Green green grass of home. (pic 1,2) Pictures took yesterday, I wear T-shirt and short on this sunshine sunday afternoon, as a weekend handyman.
Routine maintenance on HVAC save you $12,000
Re: Routine maintenance on HVAC save you $12,000
Opened the exhaust fan from furnace and condenser of the cooler HAVC which on top of the furnace.
PS: This Goodman system, Id changed 10uf capacitor for blower fan, control PCB, flame roll out switch and sprayed rust prevention.
PS: I found out the water leak is from fireplace chimney thought the furnace's exhaust fan, not from AS- I- Thought-condenser of the cooler ! (pic15)
PS: the Cooler Coating spray (Homedepot) is a nasty stuff like TAR.Last edited by capwizard; 01-30-2017, 09:13 AM. -
i am showing off to the neighbors, now they all want me be their Handyman!!!......
She said " Id changed the system to YORK two years ago for $12,000 they installed in just one day, and the most of neighbors did.", and how well her kids doing in the school gonna be a MD Doctor.........bohr....bohr ....bohr........"
PS: OK, I will keep my ANTIQUE Goodman runs as long as I can!!!!
PS: That's why HVAC makes money and TV repair business is SUCKsLast edited by capwizard; 01-30-2017, 09:02 AM.Comment
"is SUCKs"
You have an extra "is" in there...Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Thank you for pay attention to it, It is SUCKs , grammar is wrong but (is) is my version of emphasize, use as a (be).......
I think TV repair business is SUCKs better than TV repair business SUCKs, it mearns TV repair business is going to be SUCK, or
TV repair business is....SUCKs.Last edited by capwizard; 01-30-2017, 12:49 PM.Comment
$12,000 one day, I wanna go into HVAC business. .........Ha......Ha............ "you did not have HVAC license"...........OK, Who told you, The Boss needs the license..I am a investor and hire 3 peoples have HVAC licenses then I can sale and service the HVAC unit. Kinda like I open a hospital and hire MDs work for me...................
PS: Service HVAC is much easier than repair TV. PLs don't bug me........ My Personal Opinion.
PS: Crane one time charge $250, customer metal ductwork $250, two HVAC tech.s daily salary about &240 each.Last edited by capwizard; 01-30-2017, 05:01 PM.Comment
i'm an amateur.........This is my preconceived opinions , Hope, someone might give me better ideas. let us save money together.
How to clean the copper fittings and connectors: brush with WD40 then heavy grease. (prevent freon leakage)
PS: Why I said "brush with WD40" ......I [canopener] the non-air-WD40 can, correct the oil, put in the cosmetic spray bottle, reuse it.
How to clean the fins of the condenser: First DustOff + spray vinegar + brush with baking soda powder + water off the bubbles.
How do I know if my current air conditioner uses what kind of refrigerant? Most air conditioners have a nameplate on the unit that identifies the type of refrigerant it contains.
How to charge an Air Conditioning unit low on freon:
Step by Step instructions on how to properly Check Refrigerant Charge!
https://www.youtube.com/watch?v=SUyN94Y39Ro
Is my Air Conditioning unit low on freon?
https://www.youtube.com/watch?v=c4i6_Xi5si4
How to Charge an Air Conditioner That is Low On Freon ~ AC 101
https://www.youtube.com/watch?v=0bi1bcyPSyY
HVAC Maintenance Checklist (by Trane)
https://www.trane.com/residential/en...ance-tips.html
Regular HVAC preventative maintenance is the best way to ensure trouble-free operation and peak performance.
pic3 Printable checklist
http://www.hvacsticker.com/images/pr...ecklist-lg.jpg
pic4 Printable checklist
http://www.sawyoo.com/postpic/2013/1...pdf_617493.pngLast edited by capwizard; 01-31-2017, 10:00 AM.Comment
If you want to go into this you could take a 9 month course and get a certificate. Then you could work 1 to 2 years in the field. Finally you could start your own business. That way you would be well versed in the field. The reason these guys get paid a lot of money is because it is a physical/mental job like a mechanic. You could get paid well as a lineman for the power company. If you went into medical electronics you would be paid well.Comment
I only know air conditioning changes gas to liquid, liquid to gas. That is all my knowledge.
i have two friends both have HVAC certifications, they are all doing something else because of the harsh weather and toughness of the jobs.
PS: i'm an investor post #6Last edited by capwizard; 01-31-2017, 11:42 AM.Comment
Beware of HVAC Scams!! My neighbors should watch this before they spended $12,000.
I cleaned two outdoor Condenser and Compressor units, Kinda like this one. Look at this one! What does yours look like?
I will check the Capacitors next time.Last edited by capwizard; 02-06-2017, 07:32 AM.Comment
40 to 50 *F Evaporator coil temp but ---> one way to really check this is take a reading on ether side of the evaporator coil you need at least 15* F difference between the two reading
The condenser coil would any where from 120* to 180* air discharge temp depending on how old the unit is but---> one way to check this is the liquid line temp should only some what warm to the touch not hotLast edited by sam_sam_sam; 02-08-2017, 05:34 AM.Comment
Your right the evaporator coil temp would need to be more than 32*F other wise it would freeze
A 15 degree temp drop is a little low in my experience. Once the environment has stabilized it should probably be closer to 18-20. The best thing is to refer to the manufacturers charts to see what it really should be. High indoor humidity along with high outside air temp will reduce the temp drop.Comment
What you have there is very true
I was basing this on older units that did not have high efficiency and that was the hard fast rule back then
Now if one of newer units that has a VFD fan motor then yes the temp difference will be 18* to 20* F
It could even be a little more more than that if has a temp sensor on the evaporator coilLast edited by sam_sam_sam; 02-08-2017, 01:00 PM.Comment
Test Run Capacitors and change compressor electric connectors.
A unit 5/40uf tested are 4.31/38.5 uf
B unit 5/40uf tested are 4.2/36.2 uf
It seems to be OK , I Ordered two of Run Capacitors gonna change them anyway.
PS: The Electric wire 220v terminals look really bad. I changed them. Will put some solder next time.Last edited by capwizard; 02-13-2017, 07:22 AM.Comment
In this 5 bedroom 2 story house I found another gas furnace lay horizontally over the attic. So each floor has their own HVAC system.
PS: Totally I changed 4 capacitors and one PCB....................Comment
This is just me BUT when I one pole contacter I change them on site
Here is why I do this with one pole contacter only break one side of 220 so that means that you still have 120 volts going to the compressor and fan not problem unless you have a short in either the fan or compressor to me this is not a good thing I always use two pole contacter for this reasonComment
Yes, 2 pole compressor contactor is better......
1 vs. 2 pole contactors
I have always replaced the contactor with the same thing that was already in the unit. If it was a single pole, put a single pole back. But the other day I was told that I could just use a double pole for for all replacements.
Goodman puts single poles on all their builders units doesn't seem to make a difference in the long run I think they're just cheaper.
What is a Single Double & Tripple Pole Contactor -and Can / Should you change yours?
https://www.youtube.com/watch?v=o-bjYucLXBk
how to replace a contactor
https://www.youtube.com/watch?v=3oz5HLk6ZDkLast edited by capwizard; 03-06-2017, 10:30 AM.Comment
The reason they use a single pole contactor is two fold, first, and foremost, it is cheaper. However, in theory, it saves them from having to furnish a crankcase heater for the compressor by applying 120 volts across the motor windings of the compressor, keeping the oil warm that is in the crankcase.
Now you know.....the REST of the story!Comment
by bseinfoHi everyone,
I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...07-05-2025, 10:53 AM -
by KYBOSHPicked this one up today.
In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
Wanted to get a 2nd opinion from you guys before I gave up the ghost.
Great looking TV otherwise.
Is there any tricks I can do to try to save this one?
If so, i'll gladly order a set of backlights and save this one from the landfill..
Thanks in advance
by DrDosHello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
by fixitforfreeI have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different... -
by ConsteHello together,
I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
Already changed the CMOS battery... - Loading...
