PFC low?
  • dskall
    • Oct 2016
    • 2905
    • usa
    PFC low?
    I have a board that measures 357v with pfc. 162v in standby. I have read that it should be >360v. I know things don't work if pfc is missing, but what problems would it cause if just low? Is pfc a monitored voltage if low would it cause shut down?
    Re: PFC low?
    Common problem for having low PFC is due to the resistors in the feedback string that the resistance has changed.
    • R_J
      • Jun 2012
      • 9621
      Re: PFC low?
      I don't think 357 volts is low, pfc is working. if ac line was a couple volts low that could effect the dc voltage in standby and when the pfc is working
        Re: PFC low?
        In most Samsung if it goes below 360, the INVERTER or LED backlights circuit will go into shutdown.
        We do not know what power supply he is working on. Some other brands may not have that protection for low PFC but will have PFC Over Voltage shutdown.
        There are the so call fix for the SAMSUNG that has Backlights flashing problem and the supposed fix is to cut open a jumper, that jumper is for the LOW PFC Voltage shutdown protection, so when the jumper is cut the protection is no longer in place, I found and fixed the cause of the problem correctly due to resistors have drift off in value.
        • R_J
          • Jun 2012
          • 9621
          Re: PFC low?
          o.k. I did'nt think the pfc was that tightly regulated.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Re: PFC low?
            What would a proper working range be for PFC voltages?
              HDMI over CAT5 with a HDMI switcher for more than one computer being monitored proof
              I recently got a new shed that it my battery testing work bench beside this it also be electronic work bench as well and general work bench area as well
              I want to have a way to monitor more than one computer that is doing battery testing on the fly so I can switch between monitors and be able to see the results in real time
              I a chief engineer where I work gave me the information and idea to use a CAT5 repeater which would be the simplest way to do this
              They use a different method to transmit the data to tv monitors around the facility but that system requires...
              11-09-2023, 07:56 AM
            • sushilachuthan
              APC UPS error P13
              by sushilachuthan
              one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
              the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
              The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
              We replaced the SCR with new device,, but the device is not power on as expected.
              Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
              09-26-2025, 09:00 AM
            • double_DD
              Why does my ISP router hate my "homemade" power supply??
              by double_DD
              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
              07-12-2025, 03:09 AM
            • mon2
              A2141 Not powering on - case study
              by mon2
              This is a case study on a 'sudden death' A2141 unit brought in for service.
              USB-C meter is @ 5v with ~0A current draw.
              a) Disconnected battery. No power to the machine. Applied the Qianli Tail tester with the USB-C connector. Each USB-C power connector was green with the diode mode of testing. CD321x are not defective as originally thought.
              b) PPBUS_g3h is not shorted but is a low voltage due to the low INPUT voltage of 5v being boosted. On a random power up attempt, PPBUS_g3h was at the expected 12v63 range AND input voltage was observed to be @ 20v for...
              07-10-2025, 10:58 AM
            • Biruslapio
              Plasma Y board IGBT equivalency question
              by Biruslapio
              I have two TVs here with both Y-SUS failures, one LG and one Samsung.
              The Samsung's Y-main shorted one FGD4536 and one RJP63K2(there are two in parallel)
              I have the FGD but I only have one RJP63F3, which is different from the K2, so, can two 30J124 be put in place of two RJP63K2? are they equivalent?
              Also for the LG two 30F131 shorted, I have some FGD4536 (the same that are used on the samsung), can they be also be a substitute without issues?
              RJP63F3 and K2 are 630V 30A IGBTs, but their rise/fall time and other internal variants differ.
              04-06-2023, 08:09 AM
