Need help to ID this transistor
  • CapLeaker
    Leaking Member
    • 8327
    Re: Need help to ID this transistor
    Originally posted by redwire
    This (fake?) website teases with Cummins Celect ECU schematic but I couldn't download it. To at least find out what the part is.
    The big black donut is a potted toroid inductor for the boost-converter.
    I wonder if carefully hacksawing the lid off the TO-3 would reveal any die markings?
    I found this: https://www.slideshare.net/HugoNelso...-63-dschematic
    and one can see all 5 pages, but I still can't read anything. I can't DL that file on that link you posted either. Die markings.... maybe worth a shot.
    Originally posted by stj
    russian search engine works well
    start here:
    http://garageforum.org/Thread-Cummins-Schematics
    That's what I saw at the shop, but it doesn't show the internals of the ECM.
      • 31197
      so that gets this:
      (interesting that it's designed by Motorola!)
      • R_J
        • 9588
        Here is the info plus some other information in PDF But I believe it is for a different model ecm
        • CapLeaker
          Leaking Member
          • 8327
          so that gets this:
          Thanks stj! Yes, that's on that link. But the resolution sucks so bad that I can't really read it. Yes, there are a bunch of Motorola IC's in there.
          I think the part I am looking for is on page 4, top left, VGB supply. In the middle of that schematic part is a transformer and a MOSFET.
          So this would account for then for the unit not to power up anything, no dash light's etc.
          • CapLeaker
            Leaking Member
            • 8327
            R_J and stj, you guys are great!
            R_J, there are similarities between those two ECM's. Look at the Cummins N14 Celect ECM digramm (your second upload from top). The VGB supply on page 4 top left. They do have a different part number though, then what I took out.
            • R_J
              • 9588
              The second file I uploaded should be the one you want. I was going to upload it earlier but I could'nt see that transistor number anywhere in the schematic
              • CapLeaker
                Leaking Member
                • 8327
                The second file I uploaded should be the one you want. I was going to upload it earlier but I couldn't see that transistor number anywhere in the schematic
                Q311 MTD3055EL. They got rid of the TO-3 style FET in your schematic. Problem is that the gate drive IC (IC300 LM2901D in your schematic, a different Motorola IC in mine) may be shot too, since the TO-3 is shorted across the pins.
                • redwire
                  • 3912
                  That's a help, sheet 4 shows the "Vgb" and "boost" supply. At least you can see the main sections. It's all quad-comparators and op-amps for the driver in this sch.
                  I'm stuck on the TO-3/TO-204 pinout, doesn't match any (MOSFET/BJT) part I can find. What am I missing in the pic? Means this custom part has a flipped pinout?
                  • CapLeaker
                    Leaking Member
                    • 8327
                    I've thought on the same pin out. There is something else I don't understand.
                    There is a dead short between the D and G pads. So I removed that green SMD resistor marked 2211 going from that G pad and I still have a short. It should be a total open. So there must be a third layer on that board.
                    • CapLeaker
                      Leaking Member
                      • 8327
                      There is at least one more layer if not another one on that board. So we are talking 3 or 4 layers on that board. They don't made that easy.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Are there any more connection hints under the glued white insulator on the top side of the board? Or is it silkscreen ?
                          • 31197
                          yea rip that pad off.
                          i would fit any replacement with a low-profile heatsink anyway.
                          • redwire
                            • 3912
                            The gate connects to other stuff besides the 2211 resistor. I'd guess a nearby SOT-23. I think it's 4-layer pcb.
                            I use needle-probe or dental pick with an alligator lead to my multimeter, to poke through the conformal coating without cracking parts.
                            • CapLeaker
                              Leaking Member
                              • 8327
                              This is what I on top with the heat pad removed and a flash light shining on the back side of the board.
                              redwire: problem is that I have a dead short of 0.12 Ohms between those two TO-3 pins with that 2211 resistor removed. So there must be another trace going from that pad somewhere else which I can't figure out due to other components being in the way. All TO-220 style packages are O.k. No shorts on any of the bigger stuff. Any surrounding SOT-23 hasn't have any shorts either. So I thought maybe there is a Schottky diode across those pads creating that short (but this doesn't make any sense to me either), but couldn't find anything else shorted yet.
                              stj: Yeah... I thought on that, but with all the vibrations in a big rig, I am a bit skeptic about things falling apart inside after a while.
                              • paulstef
                                • Dec 2013
                                • 724
                                There seem to be relatively thick traces from both of these pins. Not clear which one would be gate, source, base, emitter etc. Could it be that the component is driven directly from the little transformer nearby, so you are measuring the transformer winding?
                                • petehall347
                                  • Jan 2015
                                  • 4438
                                  • United Kingdom
                                  #36
                                  i did wonder same thing . maybe test from transformer pins or remove transformer to see . it could still be something else though if removing transformer gets rid of the short . do those schematics not match your board ? i havent looked as low on internet credits at moment .
                                    • 31197
                                    pull the transformer.
                                    i have seen transformers like that used to boost gate-drive current in crt stuff.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      The more I look at that layout I'm more and more confused. Usually the thick wires are power/GND and TO-3's if looking from the bottom and pins rotated towards the "bottom" it'd be Source/Emitter on the left and Gate/Base on the right. Case is always Drain/Collector.
                                      Perhaps I should go to the local pick&pull and buy a module from them to study... (I wish I had schematics to my Chrysler RE42's TCU as it too failed in some odd way.)
                                      Supposedly the big/case connection is either drain or collector, what is this immediately connected to?
                                      Is what's supposedly source/emitter connected to GND?
                                      My guess is that 2211 SMD (2210 ohm?) resistor is not actually the base drive and just sucking off the GND connection. The buried connection is the source/emitter (I HATE THIS for multiple reasons and hope this isn't the way it was made). Then the base/gate is connected to the transformer with this wicked thick track...? This would be the only way for the wiring to make sense unless that device has a nonstandard pinout?
                                        • 31197
                                        strange.
                                        lets see what it connects.
                                        is the screwhole(s) actually connected to the groundplane that the metal case also goes on?
                                        and, does the large track go to any pins on the big connector?
                                        • CapLeaker
                                          Leaking Member
                                          • 8327
                                          I did take that little transformer out and the short on those TO-3 pins persists.
                                          No. The schematic is for a Cummins Celect Plus (N14). The board I am working on is for the Cummins Celect (M11).
                                          Did that and short between those pads is still there.
                                          There is no local pick and pull for big rigs around here unfortunately. The big case connection seems to be on the GND pins (09,28, etc.) on connector C. Also the case connection of the TO-3 does not go to the little transformer. I see the big track going underneath Connector C, thats it. The two pins from the TO-3 however do go to the transformer. The last picture in this post Where the flash glare is, that's where the little transformer was. You see the track that basically goes from one side of the transformer to the other, and then ends up on the negative of the first capacitor at the connector.
                                          Again first picture is supposed to be for the Celect Plus (N14) in which case the schematic is supposed to be for, but not the one we are working on!!!
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • corrize
                                            Where to find a very small fpc connector 0.3mm between 2 pins ?
                                            by corrize
                                            Hello, I search this connector (oxydated).
                                            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                            Do you know how to find this connector please ? What is the exact name for find it ?
                                            08-06-2024, 05:25 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • DominanceINC
                                            MSI Pro Z790-P Wifi 1missing CPU pins
                                            by DominanceINC
                                            I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                                            So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                                            The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                                            07-21-2025, 05:38 AM
                                          • magneh
                                            Behringer Eurolive B205D repair - help identifying transistor
                                            by magneh
                                            Hello
                                            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                            Still, I need to replace this transistor....
                                            06-18-2025, 02:34 AM
