Need help to ID this transistor
  • CapLeaker
    Leaking Member
    • 8327
    I've got a Cummins Diesel ECM here out of a 90's truck. There is a TO-3 style transistor 828S14 made by MSC in there. It is shorted between the pins. Anyone has a clue what that transistor is / crosses to?
    Thanks in advance, guys!
  • redwire
    • 3912
    Re: Need help to ID this transistor
    What does it drive. Is this for the fuel (rack) solenoid?
    • petehall347
      • Jan 2015
      • 4438
      • United Kingdom
      allied express have some very expensive ones ..
      i searched for data sheet but no luck .. am guessing it will be npn .
      shorted between pins is a bit unusual but not unheard of , base emitter are the pins .
      • CapLeaker
        Leaking Member
        • 8327
        Here is a picture of it. It's on the bottom board. I took the TO-3 out and the 2 pins are a dead short, which shouldn't be. It may be for the fuel rack solenoid, but I have no schematic to prove it until I get back to the shop tomorrow. The truck doesn't start anymore. First the truck would round an x amount of time and then shut off. After waiting for 2 hrs, it would start again. Now it doesn't start at all. Traced it down to the ECM, opened it up and found that TO-3 shorted.
        Those on Ali are no longer available (you have to look closely at the ad). Been there looked at them.
          • 31196
          as you have nothing to lose, see where it connects to.
          specifically where does the base-drive come from?
          if it looks like it's a normal transistor then stuff in a generic like a 2n3055.
          • CapLeaker
            Leaking Member
            • 8327
            I was hoping to use some generic replacement. I'll have a look at the shop tomorrow and see what I can find on their laptops. I'll try some tracing tomorrow, but it is a b*tch at best on that board.
            • redwire
              • 3912
              The two-pins shorting are a common failure all over the web on Cummins ECM's. This is a 24V vehicle?
              It's a custom part and I would guess a MOSFET fuel rack solenoid driver, or +5V reg.
              Automotive stuff has to pass load dump/reverse battery connection standards and that sometimes leaves huge oddball parts in an ECM.
              This thing is full of TO-220 parts so the TO-3 probably has very low on resistance or has the HV rating for load dump.
              I've asked an expert in the business, probably need to know what it connects to.
              Will let you know when I hear back.
              • redwire
                • 3912
                Need to trace out the PCB a bit and see what the transistor does. For the diesel fuel rack solenoid, it could be the PWM switch or boost converter. These solenoids are huge power.
                I think it's a MOSFET and nobody really sells those in a TO-3 package anymore unless MIL spec. Modern parts (since 90's) are much better for on-resistance etc. but TO-3P would have to fit.
                If the part shorted G-S then check the driver circuit hopefully is OK.
                So it looks like reverse-engineering needed to get anywhere with this part.
                Chevy's diesel Stanadyne DS4 diesel pump driver module blows up a lot. It uses two parallel MJ15004's 140V 20A ea. hFE=10 lol which get pretty hot and live a short life under the hood. Stanadyne-ds4
                • CapLeaker
                  Leaking Member
                  • 8327
                  sorry redwire, I just got back home, but I couldn't make it to the shop today as some thing else came along. So on that picture top left there is that round thing and underneath of it is a rectangular green capacitor. It's rating is 14uF / 150V.
                  I've tried to trace things a bit but didn't get very far as I loose it, jumping from one side of the board to the other side. One pin of that TO-3 goes straight to the small transformer (next to the two capacitors). The other pin goes to the Motorola IC, splits and goes to a TO-220 as well.
                  I did take the TO-3 out, measured across the pads on the board and those are shorted too.
                  At this point I am not sure if that ECM came out of a Dodge, or some International truck, but I am going there tomorrow to find out for sure.
                    • 31196
                    can we borrow a working one??
                    one of the cheap component testers would tell what it is instantly.
                    then we just need to decide on the frequency & current involved.
                    • petehall347
                      • Jan 2015
                      • 4438
                      • United Kingdom
                      try reversing your leads when measuring the board . there might be a cap still charged up looking like a short .. i have had this many times .
                      • CapLeaker
                        Leaking Member
                        • 8327
                        Well, that's something else I am hoping for, when I get to the shop tomorrow.
                        Nope, dead short on the pads, leads reversed or not, TO-3 removed.
                        Those TO-220's are IRF540
                        • petehall347
                          • Jan 2015
                          • 4438
                          • United Kingdom
                          am just guessing . the t03 being a suspect fet . the gate drive failed and took it out . without a schematic this wont be easy to fix . is there not anyone offering a rebuild service for the module ? being a common thing i suspect there might be .
                          good luck with it . i know i would be having a hard time with it for sure .
                          • CapLeaker
                            Leaking Member
                            • 8327
                            Yeah, the large disc on top left is a big ass inductor. Looking at the TO-3, it seems to be a fet of some sort, not a voltage regulator. There is almost no way of tracing things in there as it goes from one side to the other and then it ends up being underneath an IC or something else. However I think the short between the 2 pads for the TO-3 is coming from that little transformer next to it.
                            • redwire
                              • 3912
                              I would say it's part of a high voltage boost-converter for the pump... fuel control actuator. They can be 60-170VDC solenoids.
                              Is it weird the fat trace connects to TO-3 pin 1, usually the base/gate but goes to TDK transformer. Wondering if this part has reversed pinout.
                              But anyway, the driver seems shorted too and should be a couple SOT-23's... but if it runs to the MCU then this is not repairable. I think you need more than 5V gate drive unless a logic-level part.
                              • CapLeaker
                                Leaking Member
                                • 8327
                                Here is an update: It's a big 1994 Ford truck with an M11 Cummins engine. Engine serial # 34765933. It's Actuator connector "C" on that board. Basically there are 8 x 12V supply pins, 3 x return pins and 6 x 2 supply and return pins for 6 injectors. What happens is that there are NO dash lights at all (basically dead) when the ECM is connected, thus wont start. I think the TO-3 is a transistor like an NPN or PNP. I didn't find any other shorted component yet on that board, besides that TO-3.
                                I checked around, couldn't find a working ECM.
                                So I did more digging to find the short between the pads. If you look at the back side of the board, there is a wide trace and a small trace where the TO-3 goes. I removed that green SMD resistor on the small trace and guess what? There is still a short over to the other pad!? Wouldn't it maybe be a 3 layer board? With that SMD resistor gone, there shouldn't be any connection to the pad on the small trace and yet somehow them to pads are a dead short. Weird. Nope, nothing connecting them pads on the other side of the board.
                                • redwire
                                  • 3912
                                  The mystery TO-3 could be transformer-driven. From that TDK transformer.
                                  That would explain low ohms, even with transistor pulled.
                                  Um, is the TO-3 shorted out of circuit, we know it is pooched?
                                  If not, we may be on a goose chase.
                                  I don't like the black via by the C connector
                                  • CapLeaker
                                    Leaking Member
                                    • 8327
                                    The TO-3 is toast. It's pins are shorted. Post #12. The via isn't black on the connector, the camera just made it look like it. I've poked around there quite a bit.
                                    • redwire
                                      • 3912
                                      This (fake?) website teases with Cummins Celect ECU schematic but I couldn't download it. To at least find out what the part is.
                                      The big black donut is a potted toroid inductor for the boost-converter.
                                      I wonder if carefully hacksawing the lid off the TO-3 would reveal any die markings?
                                        • 31196
                                        russian search engine works well
                                        start here:
                                        http://garageforum.org/Thread-Cummins-Schematics
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • DominanceINC
                                          MSI Pro Z790-P Wifi 1missing CPU pins
                                          by DominanceINC
                                          I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                                          So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                                          The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                                          07-21-2025, 05:38 AM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
