What kind of resistor is that?
  • buchman
    • Aug 2015
    • 294
    • greece
    In that picture there is some kind of component, it look like a resistor but it's a bit bigger and there is a coil inside.
    Who can tell me what that is exactly?
    Thanks in advance.
    Re: What kind of resistor is that?
    That is just a small axial lead inductor, looks to connected between two filter cap (+) legs to form Pi filter.
    Upload the pictures of the bottom side of the board to verify.
    I.E.:
    http://www.digikey.com/product-detai...8156-ND/774696
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Hmmm, the color bands suggest to me it could be a 1K resistor. An ohm meter should tell the difference - an inductor would probably be an ohm or two at most, while a 1K would be much higher (not necessarily 1K, since it's in-circuit).
      PeteS in CA
      • capwizard
        • Jun 2016
        • 1991
        I bet you,This is a 1uH 10% tolerance inductor . and circuit look like 9v battery step up power supply for high voltage usage. ex: for Lamp, electric fence.....
        http://www.vishay.com/inductors/color-code-calculator/
        • redwire
          • 3912
          I agree with budm, looks like an inductor. Maybe as the Pi filter.
          But the color code is odd brn/blk/red/silver gives 10mH +/10% when typically these parts are ~10uH. Putting an ohmmeter on it will sort it out.
          I usually find the power transistor/capacitors are shot in these small AC wall adapters.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Could be either it would depend on how it is connected. Or you could measure it. It is either 1,000 ohms/1k ohms 10% tolerance or 1,000 uH/ 1mH 10% tolerance.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              This particular green-blue color is typically used for inductors.
              The color code could be either gray-red-black-brown (82 uH, 1%) or brown-black-red-silver (1 mH, 10%). I think it's the latter. Looks like it's used as a PI coil between the two caps.
              • capwizard
                • Jun 2016
                • 1991
                My BAD! my mistake ( , ) with ( . )!!!
                1.000uH=1uH 1,000uH = 1muH
                momaka you're right brown-black-red-silver (1 mH, 10%)
                • buchman
                  • Aug 2015
                  • 294
                  • greece
                  It's a wall cell phone charger. I took this resistor/inductor out of the board and measured for ohms, it indicates approximately 5-7 ohms.
                  How do I measure inductance?
                  What parameteres I need to know to buy one like this? I meen, what should I say in the store to the seller?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    That means it is probably okay. Inductors typically show very low resistance when measured with a multimeter, especially ones that don't have many turns. For this small inductor to have 1 mH of inductance, it means the wire of the windings inside it must be very thin... hence the fairly high resistance you got.
                    Well, this might seem like a stupid answer, but... inductance meter!
                    Of course, those cheap eBay transistor testers will also work. The only problem they have is they they can't measure less than about 10-30 uH. So the inductors you see on motherboard and in power supply output stages will appear as a short-circuit and no inductance on those meters.
                    You need to know the inductance (1 mH... or 1000 uH if you prefer) and current rating. The current rating will depend on what your charger can output. If it's 500 mA, then you need to get an inductor capable of 500 mA or more. 2x the current rating output of the stated current on the charger is typically preferred. So for a 500 mA charger, use an inductor capable of handling 1 Amp.
                    Didn't even notice it.
                    I read one intro engineering book a long time ago that said to never use a comma (,) when separating zeros above the thousands range. Reason being that you can easily mistake the (,) with (.). Also not a good idea when working in an international teams (European countries, for example, use comma (,) as the decimal separator).
                    • capwizard
                      • Jun 2016
                      • 1991
                      You certainly are the best.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        so what is wrong with the with the charger? What isn't it doing.
                        • buchman
                          • Aug 2015
                          • 294
                          • greece
                          It doesn't charge the cell phone. I know that it's very cheap and I should buy a new one but, it's kind of a small project to me to raise my confidence ☺
                          I have a plasma TV (lying in my bedroom for a year) that is waiting to be fixed (I can't find the problem so I thought I would start from something simple).
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Actually there are a lot of techs on this site that are very good with trouble shooting tvs.
                            So the charger itself is not working? In other words it is not putting out the proper voltage when measured by itself with volt meter? ?
                            • buchman
                              • Aug 2015
                              • 294
                              • greece
                              It has a led light that should light up when the charger is connected to the wall.
                              Anyway, I ordered 2 caps and a diode that I believe they are all dead. The capacitor rated 2.7 uf but the DMM shows 8.4uf.
                              The diode show 0.173 so I believe I am not wrong.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                So did you measure the output voltage of the charger to verify your LED is not bad?
                                • buchman
                                  • Aug 2015
                                  • 294
                                  • greece
                                  No. How do I measure inside the plug of the wire of the charger?
                                    • 31281
                                    show us the diode & capacitors
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      So the charger does not have a connector that connects to the cell phone? The chargers of cell phones I have seen have a connector that connects to the phone. Usually the are round and you can put the + DVM meter probe inside this connector and the - DVM meter probe on the outside of the connector set the DVM to DC voltage range. Make sure the charger is plugged in. The charger will have a DC voltage rating on it. Your measurement should be very close. If the connector is tiny use a small gauge wire to put in the + terminal of the connector. Just make sure you do not allow a connection path between connector terminals so that it shorts out the charger.
                                      • and555
                                        • Apr 2016
                                        • 36
                                        • Indonesia
                                        Simply, soldering a cable to each output (+) and GND, then please measure.
                                        Usually the biggest cap is output.
                                        • magneh
                                          Is this some kind of fuse resistor ?
                                          by magneh
                                          Hello guys
                                          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                          Seem to me like some kind of fuse resistor?
                                          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                          The red band is larger than the 4 others, but I dont have much experience with these components.
                                          Also one of the orange...
                                          02-10-2025, 07:54 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                          Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                          by momaka
                                          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                          09-19-2021, 08:44 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
