculate what value that resistor should be, but it's beyond me. If it's relevant, the lamp is supposed to hold two 6W dimmable 240v led bulbs. Thanks in advance to anyone who knows the relevant maths.
    • 31248
    it's a traditional dimmer circuit with a smaller triac,
    not really suited to driving leds - just saying.
    is the diac shorted?
    • redwire
      • Dec 2010
      • 3912
      I would say the triac is dead, they can go open circuit and then the drive circuit burns up. BT132 is only good for 1A. Check the potentiometer is still OK before deciding to repair or throw it out. It could be burnt the carbon tracks inside near the full brightness end. It should be 500k ohms.
      The burnt resistor is around 2.2k 1/4W and up to 10k ohm will work too.
      Jing Neng Dual Dimmer Switch JN6230D, JN6230DM-2 repair
      • CG2
        • Nov 2022
        • 37
        Thanks. The triac checks out OK, but it looks as if the diac went instead. The potentiometer is gone as well, but they seem to be available cheaply on aliexpress https://www.aliexpress.com/item/1005005632064132.html The wiring on this is scarily thin. I'm guessing that someone stuck in a couple of 60W bulbs and that killed it.
          • 31248
          you can get entire dimmer modules for almost nothing on ali,
          it may be cheaper to do that and swap the parts over
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            I'd imagine that DIACs (btw how do most people test these without a high voltage curve tracer?) would fail short or end up blackened/burned, and it's not conclusive here if you see an open DIAC with a modern multimeter?
              • 31248
              i would just check if a diac is shorted
              • CG2
                • Nov 2022
                • 37
                Is it that hard to test diacs? It looks OK and isn't shorted. My "test" was to connect it up to one of those cheap component testers which said "defect device" The triac checked out OK on the same bit of kit. Those little diacs cost virtually nothing anyway, so I've ordered some, but might try changing just the potentiometer and see what happens.
                  • 31248
                  big clive has a video or 2 that are interesting
                  https://www.youtube.com/watch?v=w71Qr1ygB_Y
                  https://www.youtube.com/watch?v=SRUzMd3lwLQ
                  • trickartt
                    Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                    by trickartt
                    Hello Badcaps!
                    I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                    This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                    05-04-2024, 12:07 PM
                  • sparcktikus
                    Ersa Rds 80 soldering station burnt resistor
                    by sparcktikus
                    Hi
                    I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                    I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                    The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                    Many thanks...
                    04-04-2023, 04:29 AM
                  • electomech-fixer
                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                    by electomech-fixer
                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                    09-15-2025, 01:42 AM
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
                  • ttmi100x
                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                    by ttmi100x
                    Greetings everyone,
                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                    Upon closer inspection...
                    07-31-2024, 06:36 PM
