Help with parkside induction cooker controller IC.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Hello.
    I am troubleshooting a parkside induction cooker. The bord had a microcontroller ic with marking IH001 (dip24) which i think is faulty. Any ideas what this IC is, to purchase internationally? Otherwise there is a VIPer12a which seems working fine. No other defective components were found.
    Best regards.
  • truclacicr
    • Apr 2019
    • 352
    • australia
    Is this it?
    https://gw.alicdn.com/imgextra/i4/TB...0-item_pic.jpg
    • tibd
      • Oct 2014
      • 189
      • Sweden
      Yes thats it, Any chance to know where to shop?
      • Gjackson
        SMEG induction cooker error EA on both left hand side cooktops
        by Gjackson
        I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
        07-09-2024, 01:46 PM
      • master3112
        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
        by master3112
        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
        10-29-2024, 09:32 PM
      • mariukonie
        Induction hob PCB VESTEL 20fr25 from cooker Rangemaster propl60eibl help needed.
        by mariukonie
        Hi. Could anyone with knowledge advise if this pcb in photos can be repaired? I'm willing to spend time and money on it to gain experience however I searched net for schematics and couldn't find so it's impossible to know what are some of burnt components. I can't find any second hand replacement board and new one is out of my budget and it exceeds value of cooker. I'm new to this forum but have had few successful pcb repairs of tv's and cooker pcbs and also made few working circuits for fun. Any help appreciated. Regards....
        08-23-2023, 08:19 AM
      • ronnygracias
        Help with freemotion incline trainer with controller comm error
        by ronnygracias
        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
        11-04-2024, 01:32 PM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
