Car LED Headlights dimmer?
  • capwizard
    • Jun 2016
    • 1991
    i bought Car LED Headlights but Headlights are getting far too bright.
    How can I prevent people from dazzle by dimming the headlight? use resistors?
    i would like to have Hi-Lo switch or adjustable brightness potentiometer.
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Car LED Headlights dimmer?
    Ain't gonna happen. Each "lamp" is a "smart module" that you'd have to reengineer to alter the lamp current.
    But, you can take steps to ensure your lights are aimed properly! There's a (visible!) "notch" in the headlight's output that you use as a reference when checking their "aim" (shining the lights on a building while located on flat ground).
    I noticed lots of folks flashing their brights at me (while I was on low beam) and took the time to verify that mine are aimed properly. Too bad for the other folks!
    • capwizard
      • Jun 2016
      • 1991
      they are cheap ($12 per pair) aftermarket Car LED Headlights, i try to DIY an add-on dimmer switch, I don't want to hurt someone's eyes.
      After I've installed the headlights, I though were pieces of junks, on the contrary, they are very powerful. All the road signs and road surface markings become more clear but at the same time, it is also very easy to make people dazzle.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        they are cheap ($12 per pair) aftermarket Car LED Headlights.
        Ah! I can't help you, then. Mine are OEM'd with the vehicle. I suspect yours will have a switch-mode current driver that takes whatever "battery" is available and pushes a fixed amount of current into the diodes. You'd have to tweak the "set point" for that regulator to reduce their brightness.
          • 31277
          make sure you have lots of space behind those for cooling.
          the big mistake some people make is putting the original cap/dust cover back on.
          • petehall347
            • Jan 2015
            • 4448
            • United Kingdom
            if you get freezing weather and snow you may have to fit heaters for the lenses
            • capwizard
              • Jun 2016
              • 1991
              My idea is this: isolate original power supply then get my own power supply from battery and add control circus for headlights.
              Led strip dimmer controller | using one mosfet
              https://youtu.be/mnJCRR3yoDU
              In the meantime. I try to put a Cds (photo cell) sensor so I can control headlights automatically.
              Automatic night light circuit diagram using mosfet
              https://youtu.be/UaVFRyObpkU
              • redwire
                • 3912
                Did you check and adjust the cutoff?
                With retro-fits, low beam ends up is too high and blinds oncoming drivers.
                This might be "too bright" - instead of it being the LED brightness.
                It's really bad with retro-fitting projector-style headlights with HID, you need a shutter to cutoff the beam top.
                • capwizard
                  • Jun 2016
                  • 1991
                  Did you check and adjust the cutoff.
                  Yes. I adjusted by shooting light on the wall.
                  But pretty much nothing to adjust . the LED light sockets fit right in. That's why I need light dimmer.
                  • capwizard
                    • Jun 2016
                    • 1991
                    Super Simple Dimmer Control Circuit 3/6/9/12V
                    https://www.youtube.com/watch?v=H_jKrGJN5Fk
                    DC DIMMER WITH ONLY ONE MOSFIT
                    https://www.youtube.com/watch?v=-bwdRlxvrw4
                    How To Make a Simple Touch Switch Circuit
                    https://www.youtube.com/watch?v=nux_M2fEqBc
                    • capwizard
                      • Jun 2016
                      • 1991
                      Car LED Headlights
                      What I want is to turn on the headlights automatically at night. When the night light is on, I can adjust the intensity of the light.
                      Can this circuit I designed be implemented? pic 1
                        • 31277
                        no, it will get too hot.
                        you need pwm squarewave.
                        drive the fet with a microcontroller or a 555 timer or a 4011 cmos chip
                          You need pwm squarewave.
                          Drive the fet with a microcontroller or a 555 timer or a 4011 cmos chip
                          +1
                          BTW, what is the current draw of that LED assembly?
                          Link to where you buy it from?
                          • capwizard
                            • Jun 2016
                            • 1991
                            I bought it over Aliexpress, $12.78 for a pair, now they out-of-stock but I think they still have similar products.
                            In fact, this headlight does not use a lot of current, 12.11v @ 2.38A. I have done experiments before, I just used an irfz44 (60v 50A) could control the car headlights and it won't get too hot.
                            My goals are to let it be easy to make and not too complicate. The main purpose is to help peoples in developing countries.
                            In the meantime, I would like to use STM32 then write a program to control the LED heard light sequence.
                              The lamp is rated at 72W so how is it related to 28.8W?
                                • 31277
                                maybe both together, driven at 14v???
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  Maybe in the car battery is 13.5v not 12.11v.
                                  They mention about 24v. Maybe uses 24v or a pair leds total power.
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    I will let this led light dimmer turn on for at least 3 days see what will happen? Pic1, 2, 3
                                    Pic4 MOSFET is from junk board 50N06 (60v, 50A).
                                    Ps..each LED head light has 60 of small leds, each side has 30 of them. I counted on pic 1. The back dot in pic 1 is the dust.
                                      The Voltage reading of 12.17V @.177A, is it the Voltage reading on the LED terminal or on the input feeding Voltage to the circuit. What is the Voltage between S and D pin of the MOSFET? Once you know that then you can calculate the Power dissipation of the MOSFET.
                                      • redwire
                                        • 3912
                                        I think we're assuming the LED headlamp is like a light bulb, a linear load.
                                        But inside is most likely a boost/buck converter.
                                        So supplying the LED lamp with 10V or 15V should give the same (constant) power to the LED's and not really dim it.
                                        • marce002
                                          Replacement for LED DIMMER chip
                                          by marce002
                                          Hello I have a led lamp with 3 TP8005S chips. one is shorted but cant find a replace part around.
                                          .. is it easy to replace with another option? it is just on /off led lamp for scooter... low beam and high beam are working just fine...
                                          11-16-2024, 04:17 PM
                                        • CG2
                                          LED uplighter dimmer burnt resistor
                                          by CG2
                                          I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                                          02-14-2024, 09:23 AM
                                        • Hairspring
                                          Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
                                          by Hairspring
                                          In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
                                          Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
                                          Anyhow,...
                                          12-04-2022, 11:18 AM
                                        • MrCreosote
                                          2 Belkin KVM switches have dim VGA output
                                          by MrCreosote
                                          When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                                          4-port Omniview Pro2 f1dz104t
                                          8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                                          The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                                          AD ADAPTER:
                                          There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                                          08-15-2023, 08:26 PM
                                        • Storyteller12
                                          Sony XBR-65X850E No Power
                                          by Storyteller12
                                          Tv won't turn on. Not sure if there is a standby light on this TV but I'm not seeing any.
                                          Checked the usual diodes that go bad and all test good. When plugged in 2 show 100v and the other 2 50v when plugged in.
                                          Below is reading for CN6401
                                          1) 0v - blinking
                                          2) 0v - pwm1 dimmer
                                          3) 0v - DC dimmer
                                          4) 0v - 0wm2 dimmer
                                          5) 3.5v - Standby
                                          6) 0v - pwm3 dimmer
                                          7) 0v - BL On
                                          8) 2.6v BL Error
                                          9) 3.5v PWR On
                                          10-12,19-24) 0v - ground
                                          13-18) 12v all pins - 12v reg
                                          07-26-2023, 12:15 PM
