gas cooker ignition
    • 31281
    gas cooker ignition
    i have one of these:
    https://allegro.pl/oferta/generator-...ska-7247049917
    does anybody know how you wire a 230v ignitor, or have a cooker schematic??
  • capwizard
    • Jun 2016
    • 1991
    Re: gas cooker ignition
    Originally posted by stj
    i have one of these w10t-4a
    here you're it is for 4 burner gas cooker
    Spark Generator Replacement Kit - RH Peterson
    https://cdn.badcaps-static.com/pdfs/...e274a1f901.pdf
    F1, F2, F3, F4 – Elektrody zapalające (Incinerating electrodes to 4 burner gas ignitors )
    Generator wysokonapięciowy ----- high voltage Generator
    4 palnikowe szt.1 ------------------4 burner pcs.1
      • 31281
      nice.
      what's confusing is the meter readings - it must have capacitors or something inside with the windings.
      also where is the HV return???
      i see the primary,
      and 4 seconary's for the electrodes but no ground??
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Probably returning to GND... so does the igniter light all units at the same time regardless if it's needed or not? I guess it should be fine, cars do it all the time...
        • capwizard
          • Jun 2016
          • 1991
          ....the igniter light all units at the same time ......
          you're right. as same as gas BBQ grills.
          i think they are build-ed inside ignitor.
          DOKUMENTACJA TECHNICZNO-RUCHOWA LINIA 900 KUCHNIE GAZOWE
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            not sure what meter readings you're referring to, but there must be duty cycle and current limiting inside the igniter, implying some sort of RC delay of sorts. Unfortunately the igniter is potted and no schematic is available?
            Last time I had worked with a gas range, it seemed it had its own igniter per hob, I guess they've cheapened it since then...
              • 31281
              i tried to get the resistance of the windings, they look open.
              but they arent - it's a new module!!
              reason for the questions is i want to re/mis-use it.
              • redwire
                • 3912
                It is probably like a motorcycle wasted spark ignition, where one floating secondary connects to two spark plugs. So this igniter has two secondaries, four terminals.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  Ahhhh... okay now I understand.
                  Yeah I would imagine there first needs to be some sort of isolation from mains to the outputs. That's one isolation.
                  Then I would imagine there may be a multiplier but that should show up as a high voltage diode in one direction... But don't know how they're designed inside the potting...
                    • 31281
                    it does not explain where the HV return is.
                    i see in a cooker it sparks to mains earth, but the module has no connection to it.
                    • capwizard
                      • Jun 2016
                      • 1991
                      sti: .... no resistance of the windings.....
                      no resistance of the windings is because transformer uses floating earth ground for safety reasons. when you have 2.4kv...anywhere can be ground....
                      it is an electrical resonant transformer circuit....a miniature Tesla coil or high voltage spark transformer.
                      you can use variac change 1/10 AC input voltage to ac 22v , make output voltage to 300v then add a diode and caps, now you have DC 320v for TV LED tester. or use for High voltage electronic fence. i think it has too much current for electrostimulation...I do not recommend.
                      eccerr0r.....a high voltage diode.....
                      i bet you inside this module just one Tesla coil no diode....and no HV cap.
                      • capwizard
                        • Jun 2016
                        • 1991
                        TS/W10T-4A HV module maybe has 30pf / 100m ohm bypass circuit and it generates more than 20 kv . Be very careful when playing with that.
                          • 31281
                          i had a thought,
                          maybe the secondary output and return are the first 2 connections and they arc to each other via the cooker body.
                          that's gonna complicate shit - i only want one spark - have to build a "safe" spark gap for the other pin.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            I also wonder what it will do with open outputs, or do they need to be insulated off...
                            Dang, what are you trying to "misuse" this in?
                              • 31281
                              i have it worked out now.
                              each pair of outputs is a secondary.
                              if you use both then it arc's via the cooker, but if you only use one then you ground the other end.
                              so the 4 output model actually has 2 secondary output coils.
                              to answer the last question, i'm trying to repair a Miele industrial cloths dryer with a 400€ ignitor failed in it!!
                              i'm not paying fucking 400€ when a brand new polish 4way ignitor costs under 3€ !!!!
                              • capwizard
                                • Jun 2016
                                • 1991
                                That's great, you saved a lot of money but if you use bug zapper it will save even more $ but the quality is not good.
                                  • 31281
                                  i cant put a bug zapper in a comercial repair!!!
                                  this shit will be used every day in a hotel!!!!
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    Iol
                                    What's why, you have a repeat business.
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      hope the appliance has a thermocouple .
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        in US we use Silicone Carbide Ignition or spark module for gas oven.
                                        How it works: Silicone Carbide Ignition
                                        https://www.youtube.com/watch?v=M02AIkraWH0
                                        How Does a Gas Range & Oven Work? — Appliance Repair Tips
                                        https://www.youtube.com/watch?v=hweqe2tPklo
                                        • Dannyx
                                          Wind generator charger schematics (or load of baloney ?)
                                          by Dannyx
                                          Good day folks. A former colleague of mine recommended me to a relative of his and I got to speak to this man today in person. He's a bit of a mad scientist/tinkerer sort-of guy - just my kind of weirdo Apparently this chap builds all sorts of generators and wind turbines in his little shop at home and sells them here and there. He even showed me some footage of some of his inventions in action out in the field. However, as he himself very kindly put it, he's not good with electronics - he just designs and builds the generators (from scratch, I might add) and turns to others for the electronic...
                                          09-16-2022, 11:13 AM
                                        • PM5K
                                          Inverter Generator Repair
                                          by PM5K
                                          I have an inverter generator that has two bad caps. One blew and the other was swollen.
                                          My main issue is that the power supply
                                          is encased in some type of epoxy.
                                          My main concerns are regarding the epoxy and its purpose. I can imagine that it helps with vibration should I also be concerned with sparks since it's a gasoline generator?
                                          The plan is to break off the old caps, cut the old legs off, clear out the solder points, then solder from the top since I cant get to the backside of the board.
                                          This means that the legs of the caps...
                                          01-13-2023, 03:15 PM
                                        • jason123
                                          Agilent 33220A 20 MHz Function Generator
                                          by jason123
                                          I can't find a forum to discuss "instrumentation Troubleshooting", but PS maybe the closest.
                                          So, I'm having an issue with about 13 year old Agilent Function Generator. it works, passes self-test, but it has an annoying "audible" noise, that changes as I change the output frequency setting of the instrument. Prominent around 600 Hz and up (at least that's what my ears are picking up.) I saw on some forms that it could be fan, linear regulator, dried up caps,... I can't seem to find the source of audible noise. Here is what I tried:
                                          1. Turn the output off - still...
                                          07-01-2025, 08:12 AM
                                        • mariukonie
                                          Induction hob PCB VESTEL 20fr25 from cooker Rangemaster propl60eibl help needed.
                                          by mariukonie
                                          Hi. Could anyone with knowledge advise if this pcb in photos can be repaired? I'm willing to spend time and money on it to gain experience however I searched net for schematics and couldn't find so it's impossible to know what are some of burnt components. I can't find any second hand replacement board and new one is out of my budget and it exceeds value of cooker. I'm new to this forum but have had few successful pcb repairs of tv's and cooker pcbs and also made few working circuits for fun. Any help appreciated. Regards....
                                          08-23-2023, 08:19 AM
                                        • tibd
                                          Help with parkside induction cooker controller IC.
                                          by tibd
                                          Hello.
                                          I am troubleshooting a parkside induction cooker. The bord had a microcontroller ic with marking IH001 (dip24) which i think is faulty. Any ideas what this IC is, to purchase internationally? Otherwise there is a VIPer12a which seems working fine. No other defective components were found.
                                          Best regards.
                                          12-26-2024, 10:11 AM
