Cisco 1802 Router Damaged by Lightning
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Hi All
    I need some help.
    I had one unit of Cisco 1802 which was damaged by lightning.
    As attached you can see that the capacitor has been charred / burnt out.
    The Fuse has been tested with a DMM and it was found to be open.
    I know that getting cisco schematics are difficult.
    Looking for values for C260 and C261
    and curious on what is CR20 and CR22, which I believe is a protection diode.
    Just wanna check how it is tested, made by ST ML16 C723
    Thanks in advance.
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Cisco 1802 Router Damaged by Lightning
    Originally posted by ant3202
    Hi All
    I need some help.
    Thanks in advance.
    I noticed that cr usually do not refer to a diode . You can affirm that if there isn't an anode bar on it .. I think they are some capacitance resistance like their abbreviation say .
      • 31277
      cr look like some type of diode - maybe a zener surge protector.
      i would meter them, and the windings on that coil
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        Somehow yes .. Looking at older routers reveal that this piece is a surge protector , but it's not a diode , or at least in testing purposes .
          • 31277
          no, but it shouldnt look shorted
            • 31277
            found it.
            smp100mc-160 Trisil
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              found it.
              smp100mc-160 Trisil
              this is good info...... appreciate it.
              • ant3202
                • Jun 2006
                • 275
                • Singapore
                update....
                the bad smd had been removed...
                does anyone has a clue on those two values?
                many thanks
                  • 31277
                  connected to ground from a data line - very low - probably in the pF's but high voltage to survive spikes.
                  you find stuff like that in modems and old set-top boxes with a fone connection.
                  • double_DD
                    Why does my ISP router hate my "homemade" power supply??
                    by double_DD
                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                    07-12-2025, 03:09 AM
                  • pfl
                    ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                    by pfl
                    Hello Everyone.
                    This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                    It consists in :
                    • a power board were the full H bridge class D amplifier and main power rails are located
                    • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                    Power rails are ok.
                    human interface is working fine
                    Input levels are...
                    01-23-2024, 10:21 AM
                  • auraaura
                    Sony XBR-55X800H Lightning damaged
                    by auraaura
                    The power surge came-I think- through the DSL line. TV gave a very audible pop and died. (Ethernet ports in modem were all killed too). Power light on TV was dead. I ordered a "Complete LED TV Repair Parts Kit" from shopjimmy.com and installed everything ( https://www.shopjimmy.com/sony-xbr-5...air-parts-kit/ ). TV will turn on for about 30 seconds or so then shut down. Power light flashes 7 times repeatedly. I've seen that this indicates a high voltage shutdown.? But-where is this coming from since I've replaced power supply, main board, etc.? I see that shopjimmy...
                    04-29-2022, 11:08 AM
                  • XxMicroSoldering
                    ASUS Rog Strix G17-712LV Laptop Liquid damaged
                    by XxMicroSoldering
                    Hello Guys
                    I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                    10-17-2024, 10:45 AM
                  • Tomylee
                    Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                    by Tomylee
                    I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                    It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                    I'm looking for help with the following:
                    The exact identification or part number of the T5 component
                    05-28-2025, 12:42 PM
